wrote in message news:
G-LOC= "G force induced loss of consciousness" There's a fairly linear relationship between time spent at positive Gs and loss of consciousness for any individual. (Vector pointing straight down or parallel to the spine.) The graphs at the site linked below are far from linear! At any particular g load. As another example, I just realized my kids pull more than 2 G's every day on the swings (although a sub-second timeframe may not meet my definition of "sustained" :-). Five seconds is "sustained". OK. What happens at timescales significantly above 5s? Sleep. http://aeromedical.org/Articles/g-loc.html What is the baseline in the graph at the site? 0g or 1g? Note that level flight is 1g, of course. 1G It is mentioned that G-LOC has happened with as little as 2g. This would mean 60 degree banking turn. I think even airliners allow more - like, IIRC, Airbus flight envelope protection extends to 67 degrees. What is the corresponding +g load? About 3Gs. And I suspect that this G-LOC at +3, +4, +2 concern pilots sitting and staying seated in a pilot seat. Thighs horizontal, buttocks supported, back somewhat supported (reclining enough not to slump forward or aside on G-LOC). Right? At which g would one suffer G-LOC while standing up in an aisle? Walking along aisle? At which g can one feel safe to get up suddenly and put a heavy item in an overhead bin? Go and use a lavatory? It really depends on the individual. Almost anyone can tolerate 2Gs for a sustained period but moving about or lifting anything heavy would be difficult. I think that the cutoff point for the average person (sustained) is around 3.5Gs. What would be the effect of 2g sustained for 5 minutes? Or for 5 hours? I mean, I suppose circling at 60 degrees bank angle would be somewhat wasteful of fuel, but the airliners do manage 18-19 hours level flight nonstop and without tanking... Over 30 degrees of bank angle is unusual for an airliner. If you're not used to it, 60 degrees looks and feels like 90. Can one sleep (and get up again) at 2g? That's an interesting question. xposted for an answer. moo |
On Thu, 30 Jun 2005 11:52:33 -0400, "Happy Dog"
wrote: It really depends on the individual. Almost anyone can tolerate 2Gs for a sustained period but moving about or lifting anything heavy would be difficult. I think that the cutoff point for the average person (sustained) is around 3.5Gs. A young pilot in good physical condition ought to tolerate 5 Gs. With specialized training, as was given to Spitfire pilots in WWII, 9 Gs is possible. That's strapped in, of course, and in the case of the Spitfire pilot, he's grunting and straining for all he's worth. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
It really depends on the individual. Almost anyone can tolerate 2Gs for a sustained period but moving about or lifting anything heavy would be difficult. I think that the cutoff point for the average person (sustained) is around 3.5Gs. Cub Driver wrote: A young pilot in good physical condition ought to tolerate 5 Gs. With specialized training, as was given to Spitfire pilots in WWII, 9 Gs is possible. Gotta disagree with you Dan. happydog has it right. G-tolerance is something you develope, you cannot just strain at the right time and stay awake. Back when I was younger and in excellent physical condition, I did aerobatic training. Sustained or repeated G's will quickly drain you with each successive maneuver. I never did enough to go to sleep, but repeated 4-5 G maneuver's caused be to gray out for several seconds (the instructor was then in control of the aircraft). |
time and stay awake. Back when I was younger and in excellent physical condition, I did aerobatic training. Sustained or repeated G's will quickly drain you with each successive maneuver. I never did enough to go to sleep, but repeated 4-5 G maneuver's caused be to gray out for several seconds (the instructor was then in control of the aircraft). How do pilots like Sean Tucker and Patty Wagstaff sustain G loads for their entire routine? I know Tucker "takes a break" half-way through his, doing a long climb out while he catches his breath (or clears his head), but, still -- they seem to be under incredibly high Gs for a large portion of their 15 minute routines. I've only had one aerobatic flight, pulling a maximum of 4 Gs that lasted maybe ten seconds, and even that was a pretty good workout. I can't imagine doing that -- and far more -- every few seconds for 15 minutes! