The world’s biggest jet engine, explained - GE tested the engine on a custom 747-400; it's on the right.jpg ...
Old October 15th 20, 04:12 PM posted to alt.binaries.pictures.aviation
Miloch
Default The world’s biggest jet engine, explained - GE tested the engine on a custom 747-400; it's on the right.jpg ...
more at
https://www.popsci.com/story/technol...ine-explained/
Late last month, the Federal Aviation Administration signed off on the biggest
commercial jet engine in the world. The huge thrusters that it certified are the
GE9X engines, one of which hangs under each wing of Boeing’s new widebody 777x
aircraft. That plane flew for the first time back in January, and boasts folding
wingtips—when they’re folded down for flight, they make the wings longer and
thus more fuel efficient, and when they’re folded up, the plane will occupy less
space at an airport gate.
Fuel-thirsty four-engine jets, like the Boeing 747 and Airbus A380, are
decidedly passé these days, while aircraft with just two engines represent both
the present and future of air travel. To push the big 777x forward from a
standstill into the air, Boeing needs two big engines that can create literally
tons of thrust. Here’s how they break down, by the numbers.
105,000 pounds
Each engine can produce 105,000 pounds of thrust for a total of 210,000 pounds.
(The engine has even hit 134,300 pounds of thrust, a record.) But Pat Donnellan,
an engineer on the GE9X engine program, says that pilots probably won’t need to
max the engines out to get off the ground. In fact, maxing the engines out for
liftoff is known as a “full-rated takeoff,” he explains, but there’s no reason
to do that unless you need to. “You want to conserve as much of the life as
possible, and not tear up an engine,” he says. He compares it to driving:
Ideally you’re not flooring the gas unless you really need to. More typical
lift-offs are called “derated takeoffs,” Donnellan says, in which “they use the
right amount for the load that they’re carrying—the amount of passengers and
cargo.”
For context, the single-engine on an F-16 produces less than 30,000 pounds of
thrust, which is plenty for a small, nimble aircraft.
134 inches
That’s the diameter of the fan in the front of the engine, measured blade tip to
blade tip. That 11-foot span means that if you stood in the front of the engine
in its front case (an activity best done when the plane is on the ground, with
the engine off), you’d have plenty of headroom. That fan is the star of the show
when it comes to producing thrust. “With the 777x being larger, we needed an
engine that would provide the thrust level that the airframer wanted,” Donnellan
says, referring to Boeing, “but at a much more efficient capability.”
“To get there with a turbofan engine,” he adds, “you want to make the fan
larger.”
16 blades
The curvy carbon fiber blades that constitute the spinning fan are fewer in
number than they used to be. The engine’s ancestors, the GE90 and GENX, employed
22 or 18 blades. These new ones can produce more lift, and that’s because of
design tweaks. “It’s got a wider chord to it—from the leading edge to the
trailing edge,” he says. (“Chord” is a common wing measurement term.) “It’s got
a little more twist in the proper areas, to generate that extra lift when we
need it,” he adds. The fan blades are like wings, spinning in the engines, he
notes.
2,400 degrees
The inside of the engine gets very toasty. The guts of a turbofan engine are
complex, but major components include the low-pressure turbine, the
high-pressure turbine, the core, and the compressor. Air in the compressor, as
you could imagine, gets compressed. “What you’re trying to do is drive the air
down to the smallest amount, the smallest package, that you can,” Donnellan
says. “You’ve got a lot of energy now in that small package, and then you put
that into the combustor.” Fuel enters the equation. “You ignite the fuel, which
causes that small package of air to now get very big, very fast, and it will go
through the high-pressure turbine.” That turbine harvests that energy, and some
of that energy then fuels the low-pressure turbine, which powers the fan in the
front.
The warmest part of the engine is the high-pressure turbine. “It’s right behind
the combustor,” he says. To handle that temperature, which is roughly as hot as
lava, if not hotter, the engine makes use of ceramic matrix composite materials.
“They can withstand temperatures much greater than available metal alloys that
are out there today,” Donnellan adds.
More than 15 feet
The fan doesn’t spin in the open air, like a propeller does. It’s encased in a
frame. The round material you see at the front of a jet engine is known as the
forward fan case. One of the purposes of that case is that it “shrouds” those
fan blades' tips, to create as much efficiency as possible. Also, if there were
to be damage to the engine, the engine-maker wants the debris kept within it,
and not flung outwards. Donnellan estimates that the size of the fan case adds
around 6 or 8 inches to the engine size, and when you factor in an additional
Boeing part called the nacelle, the entire engine measures, reportedly, over 15
feet across, a stat that GE confirms. That’s roughly the length of a Toyota
Corolla.
Name:	The 16 carbon-fiber blades in the fan produce the thrust..jpg
ID:	135069  Click image for larger version
Name:	The engine's fan measures about 11 feet across..jpg
Flying The World's Biggest Turboprop - Antonov An-22 preview - Flying The World-s Biggest Turboprop - Antonov An-22-thumbs.jpg Miloch Aviation Photos 0 September 27th 20 06:45 PM
article - The World’s Hugest Jet Engine Is Wider Than a 737’s Fuselage Charles Lindbergh[_2_] Aviation Photos 2 April 29th 16 02:42 PM
The biggest Aircraft Carriers in the world PilotJedi Aviation Photos 0 July 29th 14 09:03 AM
Lancair Columbia 400: The World's Fastest Certified Piston Single Engine Aircraft! David Ross Aviation Marketplace 0 August 24th 04 07:13 PM
biggest military airport in the world David Anderson Military Aviation 23 January 13th 04 06:39 PM
