Winch demonstration/training at home gliderport
Old June 8th 21, 08:19 PM posted to rec.aviation.soaring
kirk.stant
Default Winch demonstration/training at home gliderport
St Louis Soaring Association (stlsoar.org) is interested in a winch demonstration and possible training at our home gliderport (H07) in Highland, IL - located 30 miles East of St Louis right off I-70.
We currently aerotow with 2 Pawnees and a Supercub, but are looking at the future sustainability of that method (Cost, Noise, etc) and want to explore other options.
We have a wide but relatively short (2600 x 500 ft) grass airfield, all of it available for winch launches - so launch height would naturally be somewhat limited; however if the decision to go with a winch was made we have the option to extend that to almost 4000' when launching to the North, by locating the winch in a field that we own. That should be enough for some decent height.
Our fleet is almost exclusively glass with CG hooks, K-21s for training.
If anyone has any suggestions, please contact me.
Cheers,
Kirk
66
Old June 9th 21, 04:31 AM posted to rec.aviation.soaring
AS
Cheers,
Kirk
66
Kudos for thinking about a winch as an alternative! Bringing a winch to your field may not be as straight forward as one would think. We can tow our winch legally on public roads but only with the state of SC. Going out of state would require a title, registration and license plate = major headache for a home-built rig.
I invite you and anyone else to come to SC and participate in a winch clinic
Old June 9th 21, 09:39 PM posted to rec.aviation.soaring
SGS N2062T
would your winch fit on a flatbed car trailer?
I mean, I have done dumber things to get a ride...
Old June 10th 21, 03:40 PM posted to rec.aviation.soaring
AS
Hauling a winch on a flat-bed trailer is always an option but I assume that it is a costly endeavor. Might be easier to put the K21 into a trailer and take it to a place that is running a winch. You could pay out only the amount of line equivalent to your line run at your home field and see what it does for you.
Also, I took a look at the field using Google-Earth. To extend the line run into the field to the north - as mentioned by Kirk - would require the closure of a road. If that's that an option, great. The winch would then be placed very close to I-70. Not ideal but doable. What are your prevailing winds on that field? How many days a year would you really launch to the north? All these things would have to be analyzed before making the decision to go for a winch.
Uli
'AS'
Old June 10th 21, 04:09 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
On Thu, 10 Jun 2021 07:40:01 -0700, AS wrote:
What are your
Good points. I'd add a couple more, from the way my club normally
operates.
1) the rule of thumb says that generally launch height is 1/3 the
distance between launch start point and where the winch is placed on our
main run (04/22 with 22 being the prevailing wind direction).
We normally place out winch (a Skylaunch with a truck's V8 running on LPG)
4000 ft from the winch) and typically launch to 1400-1600 ft regardless
of wind speed, though we can hit 2800ft in a strongish wind with a good
speed gradient.
2) despite having a wide grass main run (475ft wide) we typically place
the launch point 500 ft from the downwind boundary so landing gliders can
stop before or just after they reach the launch point. Yes, this adds to
the required runway length, but it makes the launch rate a lot faster
since theres no wait while the landed glider is moved back out of the
danger zone for failed launches.
3) Our other run (16/320, 2800 ft x 300ft) is shorter and narrower with
no landing area behind the launch point. The result is a very low launch
rate because almost every landing stops well past the launch point, so
launching stops while a golf buggy gets the glider and puts it on the
back of the launch queue. Launches on it seldom exceed 900 ft.
HTH
Martin | martin at
Gregorie | gregorie dot org
Old June 10th 21, 07:55 PM posted to rec.aviation.soaring
Kirk,
Sandhill Soaring Club has a similar situation in terms of runway length and winch setup (we use an adjoining field to launch sometimes). Please message me and I can put you in contact with our Chief Flight Instructor who can tell you a bit more about our operation.
Chris Schrader (I mostly fly "CN")
Cheers,
Kirk
66
Old June 11th 21, 06:30 PM posted to rec.aviation.soaring
kirk.stant
Some quick answers to above questions:
1. Our club owns the field north of the runway, and the road in question is a farm right-of-way with very limited traffic. It would likely not be a big issue to hold up a launch when a vehicle approaches. On the other hand, when the field is actively being cultivated/harvested, access would be limited. Expensive option would be to convert the north field into a runway, which would solve several problems, but I'm not ready to tackle that mountain yet!
2. We probably do equal launches from both ends - and prefer aerotow launches on 36 for convenience and noise, even accepting a few knots of tailwind (in fact, we usually land our Pawnees downwind on 18 when able as it speeds up ops and is counterintuitively safer (!) when launching on 36). Winch launches on 18 would be limited to a max of 2600' pullout for the foreseeable future. A truck-mounted winch should have no problem launching from the north end of field next to I-70, giving pretty close to 4000'. Glider landings are usually on the center of the grass field (towplanes on the east "marked" landing strip), so staging would take time regardless of launch type. With a club fleet of 4 two-seat trainers (K-21s, G-103, K-13) and 4 single seat (G-102s and Astir CSs), plus 12 private ships, all CG hook equipped, I think we could keep a winch busy pretty easily (thinking of a 2-drum at least).
3. Typical of most US clubs (in my experience, at least) there is very little knowledge at SLSA about winch launching. I'm fortunate to have learned winch launching early on in Germany at a glider club located on Wittmund AB (home of JG-71 Richtofen at the time) in Ka-4, K-7, and solo in K-8s, then more recently took advantage of Karl Striedieck's incredible course at Eagle Field to get my sign off (and get flung onto the ridge in my LS6 behind his monster truck!). Been trying to get others to try it, but they all prefer being dragged around by a Pawnee (mind, you, I'm perfectly happy to do the dragging - l love Pawnees!) and think winches are a dangerous socialist plot of some kind. But seriously, I really think it is the future...possibly the only viable future for affordable and "sustainable" soaring.
Cheers!
Old June 12th 21, 02:00 PM posted to rec.aviation.soaring
George Haeh
One may find that the real estate acquisition for a 4,000' + runway to get a decent winch launch height is more expensive than a Pawnee.
Be careful with trailers from South Carolina as people there don't need to plate them, including glider trailers.
Highway patrols outside SC may not be accommodating, but the Illinois fellow I bought my glider from had been driving around for some years on a SC souvenir plate that the first owner had put on.
Old June 14th 21, 10:41 PM posted to rec.aviation.soaring
kirk.stant
Two things: We already own the property, and you don't need a 4000' runway, just 4000' clear for the cable (as long as you only care about launching one way - to the North, in our case). If we wanted 4000' to the south, we would have to extend our runway to the North, enough to move and launch gliders; no impossible but not free.
Kirk
Sandhill Soaring Club Winch Launch Training & Endorsements Christopher Schrader[_2_] Soaring 2 July 27th 20 10:12 PM
Ground Launch Training - Winch and Auto Jim S Soaring 16 February 28th 20 03:40 PM
Progress on updating training gliders and new winch operations? son_of_flubber Soaring 7 February 14th 13 08:33 AM
Some dudes and their home made winch............ Marc Soaring 3 January 26th 12 10:28 PM
Winch training in northeast USA ? toad Soaring 1 October 11th 05 11:44 AM
