Is the Mooney clock opening 2.25 inches?
Old June 8th 05, 04:29 PM
Dave Butler
Default Is the Mooney clock opening 2.25 inches?
Maybe someone can save me a trip to the airport to measure.
Specifically, looking to mount a Davtron 800 clock, will it fit?
While I'm at it, is there a convenient way to wire the clock for continuous
power when the master is off, or do I need the "B" model clock with the built-in
alkaline battery clip? I know the cabin overhead light is powered with the
master off.
M20J, in case it matters.
Thanks.
Dave
Old June 8th 05, 06:53 PM
Paul kgyy
I can't answer your question about size, but when I had a no-battery
clock installed in my Arrow, the shop had to run a fused lead directly
from the battery to power it.
Old June 8th 05, 11:17 PM
master off.
There are a lot more airplanes out there running around with duracell
(eveready, whathaveyou) powered Davtrons than what you might think.
I can look out the window and see four mid-size corporate jets that
have one on either side of the panel.
BTW, the batteries usually last 3-4 years...
TC
Mooney M20 K on Grass ? Andrew Boyd Owning 0 August 13th 04 03:00 PM
