NASA uncovers hidden water pockets on the moon that could be crucial for future missions
Old October 26th 20, 06:16 PM posted to alt.binaries.pictures.aviation
Miloch
Default NASA uncovers hidden water pockets on the moon that could be crucial for future missions
https://www.mirror.co.uk/science/nas...ckets-22907703
Water hidden in tiny patches on the moon could provide key access to drinking
water for astronauts on future lunar missions, according to NASA
Hidden pockets of water on the moon could be much more common than scientists
previously thought, and the discovery could have potential implications for
future lunar missions.
Researchers suggest that in some cases tiny patches of ice might exist in
permanent shadows no bigger than a penny.
They explored phenomena on the moon called cold traps, which are shadowy regions
of the surface that exist in a state of eternal darkness.
It is thought that many have gone without a single ray of sunlight for
potentially billions of years.
Now scientists say there may be a lot more of these nooks and crannies than
previous data suggests.
Paul Hayne, assistant professor in the laboratory of atmospheric and space
physics at University of Colorado Boulder, said: "If you can imagine standing on
the surface of the moon near one of its poles, you would see shadows all over
the place. Many of those tiny shadows could be full of ice."
Drawing on detailed data from NASA's Lunar Reconnaissance Orbiter, the
researchers estimate the moon could harbour roughly 15,000 square miles of
permanent shadows in various shapes and sizes.
According to scientists, these might be reservoirs capable of preserving water
via ice.
Prof Hayne added: "If we're right, water is going to be more accessible for
drinking water, for rocket fuel, everything that Nasa needs water for."
Previous research has reported signs of hydration on the lunar surface,
particularly around the south pole.
However, these detections are based on a spectral signature, at three
micrometres, that cannot discriminate between water and hydroxyl (oxygen bonded
to hydrogen) bound in minerals.
In one of two papers published in Nature Astronomy, Casey Honniball, from the
University of Hawaii, and colleagues analysed data from the Stratospheric
Observatory for Infrared Astronomy (SOFIA) airborne telescope that observed the
moon at six micrometres.
At this wavelength, they were able to detect a spectral signature of water that
is not shared with other hydroxyl compounds.
They found water is present at high southern latitudes.
The authors suggest the detected water is probably stored in glass or between
grains on the lunar surface that protect it from the harsh environment.
In the other study, Prof Hayne assessed a whole range of possible sizes for cold
traps, down to one centimetre in diameter.
The team found that small-scale micro cold traps - some just 1cm wide - are
hundreds to thousands of times more numerous than larger cold traps, and they
can be found at both poles.
The authors suggest that approximately 40,000 square km of the lunar surface has
the capacity to trap water.
Researchers say the findings indicate water is efficiently produced or delivered
on the moon by various processes, and is likely to be stored in the moon's cold
traps at both polar region.
The team pulled data from real-life observations of the moon, then used
mathematical tools to recreate what its surface might look like at a very small
scale. They say it is a bit like a golf ball.
However the researchers caution that they cannot prove these shadows actually
hold pockets of ice, and the only way to do that would be to go there in person
or with rovers and dig.
But they say the results are promising, and future missions could shed even more
light on the moon's water resources.
Prof Hayne said: "Astronauts may not need to go into these deep, dark shadows.
They could walk around and find one that's a metre wide and that might be just
as likely to harbour ice."
Old October 26th 20, 06:35 PM posted to alt.binaries.pictures.aviation
Mitchell Holman[_9_]
Miloch wrote in
https://www.mirror.co.uk/science/nas...er-pockets-229
07703
drinking water for astronauts on future lunar missions, according to
NASA
scientists previously thought, and the discovery could have potential
implications for future lunar missions.
in permanent shadows no bigger than a penny.
shadowy regions of the surface that exist in a state of eternal
darkness.
than previous data suggests.
space physics at University of Colorado Boulder, said: "If you can
imagine standing on the surface of the moon near one of its poles, you
would see shadows all over the place. Many of those tiny shadows could
be full of ice."
miles of permanent shadows in various shapes and sizes.
preserving water via ice.
accessible for drinking water, for rocket fuel, everything that Nasa
needs water for."
surface, particularly around the south pole.
(oxygen bonded to hydrogen) bound in minerals.
from the University of Hawaii, and colleagues analysed data from the
Stratospheric Observatory for Infrared Astronomy (SOFIA) airborne
telescope that observed the moon at six micrometres.
water that is not shared with other hydroxyl compounds.
between grains on the lunar surface that protect it from the harsh
environment.
sizes for cold traps, down to one centimetre in diameter.
- are hundreds to thousands of times more numerous than larger cold
traps, and they can be found at both poles.
surface has the capacity to trap water.
delivered on the moon by various processes, and is likely to be stored
in the moon's cold traps at both polar region.
used mathematical tools to recreate what its surface might look like
at a very small scale. They say it is a bit like a golf ball.
actually hold pockets of ice, and the only way to do that would be to
go there in person or with rovers and dig.
even more light on the moon's water resources.
shadows. They could walk around and find one that's a metre wide and
that might be just as likely to harbour ice."
Far from being a rare commodity, water seems
to be everywhere in the solar system and even the
while universe. it is deep within the earth, it
is on the moon and Mars, it is in the astroids
and comets, all over the Jovian and Saturnian
moons, and the Oort cloud.
As one astronomer recently put it, "water
wasn't brought to Earth, it was always here".
Old October 26th 20, 08:15 PM posted to alt.binaries.pictures.aviation
Miloch
In article , Mitchell Holman
says...
Miloch wrote in
07703
NASA
darkness.
be full of ice."
needs water for."
environment.
'Jack and June went up to the moon
to fetch a bottle of water
When Jack fell down and broke his crown
June came tumbling after
[18th Century]
Trump's NASA Budget Would Cancel Space Telescope & 5 Earth Science Missions Stormin' Norman[_2_] Aviation Photos 0 August 9th 18 06:50 PM
FURTHER F-22 PRODUCTION IS CRUCIAL TO WINNING FUTURE WARS. Michel[_2_] Naval Aviation 11 August 3rd 08 08:38 AM
Bush to return NASA to moon Aerophotos Military Aviation 51 December 9th 03 07:43 AM
NASA "moon" video with air effects B2431 Military Aviation 12 November 24th 03 09:26 AM
