Mechanical tach failure?
Old November 3rd 04, 10:23 PM
Rich S.
Default Mechanical tach failure?
So, I was flying back home, happily burping all the shellfish I ate at the
Shelton Oysterfest, when my engine started speeding up. Well, it didn't
really - but my tach said it did. Without touching the throttle, I went from
2400 rpm up to 3400. Funny, my airspeed didn't change.
It looks like my sturdy, simple mechanical tach (bought used at OSH) has
gone South on me. I pulled it out and removed the case. Everything inside
looks great. It is cable driven through a magnetic coupling just like a car
speedo. The needle has a return spring wound in a coil like a clock spring.
I assume the calibration is done by setting the needle on its shaft in a
position relative to the return spring, so a given rpm matches the needle
position on the dial.
I thought I would discover a broken return spring, but it looks okay.
Turning the drive with an 1100 rpm electric drill shows ~2500 on the dial.
If I allow the needle to bypass the stop pin and add an extra full turn of
tension on the return spring, the tach shows the drill turning ~400. It
looks like the needle has slipped on the shaft releasing about a half-turn
of spring tension. Either that or
A. the spring has developed a weak spot or
B. the other end of the spring has come unsoldered from the frame.
I don't think it's "B" because the entire spring would be unwound. Visual
examination of the spring doesn't show any defects.
Any ideas?
Rich "May as well take it apart - it don't work" S.
Ramifications of Cherokee Trim Jackcrew Failure Bob Chilcoat Home Built 23 June 9th 04 03:48 AM
Tail flapper failure Veeduber Home Built 2 May 22nd 04 07:52 AM
Single-Seat Accident Records (Was BD-5B) Ron Wanttaja Home Built 41 November 20th 03 06:39 AM
Interesting Flybaby wing failure analysis... Richard Lamb Home Built 3 August 27th 03 06:21 PM
Hinges under stress - mechanical engineering type question Corrie Home Built 21 August 6th 03 09:49 AM
