Blinking ICOM charger light
Old May 11th 21, 12:43 AM posted to rec.aviation.soaring
jp
Default Blinking ICOM charger light
The light on my ICOM A14 charger was blinking orange/green and the charger was not charging the battery.
I took the battery off the radio, used a pencil eraser to clean the electrical contacts on the battery - they looked fine to me by the way - and now the charger light no longer blinks and it charges the battery.
By the way, I had looked in the A14 manual for info on this blinking light and found no reference to it.
Old May 11th 21, 09:55 AM posted to rec.aviation.soaring
Tim Newport-Peace[_7_]
Hi Jim,
Assuming you are using BC-179 charger, there is a reference to blinking
orange/green in chapter 7 of the manual, "Orange or green (blink):The
battery pack or the charger has a problem". Maybe you have a different
manual? PM me if you need a copy of my manual.
Incidentally, using a pencil eraser to clean contacts is depreciated. It
often leaves residue which insulates.
Tim.
Old May 11th 21, 03:39 PM posted to rec.aviation.soaring
jp
Hi Jim,
Tim.
Hi Tim,
It is the BC-179 charger. It came in the box with the A14 radio. I don't think a manual for the
charger was included in the box. All seems to working now, fortunately.
I have a spray cleaner for electrical contacts but it seemed like overkill for the contacts
on the battery. After using the eraser on the contacts I did check that no eraser bits remained.
I hope that was ok. The battery is now charged up and the radio is working fine.
Thank you for your help.
Old May 11th 21, 04:06 PM posted to rec.aviation.soaring
Hi Jim,
Tim.
Hi Tim,
No. It is in the A14 manual, quote:
• Charging indicator color information
Orange: While charging
Green: When charging is completed
Orange or green (blink): The battery pack or the charger has a problem.
it also says:
Be sure to turn OFF the transceiver power, when charging
the battery pack along with the transceiver.
P.S. Not only does IPA Cleaner clean contacts, but it kill SARS-CoV2.
Old May 11th 21, 07:21 PM posted to rec.aviation.soaring
jp
Hi Jim,
Tim.
Hi Tim,
it also says:
Hi Tim,
I'm going to shoot IPA up my nose! Maybe not.
I see the notice you point out in the A14 manual. I missed it the first time around.
The "...has a problem..." notice may have helped but I probably would have had
to guess at cleaning the contacts as a hopeful first step. My guesses usually
don't work out well. I was lucky this time!
Convair Model 48 Charger pics [7/7] - Convair Model 48 'Charger' prototype, a competitor to the OV-10 Bronco, in flight.jpg (1/1) Miloch Aviation Photos 0 April 8th 20 03:11 PM
iCOM IC-A5 charger Charlie Papa[_2_] Soaring 0 November 29th 17 07:23 PM
FS Cheap Icom PW-1 1KW,Icom ID-1,IC-92AD,IC-756PRO III g0iqn Aviation Marketplace 0 July 1st 12 08:33 AM
Cursor keeps blinking on FS 2004 Dave Schwartz Simulators 1 January 4th 04 04:18 AM
Icom CM-35 Desktop Battery Charger for Icom IC-A2 Radio A. Kay Aviation Marketplace 0 August 23rd 03 08:01 AM
