I have a few questions about private piloting (the PPL license) that I
havent seen answered anywhere. Maybe I'll learn about them during training, but whether or not I'll train depends on these answers: (1) Is there a central repository of rental locations other than the yellow pages? (2) After the ground training, do you have scheduled time with a trainer regularly, or do you just call a day or two in advance to check if the trainer is available to fly with? (3) Once the 20 hours with the trainer is complete, can you go to any FBO, rent the airplane and fly around to complete the remaining hours? Do you have to stick with an FBO? (4) Do the required 40 hours have to be in clear overcast weather or do you get to experience windy weather/rainy/night? (5) What is the difference between the recreational pilots license and the PPL? (6) Can you fly ultralights and wing gliders with a PPL? (7) Is the PPL recognized worldwide? Can I just rent out aircraft in Russia, Mexico, Pakistan, UK, Spain, Brazil etc? (8) Can you also fly aircraft with floats? (9) I understand to fly aircraft weighing more than 12500 lbs, you have to test for that aircraft with a trainer for a few hours. Is this also required for lighter but multiengine or turboprop aircraft like the Cessna 208? (10) Will I be able to rent any airplane under 12500lbs from any FBO or do each FBO put their own requirements (like 100 flight hours)? (11) Can I rent something to do a trans-atlantic? (after some real x-country experience) (12) Can I take aircraft into the arctic as cold as it gets? (13) Is there a limit of the distance I can go or the number of people or weight I can carry, or the altitude or speed beside the aircraft's certified performance? (14) Can I fly jets? If so is anyone renting out? (15) Can I take friends skydiving? (16) Are some of these questions answered in a FAQ I can just check? Thanks for your answers. |
"Ghazan Haider" wrote in message
oups.com... I have a few questions about private piloting (the PPL license) that I havent seen answered anywhere. Maybe I'll learn about them during training, but whether or not I'll train depends on these answers: (1) Is there a central repository of rental locations other than the yellow pages? No official place to find that information. However, the Canadian Owners and Pilots Association has a wealth of information that will likely be useful to you. The web site may answer many of your questions. The main page is he http://www.copanational.org/non-members/index.htm They have a directory of flight schools, which generally also offer rentals after you get your certification: http://www.copanational.org/non-memb...0Certified.htm (2) After the ground training, do you have scheduled time with a trainer regularly, or do you just call a day or two in advance to check if the trainer is available to fly with? It depends on what works best for you. Flight schools don't provide any sort of class schedule the way a college might. But it is usually easy enough to set up a recurring schedule with your instructor, if that works best for you. Just keep in mind that weather may affect whether you actually get to fly each of your scheduled lessons. Your instructor should either cancel the lesson before you make the trip to the airport or (even better) have a ground lesson prepared to take advantage of the time not spent in an airplane. If you are more comfortable scheduling lessons just a few days in advance, you can do that. Keep in mind, however, that this may well lead to less frequent flying, which will significantly increase the time you take to complete your training, and it may also be difficult depending on how many airplanes are available and how busy your instructor is. Longer-term scheduling is better, as is flying at least two or three times a week. (3) Once the 20 hours with the trainer is complete, can you go to any FBO, rent the airplane and fly around to complete the remaining hours? Do you have to stick with an FBO? There should be no requirement to complete your training with the same FBO and/or instructor with which you started. In the US there's not, and I doubt Canada is much different. In fact, you should not hesitate to consider switching instructors and/or schools if you are having problems with the one you start with. That said, you certainly don't want to switch very often. A new school will not allow you to solo until you have done some kind of orientation and check flight with one of their instructors; it's highly unlikely they would accept the previous school's solo endorsement for the purpose of allowing you to rent an airplane. So every switch does involve a certain amount of overhead, not even counting the time it takes for a new instructor to become familiar with you, your learning style, and your current level of progress. (4) Do the required 40 hours have to be in clear overcast weather or do you get to experience windy weather/rainy/night? "Clear overcast weather"? What's that? ![]() Again, I don't know the Canadian regulations specifically. In the US, you can do your training in any weather condition, as long as the instructor is qualified to act as "pilot in command" for those conditions. Some training in "instrument meteorological conditions" may not count toward your required aeronautical experience, but there's no rule in the US against training in such conditions. Generally, however, your instructor will want to at least maintain "visual meteorlogical conditions", and will probably avoid the worst visual conditions, at least until you are near the end of your training. Weather