Hi all,
Yesterday I was flying on a Seneca II equipped with TSIO 360EB Teledyne Continental engines. The first flight (Dusseldorf-Milan) took 2 hours, FL 140, everything working perfectly adn according to the manual. The second flight (Milan-Rome) had the following inconvenience on BOTH engines: At FL 130 29" MAP 2400rpm the indicated fuel flow was 12 Gal/Hours but the Mixture control lever were in the "Full Rich" position. I could not move them to lean mixture since the fuel flow was going down to less than 12. The speed was correct (about 170 KTAS), and the engines were both a little bit too hot, but not that much. I repeat it was behaving like this for BOTH engines. And this sound strange and new to me.. I still have to fly again with the same plane, and it will be checked by a specialist before, but, is there anybody who has an idea about what was happening ? Silvio |
Several questions:
What do you mean by hot? What were the CHT's and Oil Temperatures? What do they normally run? What % of full power is 29" and 2400 RPM? I realize you're flying a turbocharged aircraft, but 24" and 2400 RPM is usually something like 75%, so I'd guess 29" and 2400 RPM is well over 75%. What is the recommended max cruise setting for these engines? Am I correct in assuming these are Continental 210 hp engines? "Silvio Mecucci" wrote in message oups.com... Hi all, Yesterday I was flying on a Seneca II equipped with TSIO 360EB Teledyne Continental engines. The first flight (Dusseldorf-Milan) took 2 hours, FL 140, everything working perfectly adn according to the manual. The second flight (Milan-Rome) had the following inconvenience on BOTH engines: At FL 130 29" MAP 2400rpm the indicated fuel flow was 12 Gal/Hours but the Mixture control lever were in the "Full Rich" position. I could not move them to lean mixture since the fuel flow was going down to less than 12. The speed was correct (about 170 KTAS), and the engines were both a little bit too hot, but not that much. I repeat it was behaving like this for BOTH engines. And this sound strange and new to me.. I still have to fly again with the same plane, and it will be checked by a specialist before, but, is there anybody who has an idea about what was happening ? Silvio |
"Kyle Boatright" wrote in message
... Several questions: What do you mean by hot? What were the CHT's and Oil Temperatures? What do they normally run? Good questions. The original post was certainly short on details regarding what the pilot feels is normal versus what was actually happening. What % of full power is 29" and 2400 RPM? I realize you're flying a turbocharged aircraft, but 24" and 2400 RPM is usually something like 75%, so I'd guess 29" and 2400 RPM is well over 75%. That all depends on the turbocharging. If the maximum boost is higher than 30", 29"/2400 RPM could easily be in the 75% range. That said, as far as I know these particular engines aren't boosted very high (but I'm almost entirely unfamiliar with them, so that doesn't mean much ![]() airplane has a maximum boost of 34", with a typical "high cruise" power setting being 29"/2300 RPM, for about 75% power. Pete |
Peter Duniho wrote:
/snip/ That said, as far as I know these particular engines aren't boosted very high (but I'm almost entirely unfamiliar with them, so that doesn't mean much ![]() airplane has a maximum boost of 34", with a typical "high cruise" power setting being 29"/2300 RPM, for about 75% power. Pete Pete, The TSIO-360EB is boosted to 40", quite high for a general aviation engine. Happy Flying! Scott Skylane |
"Scott Skylane" wrote in message
... The TSIO-360EB is boosted to 40", quite high for a general aviation engine. Well, there you go! 29/2400 is probably *less* than 75% power. ![]() And yes, that's pretty high. Wow. Poor little tiny engines, asked to put up with so much! ![]() Pete |
![]() Kyle Boatright ha scritto: Several questions: What do you mean by hot? What were the CHT's and Oil Temperatures? What= do they normally run? Maximum Oil temperatures 240=B0 F Maximum CHT 460=B0 F We were running about 210=B0 F for Oil and 420=B0F for CHT. Anyway.. this was in the middle fourth quarter of the indication ranges something like "hot".. :-) Normally, if you operate properly with cowl flaps and mixture leaning, they run right in the middle except during climbs or descends were they became hotter and colder namely. The strange was that we were not able to cool them down opening the cowl flaps The EGT's were at the minimum indications (like we has not leaned at all) but the Flow Meters were like the leaned properly. According to the POH it should have been 23.6 Gal / hour which means about 12 for each engine like I was reading. Just the left engines was overhauled while the right has still 600 hours. They were behaving exactly the same way.. It can't be the same kind of inconvenience to both