canard flying boat
Old July 18th 05, 08:18 PM
Darrel Toepfer
Default canard flying boat
karel wrote:
has the canard concept ever been applied to a flying boat?
with pusher propellers?
if not, any good reasons?
KA
(just wondering)
(1911 Voisin)
http://www.fiddlersgreen.net/AC/airc.../info/info.htm
Old July 18th 05, 09:52 PM
I know someone who made a VW powered canard equipped amphibian.
Dunno if it was a pusher or a puller, I'll ask next EAA meeting.
IIUC, the plane flew well in the air but would not break free of
the water at less than 70 mph. Considering that until then, the
air rudder was ineffective and the water rudder became ineffective
around 40 - 45 mph that make takeoffs a bit hairy.
He said landing speed on the water was also around 70 mph, not
sure of the reason for that, surely his stall speed was lower.
That plane has been dismantled and the engine used for his current
non-canard amphibian project (tractor), now undergoing taxi tests.
AFAIK, no website.
FF
Old July 19th 05, 11:15 AM
yep ...
XTC amphibian
Also the Merganser (spelling ??) Circa late 70's. Not sure if it ever flew.
This is the VW design refered to by another post.
"karel" wrote in message
KA
(just wondering)
Old July 19th 05, 02:06 PM
.......... :-)) wrote:
yep ...
XTC amphibian
A couple of weeks ago I was talking with Mr Merganser (also unsure of
the spelling) at a fly-in. He said the earlier attempt flew
beautifully
in the air but landing it was too dangerous. I previously heard about
the problems taking off from the water second hand.
This rather clearly implies that it did in fact, fly. His present
amphibian project is not a canard design.
Don't canard designs have a reputation for requiring a smooth
landing strip (paved, dry lakebed, etc) in order to take off
in a reasonable distance? Supposedly this is because a bumpy field
interferes with the establishment of laminar flow over the canard.
Seems like you'd have the same problem taking off from water.
FF
Old July 19th 05, 10:54 PM
My distant relatives built several canard biplane pusher seaplanes
between 1911 and 1917. The used engines that they built themselves.
The planes were turned with their patented "Jib Sheet Rudder" which was
a surface the was mounted on the outside interplane struts between each
wing and pivoted to the outside to turn the plane. It was supposed to
have worked very well.
If you can find a copy of Jane's Planes from back then look for the
Boland Aeroplane and Motor Company. There is also a book called "Wings
of the Weird and Wonderful" that has a picture of the landplane
version.
Michele
KA
(just wondering)
Old July 19th 05, 11:57 PM
abripl
The Rutan style smaller wings canards you see today are designed for
aerodynamic efficiency and speed and not for load carrying capacity.
Some of the canard efficiency (and turbulence advantage) is that both
the canard and main wing is lifting, whereas in conventional aircraft
the tail is actually pushing down. The canard flies just like other
wings - obeys the same law of physics - but current canard wing designs
are for higher stall speeds to stall before the main wing, a flight
safety feature. That means the landing/takeoff speed is limited by the
relatively high stall speed of the small canard wing. Canard aircraft
are generally more CG sensitive and the canard stall speed is dependent
on the CG position - means longer takeoff for front CG and shorter for
aft CG. By contrast the conventional design has the CG near lift center
of main wing which carries most of the load and essentially dictates
the stall speed - considerably lower for the large wing. It is possible
to design a canard with large wings and lower stall speeds suitable for
water landing. It would probably look something like the Wright
brothers design with the canard way out up front to minimize the canard
wing CG position dependency. But why bother.
SQ2000 canard: http://www.abri.com/sq2000
Old July 20th 05, 12:31 AM
Marc J. Zeitlin
fredfighter wrote:
Hmm. ISTM that a canard does not stall when the aircraft pitches
down, it stalls when the aircraft pitches up.
Correct.
.... Thus each time the
aircraft hits a bump or wave the nose pitches up stalling the canard
so that the nose of the aircraft comes down hard into the next
wave or onto the next bump and then nosedives under the wave or
bounces higher and stalls again.
Possible.
Thanks, now I have a much better understanding of the rough field
take-off problem with a canard.
Well, you would if that was the reason for the rough field issues, but
it isn't.
I fly a COZY MKIV, and what happens on a rough field, due to the
geometry of the nosegear (and NOT dependent solely on the fact that it's
a canard aircraft) is that as high grass or bumps cause the nose gear to
flex somewhat, the nose of the plane drops a couple of inches, causing
the AOA of the canard to decrease, and decreasing lift. If the drag
from the grass/dirt, etc. is high enough, the canard cannot reach a
speed or AOA where it can rotate the aircraft.
So the problem is one of inability to rotate due to drag on the nosegear
and resulting geometry changes that lower the AOA, NOT on canard
stalling.
I have taken off from a few paved runways that are very bumpy (AFN in NH
comes to mind), and if anything, the bumps can help to get the nose of
the plane in the air at speed, and never come close to raising the nose
far enough to stall the canard.
Marc J. Zeitlin
http://marc.zeitlin.home.comcast.net/
http://www.cozybuilders.org/
Copyright (c) 2005
Old July 20th 05, 11:05 AM
The biggest issue with a canard is that the CLmax of the configuration is
low compared to a conventional configuration. This is for several reasons:
1. The smaller canard must stall first and that means that the wing will
never stall and hence never develop it maximum lift. Of course the opposite
is true for a conventional airplane. The larger wing stalls and developes
its maximum lift whilst the smaller tailplane remains unstalled.
2. Unless you do some tricky stuff you cannot really put a flap on a canard
because it is difficult to trim out the nose down pitching moments.
Low CLmax means that the configuration will not develop as much lift at a
given speed and hence the airplane will not be as suitable for short fields
as will a conventiona configuration.
For those without an engineering background, CLmax is simply a measure of
how much lift a given wing will produce per unit area at a given speed.
CLmax is the maximum lift coefficient.
"Marc J. Zeitlin" wrote in message
Correct.
Possible.
it isn't.
stalling.
Marc J. Zeitlin
Copyright (c) 2005
Passing of Richard Miller [email protected] Soaring 5 April 5th 05 01:54 AM
Swift Boat Guys Caught in Some Great Big Lies WalterM140 Military Aviation 44 August 23rd 04 08:30 PM
William Rood, Swift Boat skipper : Anti-Kerry vets not there that day Riddick Military Aviation 0 August 21st 04 05:09 PM
[sci.military.naval, rec.aviation.military] Lost Sunderland Flying Boat Found! Sunderland Military Aviation 0 April 4th 04 06:27 PM
'They want to ban recreational flying...' Thomas J. Paladino Jr. Piloting 28 July 22nd 03 07:20 PM