interferes with learning the basic concepts key to flying, and so it's probably counterproductive to try to train in poor weather. As far as what "VMC" actually is, in the US it generally means that you can remain 500' below the clouds, and maintain 3 miles visibility. The actual rules are much more complicated than that, and depending on what airspace you're in, the actual conditions may be a bit worse than that, or may have to be better than that. But it's a good starting point for you, with respect to where you are in your training (haven't started yet). ![]() (5) What is the difference between the recreational pilots license and the PPL? In the US, the recreational pilot certificate prohibits various operations that would be permitted with a regular private pilot certificate. Most notably, no cross-country flights beyond a relatively short distance, being able to carry only one passenger at most, and not being permitted to fly into certain kinds of airspace. Some of these restrictions can be removed with further training, and of course once you have your recreational pilot certificate, there's less work left to go ahead and get the full-blown private. To further complicate matters, the US has just created a new "Sport Pilot" certificate, that is kind of like the recreational, but in some important ways is different. I don't know whether this is relevant to Canada or not; as far as I know, Canada doesn't offer that certificate, and I don't know how they would treat a US pilot with that certificate. (6) Can you fly ultralights and wing gliders with a PPL? I assume so. In the US, no pilot certificate is required for those aircraft, and getting the additional training doesn't take that privilege away from you. Presumably, Canada's rules are similar.(7) Is the PPL recognized worldwide? Can I just rent out aircraft in Russia, Mexico, Pakistan, UK, Spain, Brazil etc? "Just"? No. You can't even do that within Canada. Any new FBO from which you want to rent will, just as they do for new student pilots with previous training, want to have you fly with one of their instructors to verify your competence as a pilot. Going to a different country depends on each country, but generally any country that has a pilot certificate will also have rules that dictate how you convert another country's certificate to theirs. I have heard a wide variety of rules, from a simple rubber-stamp, to a detailed examination. (8) Can you also fly aircraft with floats? No. Seaplanes require a different pilot certificate than landplanes. The add-on is not nearly as difficult as the initial training, but it does involve some significant new skills. (9) I understand to fly aircraft weighing more than 12500 lbs, you have to test for that aircraft with a trainer for a few hours. Is this also required for lighter but multiengine or turboprop aircraft like the Cessna 208? I don't know off the top of my head for all airplanes. Multiengine aircraft require a different certificate, just as seaplanes do. In the US a turboJET [emphasis mine] powered aircraft requires a type rating (just like large aircraft), but that doesn't apply to turboprop power aircraft like the Cessna 208. The FAA (and so, I suppose Transport Canada) may require type ratings for some aircraft other than large or turbojet powered ones, but AFAIK all of the single-engine turboprop airplanes don't fall under such a restriction in the US. Of all the regulations in the FAA/TC book, these are some that I would not at all be surprised to find significant differences. (10) Will I be able to rent any airplane under 12500lbs from any FBO or do each FBO put their own requirements (like 100 flight hours)? Each FBO has their own requirements. This is generally driven by their insurance carrier, but they may have other reasons as well. Generally speaking, the smaller or slower the airplane, the fewer restrictions. You are unlikely to be able to get anywhere close to the large aircraft limit (12,500 pounds) without some very specialized training, and extensive flight experience. Even airplanes in the 3000-4000 pound range won't be within reach immediately after getting your private pilot certificate. (11) Can I rent something to do a trans-atlantic? (after some real x-country experience) Possibly. It all depends on the FBO, and they will almost certainly want to do a fair amount of hand-holding to ensure that you have properly prepared for the flight. Trans-atlantic in small planes is never easy, and doing it in a rental just adds to your complexity of planning. That said, it wouldn't surprise to find an FBO that actually specializes in such flights, especially in the Nova Scotia area for example. There is a small, but probably solid business, in such flights. (12) Can I take aircraft into the arctic as cold as it gets? Flight into the Arctic involves a whole slew of other problems. It is theoretically possible, but likely involves at least an order of magnitude or two greater complexity and planning requirements than the trans-atlantic flight (which is itself no walk in the park). I would be surprised to find an FBO that allows that sort of flight, except under very narrow and unique circumstances. That said, keep in mind that there certainly are extensive areas in Northern Canada where flight is possible. Flying to the North Pole is one thing; flying near the Arctic Circle is something else, and much more likely. Planning can still be complicated, but this is true any time a flight extends away from populated areas. (13) Is there a limit of the distance I can go or the number of people or