engines, oil, cht, egt indicators and mixture levers.... Could it have something to do with the fuel we put during the second flight ? What % of full power is 29" and 2400 RPM? I realize you're flying a turbocharged aircraft, but 24" and 2400 RPM is usually something like 75%, so I'd guess 29" and 2400 RPM is well over 75%. Well not.. TSIO 360EB can run up to 40" as maximum continuos power if you are able to cool the engine properly (i.e. during a descend from a level higher than the single engine ceiling) According to the POH of the Seneca II this setting is 75% of power which is also the reccomended setting for the first 25 hours after a major overhaul like the one undergone by my left engine. What is the recommended max cruise setting for these engines? 75% Am I correct in assuming these are Continental 210 hp engines? They are Continental engines rated for 200hp at sea level and 215hp at 12,000ft "Silvio Mecucci" wrote in message oups.com... Hi all, Yesterday I was flying on a Seneca II equipped with TSIO 360EB Teledyne Continental engines. The first flight (Dusseldorf-Milan) took 2 hours, FL 140, everything working perfectly adn according to the manual. The second flight (Milan-Rome) had the following inconvenience on BOTH engines: At FL 130 29" MAP 2400rpm the indicated fuel flow was 12 Gal/Hours but the Mixture control lever were in the "Full Rich" position. I could not move them to lean mixture since the fuel flow was going down to less than 12. The speed was correct (about 170 KTAS), and the engines were both a little bit too hot, but not that much. I repeat it was behaving like this for BOTH engines. And this sound strange and new to me.. I still have to fly again with the same plane, and it will be checked by a specialist before, but, is there anybody who has an idea about what was happening ? Silvio |
I'm not entirely familiar with the TIO-360 but those CHTs sound high to me. Maybe I'm just conditioned to seeing temps around 370-380 in the Aztec/Lance (non-turbo) but John Deakin's excellent articles on this subject warn of exceeding 400F. Like another poster suggested maybe the FI system is out of whack? They are Continental engines rated for 200hp at sea level and 215hp at 1= 2,000ft Turbo engines with a higher power rating at altitude? Never heard of that, but then again I only have a few hours in the PA34-200T. |
That's what's written in the POH ..
what the pilot feels is normal versus what was actually happening I agree with you. I put some more details in the other reply. Also.. usually on GA cheap aircrafts, engine instruments are not that good in reliability unless hey are new or well mantained. I bought this airplane yesterday in germany.. were usually mantainance is done properly. In fact, both engine istruments indications were in accord. This let me think that is not something strange to do with a single engine or both engines with the same problem at the same time with a life so different: 0 hours vs 1200 hours... Please ask me any further detail can help You. S. |
On 7 Aug 2005 08:40:41 -0700, "Silvio Mecucci"
wrote: Please refer to TCM SID97-3C (latest revision is dated 2-25-2005). http://www.tcmlink.com/pdf2/SID97-3C.pdf It describes in detail how the fuel injection system on your engines is to be set-up. This should have been accomplished when your "new" engine was installed, and the unmetered pressures and fuel flows should be verified periodically (during scheduled inspections). I am not saying that you have a problem, but ensuring that you have the proper fuel delivered to a turbo-supercharged aircraft engine is not an option. Regards; TC Hi all, Yesterday I was flying on a Seneca II equipped with TSIO 360EB Teledyne Continental engines. The first flight (Dusseldorf-Milan) took 2 hours, FL 140, everything working perfectly adn according to the manual. The second flight (Milan-Rome) had the following inconvenience on BOTH engines: At FL 130 29" MAP 2400rpm the indicated fuel flow was 12 Gal/Hours but the Mixture control lever were in the "Full Rich" position. I could not move them to lean mixture since the fuel flow was going down to less than 12. The speed was correct (about 170 KTAS), and the engines were both a little bit too hot, but not that much. I repeat it was behaving like this for BOTH engines. And this sound strange and new to me.. I still have to fly again with the same plane, and it will be checked by a specialist before, but, is there anybody who has an idea about what was happening ? Silvio |
Leaning Procedure for a Carbureted 182 | Jeffrey | Owning | 54 | July 5th 05 04:23 PM |
It's finally running! | Corky Scott | Home Built | 19 | April 29th 05 04:53 PM |
Constant speed props | GE | Piloting | 68 | July 3rd 04 04:08 AM |
Lean of Peak Test Flight | Roger Long | Piloting | 0 | April 22nd 04 10:13 AM |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
