electric gyro options
Old July 13th 05, 08:12 PM
Jose
Default electric gyro options
Our club is considering installing an electric AI as a backup after a
vacuum gyro failure not involving the suction system. We have three
cherokees and are looking at three alternatives (we'd like the same one
in all the aircraft):
http://www.lifesavergyro.com/purchasing_home.html
http://www.sportys.com/acb/showdetl....roduct_id=7439
(ignore the request for password)
http://www.gyrohouse.com/catalog/items/item551.html
The first is a $4000 unit, the other two are less than half that.
Anybody out there have any experience with these units, or the companies
that make them?
Jose
Nothing takes longer than a shortcut.
Old July 14th 05, 01:03 AM
vincent p. norris
I know nothing about gyros, but don't assumme that the more expensive
one is necessarily better. It could even be worse. You can't tell
anythng from the price. Inferior goods are often priced very high, to
convey to naive consumers the notion it is better.
Have you checked Aviation Consumer?
vince norris
Old July 14th 05, 01:14 AM
Michelle P
www.pcflightsystems.com
Satisfied customer
Michelle
one in all the aircraft):
companies that make them?
Jose
Old July 14th 05, 01:31 AM
Nathan Young
On Wed, 13 Jul 2005 19:12:16 GMT, Jose
that make them?
No experience with any of the electric gyros, but the 1st one contains
a battery backup in case the electric source dies. Since this would
be a backup to your vacuum ADI, I think that's overkill. I would not
pay $2000 extra for it.
Old July 14th 05, 04:06 AM
Andrew Gideon
a battery backup in case the electric source dies.Â*Â*SinceÂ*thisÂ*would
be a backup to your vacuum ADI, I think that's overkill.Â*Â*IÂ*wouldÂ*not
The battery is an option. The price is a little below $4K w/o, and a little
above with. Why one would get this w/o the battery, though, I'm not sure.
Sure, a failure of both electric and vacuum isn't likely. But the battery
option isn't that much more money.
Look at the MTBF. I think that the Mid-Continental has one that's longer
than most at 7500 hours. However, also check the warranties. I seem to
recall that there was a unit that seemed less robust than the MC unit but
which had a longer warranty.
- Andrew
Old July 14th 05, 06:02 AM
max
We've had the last one you linked
(http://www.gyrohouse.com/catalog/items/item551.html
) in a club 182. It's got about 850hrs on it so far with no problems at
all. Although we haven't needed to use it in a vacum failure yet it
makes me feel fantastic in the clouds to "see double".
Also I had an alternator failure when IMC once and the little red flag
that popped out on this AI was what made me first notice the failure
(this 182 has no low voltage light- just an ammeter).
max
We've had the last one you linked (
at all. Although we haven't needed to use it in a vacum failure yet it
Old July 14th 05, 06:14 AM
max
(http://www.gyrohouse.com/catalog/items/item551.html ) in a club 182.
It's got about 850hrs on it so far with no problems at all. Although we
haven't needed to use it in a vacum failure yet it makes me feel
The other nice thing about out installation is that the second AI is in
the ol VOR 1 hole, which puts it just two holes away from the primary
AI. I think having the backup as plainly visible as possible is
important if it's backing up the vacum AI.
Old July 14th 05, 06:17 AM
max
The other nice thing about our installation is that the second AI is in
the old VOR 1 hole, which puts it just two holes away from the primary
AI. I think having it as plainly visible as possible is important if
Old July 14th 05, 03:23 PM
paul kgyy
There were some posts a couple of years ago about short lifespans on
the RC Allen units. The Midcontinent unit has a slower rotational
speed and longer expected life.
I haven't heard anything yet about the one from Sporty's.
I'd make the decision based on how long you expect to run the airplane.
How long an Electric Horizon GYRO can be used? Luo Zheng Home Built 1 June 27th 04 04:12 AM
How long an Electric Horizon GYRO can be used? Luo Zheng Products 0 June 27th 04 03:28 AM
How long an Electric Horizon GYRO was used? Luo Zheng Home Built 0 June 26th 04 02:55 AM
Gyros - Electric vs Vacuum? Bill Denton Piloting 1 April 18th 04 05:56 AM
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 15th 04 11:30 PM