weight I can carry, or the altitude or speed beside the aircraft's certified performance? Sort of. In the US, you can only fly above 18,000' with an instrument rating or a waiver from the FAA. As far as I know, waivers are generally not given to powered aircraft (the only time I've heard of them being used is for gliders under very specific atmospheric conditions). Also, flying an airplane with a service ceiling higher than 25,000' requires special high-altitude training. In addition, there are requirements for the use of supplemental oxygen above 12,500' in the US. As far as weight goes...if you are qualified for the weight of the airplane, then you are permitted to fly it. Same thing with number of people. As far as speed goes, different airspaces do have different speed restrictions. But those restrictions are high enough that they are relevant only for very high performance airplanes, and they don't apply to the use of the airplane generally, just in airspace around terminal areas (that is, near airports, or below a certain altitude). (14) Can I fly jets? If so is anyone renting out? In the US, not without a type rating. Canada is probably similar. Renting a jet? Never heard of it. (15) Can I take friends skydiving? Don't know. I suspect that as long as you aren't getting paid, a private pilot certificate is just fine. (16) Are some of these questions answered in a FAQ I can just check? Many of them can be answered by reading the pertinent regulations. This would be a good place to start: http://www.tc.gc.ca/civilaviation/re.../cars/menu.htm Granted, it can be hard to read and find what you're looking for, when you're not a pilot and are unfamiliar with the regulations. But that's the authoritative source. On the bright side, I find the Canadian regulations to be better organized than the US regulations. ![]() The Transport Canada website probably has other useful information for you as well. Start on the "Air" page (click on the button at the top, on their navigation bar), and browse around. Pete |
In article , Peter Duniho wrote:
"Ghazan Haider" wrote in message oups.com... (12) Can I take aircraft into the arctic as cold as it gets? Flight into the Arctic involves a whole slew of other problems. It is theoretically possible, but likely involves at least an order of magnitude or two greater complexity and planning requirements than the trans-atlantic flight (which is itself no walk in the park). My own take on it: If Mr. Haider is capable of camping out in the arctic region during the desired time of year, for at least several days, then he will probably have a better appreciation of some of the factors for arctic flying including the survival aspects. If he can not handle a survival situation, then he would be better advised to reconsider arctic flying for another time, until one was more experienced. I say this, as having camped out in northern latitudes during the fall and visited in the winter. Summer is between cool to pretty hot. Very short 'spring' (if one at all) depending on latitude. Winter flying may have one worrying about how one's own feet is not going to freeze and require amputation. Engine heat may not be sufficient to keep one's feet warm in winter flying in the arctic. (Which is one of the many challenges involved.) Nevermind the oil situation or engine start... The arctic is something to truly appreciate -- its delights and beauty, as well as something to fully respect what dangers it presents. Arctic flying is doable, but it requires understanding, practice, some mentorship (instruction), and experience. Doubtful something that the recently-minted student pilot will immediately take on. Still, the arctic can be a long way from rescue (in that unlikely event), so one has to be prepared for possibility of needing to wait on the ground for several days at most in case of a serious emergency. Hence, the suggestion to be capable of camping out (and taking along the appropriate gear, too) during the desired time of year for an arctic visit. Your nearest neighbour could very well be easily at least 1000 km away. That's in addition to the requirements the FBO may have (if they permit such a rental at all) as well as Transport Canada, too. One I recall is that a flight plan is required, even for VFR flight plans, which makes more sense in the less populated areas. (From a search and rescue perspective.) Mr. Haider: I would recommend concentration on learning to fly, if you are truly interested, and let the 'additional stuff' take care of itself in due time, with experience. Many things are possible, with sufficient time, money, and patience invested. -Dan |
Most of the answers are in the CAR's (www.tc.gc.ca), but some help as
follows: Ghazan Haider wrote: I have a few questions about private piloting (the PPL license) that I havent seen answered anywhere. Maybe I'll learn about them during training, but whether or not I'll train depends on these answers: (1) Is there a central repository of rental locations other than the yellow pages? Not as such, but as mentioned elsewhere, you can some info from COPA or the Transport Canada website. (2) After the ground training, do you have scheduled time with a trainer regularly, or do you just call a day or two in advance to check if the trainer is available to fly with? You can do your ground school before, concurrently, or after your flight time. I did mine concurrently, and that's probably the best. You will also have some ground instruction before and after most flight lessons. (3) Once the 20 hours with the trainer is complete, can you go to any