Lycoming 290g Questions
Old December 4th 04, 03:52 AM
Default Lycoming 290g Questions
Hello All,
An "exhaustive" internet search regarding the 0-290G has left me with
several unanswered questions. I understand that the EAA published a
conversion guide years back that would be very helpful. In the mean
time, I am hoping some of you out there can answer any of the
following questions:
1) Which cylinders may be used (i.e. bolt-on) on the O-290G? I
understand that the stock cylinders, other 0-290 cylinders (D, D2
etc), and 0-435 may be bolted on and used.
2) Which pistons may be used (in native/unmodified form)?
3) Which cranks may be used (in native/unmodified form)? I understand
that "any" 0-320 crank may be installed without modification.
4) What "slight" modifications can be used to up the HP to 150hp?
5) Is the "converted" 0-290G still heavier than an 0-320? Why?
6) Any known sources for 0-290 parts?
Thanks for any help,
Old December 4th 04, 06:53 PM
Orval Fairbairn
(Mike) wrote:
Hello All,
There are two kinds of straight valve cylinders military (O-435-C) and
civilian (O-435-A) -- both are acceptable in any combination.
It is best to use the 3-ring pistons, rather than the old 4-ring
pistons. You can get 135 hp, if you use the O-290-D2 pistons (7.5:1,
rather than 6.5:1 compression ratio)
Piston Top Comp 2nd Comp Oil ring
125 hp 69958 62916/LW-13883p Same as #1 69401ca/68338pa
135 hp 69481 Same Same Same
I don't know this one, as I use the O-435.
El Reno Aviation
1994 S. Country Club Rd
PO Box 760
El Reno
OK 73036-0760
Ph: 1-800-521-0333
The entire top end of the straight valve O-435 series is the same as the
top end of the O-290 series. The only differences in hp are the pistons.
You can use the same tappets, lifters, push rods in O-540, )-360, etc.
Old December 5th 04, 06:05 AM
Drew Dalgleish
On Sat, 04 Dec 2004 18:01:41 -0800, Ed Sullivan
On 3 Dec 2004 19:52:31 -0800, (Mike) wrote:
Hello All,
I saw an ad, I think in the latest Sport Aviation wherein someone
wrote a new manual on the conversion. Price was $40.
EBS
H Mike I can't answer any of your questions but as an owner of an
0-290 D my advice is. These are unsupported engines parts are hard to
find and brutally expensive. If you need cylinders and a crankshaft
it's probably cheaper to buy an 0-320. If you want 150hp you should
buy an 0-320. If you do all the work needed to make it airworthy it
will still be worth next to nothing
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
