money
Old June 16th 05, 05:16 AM
Codeman
Default money
MAKE FAST MONEY
$6 to $6,000 EASY!!!!
Article:
How to make money fast with only 6 DOLLARS!!!!!!!!! THIS REALLY CAN
MAKE YOU EASY MONEY!! IT WORKS!!! A little while back, I was browsing
through newsgroups, just like you are now, and came across an article
similar to this that said you could make thousands of dollars within
weeks with only an initial investment of $6.00! So I thought," Yeah,
right, this must be a scam", but like most of us, but I was curious, so
I kept reading. Anyway, it said that you send $1.00 to each of the 6
names and address stated in the article. You then place your own name
and address in the bottom of the list at #6, and post the article in at
least 200 newsgroups. (There are thousands) No catch, that was it. So
after thinking it over, and talking to a few people first, I thought
about trying it. I figured what have I got to lose except 6 stamps and
$6.00, right? Like most of us I was a little skeptical and a little
worried about the legal aspects of it all. So I checked it out with the
U.S. Post Office (1-800-725-2161) and they confirmed that it is indeed
legal! Then I invested the measly $6.00.............plus postage. Well
GUESS WHAT!!... within 7 days, I started getting money in the mail! I
was shocked! I figured it would end soon, and didn't give it another
thought. But the money just kept coming in. In my first week, I made
about $25.00. By the end of the second week I had made a total of over
$1,000.00!!!!!! In the third week I had over $10,000.00 and it's still
growing. This is now my fourth week and I have made a total of just
over $42,000.00 and it's still coming in rapidly....... It's certainly
worth $6.00, and 6 stamps, I have spent more than that on the lottery!!
PLEASE NOTE: Follow these instructions exactly and $50,000 or more can
be yours in only 20-60 days!
Let me tell you how this works and most importantly, why it
works....also, make sure you print a copy of this article NOW, so you
can get the information off of it as you need it. The process is very
simple and consists of 3 easy steps: STEP 1: Get 6 separate pieces of
paper and write the following on each piece of paper "PLEASE PUT ME ON
YOUR MAILING LIST." Now get 6 US $1.00 bills (or equivalent in your
local currency) and place ONE inside EACH of the 6 pieces of paper so
the bill will not be seen through the envelope to prevent thievery.
Next, place one paper in each of the 6 envelopes and seal them. You
should now have 6 sealed envelopes, each with a piece of paper stating
the above phrase, your name and address, and a $1.00 bill. What you are
doing is creating a service by this. THIS IS ABSOLUTELY LEGAL! Mail the
6 envelopes to the following addresses:
#1) Jon, 11 snowhill meadows Foley, MO 36617.
#2) Matt, 120 Quail Lane Monticello, WI 53570.
#3) Jody, N6843 Pratt Rd. Monticello, WI 53570.
#4) Ryan, 5010 84th st S.W. Apt. C34 Mukilteo, WA 98275
#5) Eevon, 2 Woodley Rd. Buffalo, NY 14215
#6) Cody Naramore, 2900 Mansion Dr. Apt. 218 Kansas City, MO 64055
STEP 2: Now take the #1 name off the list that you see above, move the
other names up (6 becomes 5, 5 becomes 4, etc...) and add YOUR Name as
number 6 on the list. STEP 3: Change anything you need to, but try to
keep this article as close to original as possible. Now, post your
amended article to at least 200 newsgroups. (I think there is close to
24,000 groups) All you need is 200, but remember, the more you post,
the more money you make! Don't know HOW to post in the newsgroups? Well
do exactly the following: ---- DIRECTIONS - HOW TO POST TO
NEWSGROUPS------------ Step 1. You do not need to re-type this entire
letter to do your own posting. Simply put your cursor at the beginning
of this letter and click and hold down your mouse button. While
continuing to hold down the mouse button, drag your cursor to the
bottom of this document and over to just after the last character, and
release the mouse button. At this point the entire letter should be
highlighted. Then, from the 'edit' pull down menu at the top of your
screen select 'copy'. This will copy the entire letter into the
computers memory. Step 2. Open a blank 'notepad' file and place your
cursor at the top of the blank page. From the 'edit' pull down menu
select 'paste'. This will paste a copy of the letter into notepad so
that you can add your name to the list. Remember to eliminate the #1
position, move everyone up a spot (re-number everyone elses positions),
and add yourself in as #6. Step 3. Save your new notepad file as a .txt
file. If you want to do your postings in different sittings, you'll
always have this file to go back to. ----------FOR NETSCAPE
USERS:----------------------- Step 4. Within the Netscape program, go
to the pull-down window entitled 'Window' select 'NetscapeNews'. Then
from the pull down menu 'Options', select 'Show all Newsgroups'. After
a few moments a list of all the newsgroups on your server will show up
(try searching for a list of all newsgroups also.) Click on any
newsgroup you desire. From within this newsgroup, click on the 'TO
NEWS' button, which should be in the top left corner of the newsgroups
page. This will bring up a message box. Step 5. Fill in the Subject.
