PIREP: WxWorx w/Bluetooth
Old June 20th 05, 12:44 AM
Nathan Young
Default PIREP: WxWorx w/Bluetooth
As some of you know, I run a Fujitsu ST4121 tablet PC in my plane, and
use it to display moving map software as well as XM/WxWorx radar.
I had grown tired of cables dangling from the tablet, so when WxWorx
offered a Bluetooth upgrade to their receiver, I went for it.
To support the Bluetooth upgrade I also order a Garmin GPS10 Bluetooth
GPS receiver and a Belkin PCMCIA carrier/compact Flash card to add BT
to the tablet.
Before ordering I was a bit concerned about how BT would integrate and
pull the data into the applications. Fortunately, Bluetooth has a
serial port emulation mode, so the bluetooth devices appear as COM
ports to the applications running on the PC, which is exactly how the
GPS and USB based WxWorx receivers operated.
As a communications path is established to the BT device, the Belkin
driver assigns a virtual COM port number to the device. In my case,
these happen to start at COM8. So as long as I always turn the GPS on
first, it will be assigned COM8. The WxWorx receiver is then assigned
COM9 as I turn it on 2nd.
WxWorx's XMLink software works perfectly with the BT connection, as
does my moving map SW.
My tablet PC has a 3+ hr battery life, so I can actually go completely
wireless to the tablet on shorter flights.
So far it appears to be a worthwhile investment... Next step - I need
to decide the best way to eliminate the massive array of cigarette
plugs in the plane.
-Nathan
Old June 20th 05, 02:09 AM
Stephen McNaught
The GPS10 has, IMO, some pretty strong magnets. They're designed to hold
the unit on to the hood of your car at speeds (it's also water resistant). I
removed the magnets, because it "can" affect the compass, (removal of which
obviously voids any warranty), by "gently" prying the split around the sides
apart. The two half's are held together by, what appears to be, a silicone
based glue. The three magnets inside are held in place by a harder glue,
like epoxy. I think the GPS10 is a very good Bluetooth sensor.
Also, if you take out the magnets, you'll see what the rechargable battery
looks like, in case you every have to replace it yourself, in a couple
years. But, it would void the warranty.
"Nathan Young" wrote in message
to the tablet.
Old June 20th 05, 05:43 AM
Nathan Young
On Sun, 19 Jun 2005 20:09:09 -0400, "Stephen McNaught"
Excellent tip, thanks!
Old June 20th 05, 08:31 PM
Dan Luke
Thanks for the pirep, Nathan.
Dan
C-172RG at BFM
Old June 21st 05, 07:47 PM
S Narayan
I have played around with the GPS10 location to make sure the compass swing
is negligible. Since I use it in my car as well, I am reluctant for now to
remove the magnets. Thanks for the info on the magnet removal.
"Stephen McNaught" wrote in message
I
which
sides
battery
to the tablet.
Old June 21st 05, 08:50 PM
Stephen McNaught
I've found that I get pretty good satellite reception from the dash of the
car. Although I think the magnets are strong enough, I still had a fear of
it flying off and impaling itself in the windshield of the car behind me.
You know that car with the funny blue lights, trying to keep up with me. ;-)
Probably no need to worry, still..., I did.
- Steve
"S Narayan" wrote in message
news:1119376074.2e8790826c82bab94af0dc3f41f3f805@t eranews...
swing
WxWorx flight test Dan Luke Instrument Flight Rules 22 October 12th 03 03:54 PM
WxWorx continued Dan Luke Instrument Flight Rules 8 September 27th 03 02:05 PM
WxWorx continued Dan Luke Piloting 8 September 27th 03 02:05 PM
(long) WxWorx arrived...(and NavAero) Lenny Sawyer Instrument Flight Rules 1 September 10th 03 01:39 AM
(long) WxWorx arrived...(and NavAero) Lenny Sawyer Piloting 1 September 10th 03 01:39 AM
