My understanding is that one should lean using the "hotest" cylinder as
the reference point for peak EGT. My question is on the interpretation of "hotest." Does that mean the cylinder that reaches the hotest EGTs or CHTs? On mine, they are inversely related (the hotest EGTs are on the coldest CHT cylinders). -Sami N2057M, Piper Turbo Arrow III |
The cylinder that reaches peak EGT first (not necessarily the highest
EGT temp). In other words, the EGT that starts to cool first as you are leaning. If you have a good engine monitor, it will compute this for you and flash the EGT on the monitor. -Robert |
O.,
Does that mean the cylinder that reaches the hotest EGTs or CHTs? On mine, they are inversely related (the hotest EGTs are on the coldest CHT cylinders). Absolute temperatures are not important. The key issue is the first cylinder to reach peak EGT. If the peak EGT for that cylinder happens to be 200 F lower than the peak EGT of the next cylinder, that's not important for the leaning process (although you might want to check the engine baffling). -- Thomas Borchert (EDDH) |
![]() O. Sami Saydjari wrote: My understanding is that one should lean using the "hotest" cylinder as the reference point for peak EGT. My question is on the interpretation of "hotest." As others have stated in other words, the proper procedure is not to lean to the "hottest" cylinder, but to lean to the "leanest" cylinder. IOW, look for the first one to peak, and lean to that one. The fact that the leanest cylinder may not be the one with the highest EGT is not a consideration for leaning. Note also that the leanest cylinder will vary over time. It won't always be the same cylinder on every flight. |
Path of an airplane in a 1G roll | Chris W | Piloting | 47 | July 4th 05 10:53 PM |
Path of an airplane in a 1G roll | Chris W | Aerobatics | 20 | June 29th 05 09:35 AM |
Path of an airplane in a 1G roll | Chris W | Home Built | 22 | June 29th 05 09:35 AM |
Dehydration | [email protected] | Soaring | 23 | March 30th 05 02:59 PM |
Start Anywhere Cylinder (SSA rules proposal) | Mark Navarre | Soaring | 15 | September 25th 03 01:13 PM |