This will be the header that everyone sees as they scroll through the
list of postings in a particular group. Step 6. Highlight the entire
contents of your .txt file and copy them using the same technique as
before. Go back to the newsgroup 'TO NEWS' posting you are creating and
paste the letter into the body of your posting. Step 7. Hit the 'Send'
Button in the upper left corner. You're done with your first one!
Congratulations... ----------------INTERNET EXPLORER USERS:------- Step
4. Go to newsgroups and select 'Post an Article'.(You can search for a
directory of all newsgroups) Step 5. Fill in the subject. Step 6. Same
as #6 above Step 7. Hit the 'Post' button. ----THAT'S IT! All you have
to do is jump to different newsgroups and post away, after you get the
hang of it, it will take about 30 seconds for each newsgroup!
**REMEMBER, THE MORE NEWSGROUPS YOU POST IN, THE MORE MONEY YOU WILL
MAKE!! BUT YOU HAVE TO POST A MINIMUM OF 200** That's it! You will
begin reciving money from around the world within days! You may
eventually want to rent a P.O.Box due to the large amount of mail you
will receive. If you wish to stay anonymous, you can invent a name to
use, as long as the postman will deliver it. **JUST MAKE SURE ALL THE
ADDRESSES ARE CORRECT.** Now the WHY part: Out of 200 postings, say I
receive only 5 replies (a very low example). So then I made $5.00 with
my name at #6 on the letter. Now, each of the 5 persons who just sent
me $1.00 make the MINIMUM 200 postings, each with my name at #5 and
only 5 persons respond to each of the original 5, that is another
$25.00 for me, now those 25 each make 200 MINIMUM posts with my name at
#4 and only 5 replies each, I will bring in an additional $125.00! Now,
those 125 persons turn around and post the MINIMUM 200 with my name at
#3 and only receive 5 replies each, I will make an additional $626.00!
OK, now here is the fun part, each of those 625 persons post a MINIMUM
200 letters with my name at #2 and they each only receive 5 replies,
that just made me $3,125.00!!! Those 3,125 persons will all deliver
this message to 200 newsgroups with my name at #1 and if still 5
persons per 200 newsgroups react I will receive $15,625,00! With a
original investment of only $6.00! AMAZING! And as I said 5 responses
is actually VERY LOW! Average is probable 20 to 30! So lets put those
figures at just 15 responses per person. Here is what you will make: at
#6 $15.00 at #5 $225.00 at #4 $3,375.00 at #3 $50,625.00 at #2
$759,375.00 at #1 $11,390,625.00 When your name is no longer on the
list, you just take the latest posting in the newsgroups, and send out
another $6.00 to names on the list, putting your name at number 6
again. And start posting again. The thing to remember is, do you
realize that thousands of people all over the world are joining the
internet and reading these articles everyday, JUST LIKE YOU are now!!
So can you afford $6.00 and see if it really works?? I think so...
People have said, "what if the plan is played out and no one sends you
the money? So what! What are the chances of that happening when there
are tons of new honest users and new honest people who are joining the
internet and newsgroups everyday and are willing to give it a try?
Estimates are at 20,000 to 50,000 new users, every day, with thousands
of those joining the actual internet. Remember, play FAIRLY and
HONESTLY and this will work.
IMPORTANT: This is not a rip off; it is not indecent; it is not
illegal; and it is virtually no risk it really works!!!! If all of the
following instructions are adhered to, you will receive extraordinary
dividends. PLEASE NOTE: Please follow these directions EXACTLY, and
$50,000 or more can be yours in 20 to 60 days. This program remains
successful because of the honesty and integrity of the participants.
Please continue its success by carefully adhering to the instructions.
You will now become part of the Mail Order business. In this business
your product is not solid and tangible, it's a service. You are in the
business of developing Mailing Lists. Many large corporations are happy
to pay big bucks for quality lists. However, the CASH made from the
mailing lists is secondary to the income which is made from people like
you and me asking to be included in that list.
Old June 16th 05, 11:21 AM
Vaughn
"Codeman" wrote in message
MAKE FAST MONEY
$6
Send money to a spammer? Yea right!
Old June 16th 05, 02:59 PM
abripl
Why don't you try working for a living? You'll feel better.
Quick, easy program to earn extra money. [email protected] Owning 1 January 28th 05 03:39 PM
So I invested my US$6°°.....GUESS WHAT!!!... less than ten days later, I received money [email protected] Owning 1 January 16th 05 06:48 AM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
Start receiving MONEY with this simple system. Guaranteed. Mr Anderson Aviation Marketplace 0 February 2nd 04 11:55 PM