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Cub Driver wrote: On Thu, 30 Jun 2005 11:52:33 -0400, "Happy Dog" wrote: It really depends on the individual. Almost anyone can tolerate 2Gs for a sustained period but moving about or lifting anything heavy would be difficult. I think that the cutoff point for the average person (sustained) is around 3.5Gs. A young pilot in good physical condition ought to tolerate 5 Gs. With specialized training, as was given to Spitfire pilots in WWII, 9 Gs is possible. Most healthy military pilot sorts (completely healthy and fit) have a RESTING G tolerance of 4-5G, that is without any muscular contraction or strain maneuver. Leg and abdominal muscle straining typically adds another 0.5-1.0G on top of this resting tolerance, and then adding the G-Strain maneuver (pushing against a closed glottis to increased intrathoracic pressure) adds above that. I recently spun in the centrifuge at Brooks AFB and started to gray out at around 4.2-4.5, and then had to begin the strain (lightly at first of course) at around 5.3-5.4 G. I was able to go to just over 9G without blacking out or G-LOCing which was fun (in hindsight) but it REALLY is a lot of work. Tolerance varies widely, with some graying out at 3.5 and some going to 7+G with no strain whatsoever. Good lower limb and abdominal muscle strength helps peak tolerance, and good cardiovascular fitness seems to help with repetitive Gs. -Chris Schmelzer, MD, Captain Medical Corp, Flight Surgeon 110th Fighter Wing, Michigan ANG -- Chris Schmelzer, MD Capt, 110th Fighter Michigan ANG University of Michigan Hospitals Ann Arbor, MI |
"Michael Ash" wrote in
In rec.arts.sf.science wrote: Douglas Bader lost both legs in a pre-WWII flying accident, and re-enlisted at the start of the war. He claimed he could pull more g's in his Spitfire, 'cause there was no place for the blood to pool! Not to change the subject, but I'm curious as to how a legless pilot fares in combat conditions. Rudder control is pretty essential when flying, particularly in powerful propellor-driven planes like WWII-era fighters, and normally that's all done with the feet. Did he have something special rigged so that he could operate the rudders with his hands? Wondered about that too. I don't know that you could do a safe takeoff without rudder in a Spitfire. moo |
Chris Schmelzer wrote:
Good lower limb and abdominal muscle strength helps peak tolerance, and good cardiovascular fitness seems to help with repetitive Gs. I heard a report that women tended to tolerate high gee forces better than women because they tend to be shorter and have different centers of gravity. Is that still thought to be the case? -- Erik Max Francis && && http://www.alcyone.com/max/ San Jose, CA, USA && 37 20 N 121 53 W && AIM erikmaxfrancis Heaven ne'er helps the man who will not act. -- Sophocles |
Happy Dog wrote:
"Michael Ash" wrote in In rec.arts.sf.science wrote: Douglas Bader lost both legs in a pre-WWII flying accident, and re-enlisted at the start of the war. He claimed he could pull more g's in his Spitfire, 'cause there was no place for the blood to pool! Not to change the subject, but I'm curious as to how a legless pilot fares in combat conditions. Rudder control is pretty essential when flying, particularly in powerful propellor-driven planes like WWII-era fighters, and normally that's all done with the feet. Did he have something special rigged so that he could operate the rudders with his hands? Wondered about that too. I don't know that you could do a safe takeoff without rudder in a Spitfire. Bader lost one leg below the knee and the other just above the knee. With the prosthetics available, he could control the rudder with his hips. |
"Jay Honeck" wrote in message
news:3abxe.119054$xm3.82811@attbi_s21... G-tolerance is something you develope, you cannot just strain at the right time and stay awake. Back when I was younger and in excellent physical condition, I did aerobatic training. Sustained or repeated G's will quickly drain you with each successive maneuver. I never did enough to go to sleep, but repeated 4-5 G maneuver's caused be to gray out for several seconds (the instructor was then in control of the aircraft). Grey out is something you learn to tolerate. Although it's flirting with the edge of G-LOC, it's safe to do once you've learned to predict the onset of G-LOC and learned your personal limits. When I started training, I once blacked out, in part, from an improper straining maneuver. The instructor just let me ride it out. Waking up was like coming out of a dream. It took over ten seconds from lights out to initiating recovery. G-LOC is not to be ****ed with. How do pilots like Sean Tucker and Patty Wagstaff sustain G loads for their entire routine? Practice, practice, practice. That, and, as you noted, the routines are designed to allow breaks in G loads. moo |
| Thread Tools | |
| Display Modes | |
| F/A-18 external stores load | [email protected] | Naval Aviation | 3 | December 27th 04 08:59 AM |
| Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 05:03 AM |
| Stupid question about flight testing and "the envelope" | Scott Ferrin | Military Aviation | 12 | January 7th 04 04:56 AM |
| Va: maneuvering speed ad nauseam | Koopas Ly | Piloting | 14 | November 29th 03 06:07 PM |
| Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 07:46 PM |
