Mogas Deletions
Old July 14th 05, 07:29 PM
RST Engineering
Default Mogas Deletions
Delete Morgan County UT and Chreighton NE from the mogas list.
Old July 14th 05, 09:03 PM
Steve Foley
Is there a "mogas list"?
I tried http://www.rst-engr.com/mogas but got a 'page not found'
"RST Engineering" wrote in message
Old July 14th 05, 10:43 PM
RST Engineering
No. Airnav.com lists both of them as having mogas.
"Steve Foley" wrote in message
news:hyzBe.2614$bw6.336@trndny03...
Old July 15th 05, 12:35 AM
Dave S
The folks out there who use mogas have cobbled together an ad-hoc list
of where to buy it from.. usually from first person reports on here.
Airnav lists what the airfields report to the FAA and what users report
to airnav.. but "saying you sell mogas" and actually "SELLING mogas" are
two different things.
I haven't kept up with "the list" too much since the project plane isnt
flying yet. Once it does, I will be compiling my list for reference, but
honestly, I will probably just use blue stuff when fueling out.
Dave
Old July 15th 05, 03:36 AM
Darrel Toepfer
Shame they don't make a note of MOGAS availability, this is another good
resource, info looks formated much like that in GoldenEagle Flightprep:
http://100ll.com/showfbo.php?fbo_id=2924
(K42U) Morgan County Airport
Morgan, UT
Phone: 801-876-3156
Fax: 801-876-3156
Hours of Operation
Fuel Information
http://100ll.com/showfbo.php?fbo_id=3414
(KTVY)Tooele Valley Airport
Tooele, UT
Phone: 801/575-2401
http://www.saltlakecityairport.com
Hours of Operation Open 24/7
Fuel Information(as of 2005-07-12 08:55:12)
Jet-A Full Service: $3.99/Gal
100LL Full Service: $3.92/Gal
Ground Transportation
Courtesy/Crew Car
Provisions/Food Available
Restaurant within 1M
Credit Cards Accepted
You wouldn't fly with a couple empty 5 gallon containers huh? That opens
up possibilities when you use a gas station mapping program. FBO's
probably wouldn't appreciate borrowing the courtesy car to fill them
though... G
Old July 15th 05, 04:52 AM
Doug
Platte Valley Colorado, 18V, consistently has the lowest fuel prices in
Colorado. Their mogas is 91 octane before the additives are added.
Current fuel prices (7/14/05) are
$2.50 for mogas and $2.65 for 100LL. Platte Valley is north of Denver
by about 20 miles.
Old July 17th 05, 09:51 PM
floater
The lack of mogas at most airports is proving to be a real problem for
me. 100LL fouls my spark plugs badly. Having a canard aircraft, I prefer
long runways. The few airports that have mogas seem to be small fields
with short runways. I'm ordering some TCP from Aircraft Spruce for an
upcoming long trip, in case I'm forced to use that evil leaded stuff.
Options I've looked at to get mogas:
1. Contact EAAers in the planned fuel stop area, to see if they can help
with re-fueling. Might mean several trips to a local gas station with
5 gallon cans. My Long-EZ is too small to carry 5 gallon cans onboard.
2. Contact companies that deliver fuel to farmers. I did this for McCook
NE, they wanted 200 gallon minimum, so that idea doesn't seem too
feasible. I also asked the FBO at McCook if they could obtain Mogas for
me - no go, even though they have extensive ag operations.
3. Get a fuel-transfer pump system that can transfer fuel from a car
fuel tank to the airplane, that runs on 12V from a cigarette lighter
plug or clips to the car battery terminals. There does not seem to be
such a thing, so I would have to build it. At least this could be small
and light enough to keep onboard the plane. Then you might have to
explain to the FBO that you are going to pump the gas out of the loaner
car into your airplane, then go into town to top off the car tank again!
Would probably have to make a couple trips as car tanks are not that
large either.
Any other ideas?
18V looks good, but as is typical of airports that have mogas, the
runway might be a little short for a canard at such a high density
altitude field.
by about 20 miles.
Old July 17th 05, 10:51 PM
LCT Paintball
3. Get a fuel-transfer pump system that can transfer fuel from a car fuel
tank to the airplane, that runs on 12V from a cigarette lighter plug or
They make some 12v pumps for the tanks farmers put in the back of their
trucks. I'll bet you could modify one of those.
Any other ideas?
Have you ever seen the calapsable 5 gallon water bladders that campers use?
Maybe you could find something like that for gasoline. Or, maybe you could
call a tow truck. Some of them carry gas. You might be able to talk them
into bringing you some.
Old July 17th 05, 11:25 PM
Marc J. Zeitlin
I did exactly this, but for a different reason. I bought a cheap 12V
fuel pump at the auto parts store, mounted it to a wooden platform with
an on-off switch, and put some long bits of tubing on either end. I
clip it to the plane/car's battery, and use it to transfer fuel from one
tank to the other on my COZY when I'm on the ground, working on the
plane. It could easily do what you ask, at about 2-3 gallons/min. or
so. IIRC, it cost me about $25, and is pretty small.
Marc J. Zeitlin
http://marc.zeitlin.home.comcast.net/
http://www.cozybuilders.org/
Copyright (c) 2005
Old July 17th 05, 11:28 PM
Ed Sullivan
On Sun, 17 Jul 2005 20:51:08 GMT, floater
What engine are you running? I found that switching to REM37BY plugs
helped a lot with the plug fouling. This was on an 0-235 also an 0-320
Ed Sullivan
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Home Built 82 May 19th 05 02:49 PM
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Owning 87 May 19th 05 02:49 PM
Mogas and Peltier effect anaconda Home Built 7 May 11th 05 08:03 PM
MOGAS availability database [email protected] Piloting 51 May 9th 05 12:02 AM
Mogas and microbial growth Economic Girly Man Owning 6 November 13th 04 09:14 AM
