Landing gear micro switchs
Old June 28th 05, 01:34 AM
lardsoup
Default Landing gear micro switchs
Preflighting the Arrow I was taught to check the landing gear micro
switches. OK great. There they are. I even work the switch to feel that
it's making contact inside. I was Master Mechanic in the Air Force and
repaired the Autopilot systems on the SR-71 and U-2 so I know about
airplane systems and parts and all, but what exactly am I supposed to be
checking? That they aren't caked in mud? That they are there? I can't see
if the lights are working while I manipulate the switch so what's the deal?
None of the CFIs can give me an answer besides, "check the landing gear
switches". I'll keep "checking the switches" on every pre-flight but can
someone provide a more detailed explanation on what I should be checking
for?
Thanks.
Lsoup
Old June 28th 05, 02:22 AM
john smith
for?
That's pretty much it.
Check that they are not stuck and that that lights/horn sound when you
open/close the contact.
Old June 28th 05, 03:00 AM
Mike Granby
For the lights/horn to sound, you'll need to have the master on. Not
sure I'd want to be playing with the landing gear and its switches with
power to the system. Imagine there's a problem with the gear control
circuit, and you "test" the squat switch, causing the gear to start to
retract. Could spoil your day...........
Old June 28th 05, 04:28 AM
Seth Masia
I don't know how to check the electrical operation of the microswitches, but
they're critical. It's not just the squat switches, but if your Arrow, like
my Comanche, has gear-up switches (to turn off the gear motor once the
wheels are stowed), they'd better work. If these gear-up switches don't turn
off the juice to the motor, it keeps drawing power -- which can burn out the
motor and/or discharge the battery in flight. I had this problem and it was
expensive: I replaced two gear motors and experienced two inflight
electrical system failures before we finally traced the problem to a single
bad microswitch. Talk to your mechanic about this and do a continuity test
at annual time.
Seth
N8100R
"Mike Granby" wrote in message
ps.com...
Old June 28th 05, 12:17 PM
Mike Granby
Pipers terminate the gear-up cycle by means of a pressure switch. The
gear-up switches are for indication only.
Old June 28th 05, 12:26 PM
William Snow
"lardsoup" wrote in message
see
deal?
for?
There ARE a couple of things that need to be checked.
First you need to make sure that the switches are aligned with the J hooks
on the main gear. Make sure the wires are not disconnected, and that there
is no corrosion in the vicinity of the connections. This is to prevent
uneven wear of the switch and possible early malfunction.
Second ,there are about nine switches total in the Arrow system. A check of
all of them is impossible since a few are out of sight.
The main squat switch is in left gear wheel well, mostly hidden but visible
in a couple of positions. Make sure it is free of corrosion, has wires
attached and is in the open position while on the ground, gear down.
Principle checks are alignment, wires connected, no corrosion, mounted
tightly.
Hope that helps
W. L. Snow CP, IA, ASEL
N5381F
Old June 28th 05, 02:39 PM
Paul kgyy
If it's an older model Arrow, check the wiring at the switch attach
point. The plastic wire housing gets brittle with age, and I
encountered a "2-green" situation in flight a while back when the
inability to flex caused a wire to break off at the switch.
Old June 29th 05, 01:09 PM
lardsoup
Thanks again to all who posted.
Lsoup
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 09:14 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
