engine startup problem
Old May 29th 05, 02:51 AM
Frank Ch. Eigler
Default engine startup problem
Hi -
Very rarely, one of the 6-cylinder Lycoming IO-540's in my Aztec acts
up after startup. There is a fair amount of vibration, and a high MP
(20") for the resting 1000rpm, and if the engine monitor is turned on,
it shows three of the six cylinder (1, 3, 6) not making any heat.
Turning on the electric boost pump, playing with the magnetos,
mixture, throttle, all seem to not help.
After a shutdown and a minute's rest, a subsequent startup is usually
perfect, with all cylinders firing well throughout the runup and
flight. Post-flight visual inspection of the cylinders appears
normal.
Does this set of signs ring a bell toward a possible explanation?
- FChE
ROP masking of engine problems Roger Long Piloting 1 September 25th 04 08:13 PM
Diesel engine Bryan Home Built 41 May 1st 04 08:23 PM
Engine... Overhaul? / Replace? advice please text news Owning 11 February 17th 04 05:44 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 05:09 PM