FBO, rent the airplane and fly around to complete the remaining hours? Do you have to stick with an FBO? It's not quite that simple - once you solo, which will likely be before you've done the mandatory hours with the instructor, you'll still need to do cross country, instrument training, etc. with an instructor. As well, you won't be able to rent a plane as a student without signoff from your instructor. As you get closer to completion, the instructor may just sign you off for certain types of flights. Even after you get your license, going to a new FBO or a different plane will require a check flight with an instructor in many cases. (4) Do the required 40 hours have to be in clear overcast weather or do you get to experience windy weather/rainy/night? You'll definitely fly in wind (if it's within the aircraft and your limits). Visibility and ceilings tend to be below minimums in a lot of cases, so you won't generally do much of that. As for night, that's a separate rating here, so you likely won't do any night flying while working on your license. (5) What is the difference between the recreational pilots license and the PPL? The rec license requires less training, and limits privileges: - no ratings except float/seaplane (in other words, day VFR only) - plane limited to single engine, 4 seats - limited to 1 passenger - not valid outside Canada (so you couldn't fly to the US for vacation, for example) (6) Can you fly ultralights and wing gliders with a PPL? Yes. (7) Is the PPL recognized worldwide? Can I just rent out aircraft in Russia, Mexico, Pakistan, UK, Spain, Brazil etc? I believe that it's valid in any ICAO country, however, you'll need to get checked by an instructor in almost any FBO that you rent from. (8) Can you also fly aircraft with floats? After obtaining a seaplane rating... (9) I understand to fly aircraft weighing more than 12500 lbs, you have to test for that aircraft with a trainer for a few hours. Is this also required for lighter but multiengine or turboprop aircraft like the Cessna 208? You can fly any "low performance, non-complex, single engine land aeroplane". This means that to fly anything with retractable gear, greater than 200 hp, more than one engine, or on floats, you need a rating (either a specific type rating for a certain aircraft, or a general rating for planes of a certain class, such as multiengine). (10) Will I be able to rent any airplane under 12500lbs from any FBO or do each FBO put their own requirements (like 100 flight hours)? It depends on the FBO and the plane. Every FBO will have a requirement to demonstrate that you can fly the plane - kind of like an abbreviated check ride. Basically, you go up with the FBO's resident instructor, and demonstrate the basic manoeuvers of the aircraft (slow flight, stalls, steep turns, takeoffs and landings), and know the "V speeds" and basic operating procedures and checklists. Some FBO's will also have a "checkout test" for low time pilots to force you to read the POH. (11) Can I rent something to do a trans-atlantic? (after some real x-country experience) Not likely. (12) Can I take aircraft into the arctic as cold as it gets? Yes, but you are required to carry survival gear as per the CAR's. Some aircraft have limits for low temperature as far as ground operations go, it will be in the POH. depending on where you are, you don't need to go to the Arctic to get cold in the winter. (13) Is there a limit of the distance I can go or the number of people or weight I can carry, or the altitude or speed beside the aircraft's certified performance? No. You do need to file a VFR flight plan or itinerary if you're going more than 25nm from the originating airport. (14) Can I fly jets? If so is anyone renting out? You'll need a type rating for each type of jet. I don't know of anywhere that you can rent one - if there is a place, I'm sure the minimum hour and checkout requirements would be very onerous. (15) Can I take friends skydiving? I think this is mentioned in the regs - don't remember off the top of my head. (16) Are some of these questions answered in a FAQ I can just check? The best thing to do would be to find a local flight school, and go up for an introductory flight. In my part of the country (Ottawa area) they're around $50. You go up for about 30 minutes, and typically get to take the controls for most of it - the instructor will take off and land. You can even log the time if you decide to go forward with training. After the flight, most instructors are more than happy to answer any questions you have. If you're in the Ottawa area, there are several schools: Westair Aviation, Carp Airport (www.westair-aviation.com) Ottawa Flying Club, Ottawa Airport (www.ofc.ca) Ottawa Aviation Services, Ottawa Airport (www.ottawaflighttraining.com) Rockcliffe Flying Club, Rockcliffe Airport - next to the National Aviation Museum (www.rfc.ca) Chapman Aviation, Arnprior Airport (www.chapmanaviation.com) Smiths Falls Flying Club, Russ Beach Airport, Smiths Falls (www.smithsfallsflyingclub.com - the instructors and bookings are managed by Ottawa Aviation Services) There are others on the Quebec side (at least one at the Gatineau airport). Thanks for your answers. |
| Thread Tools | |
| Display Modes | |
| Can a Private Pilot tow gliders and get paid? | BTIZ | Soaring | 1 | October 17th 04 02:35 AM |
| Trip Report - Canada (long) | Andrew Sarangan | Piloting | 8 | August 26th 04 04:34 AM |
| Could Canada Build | Charles Talleyrand | Military Aviation | 22 | July 11th 04 11:05 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| French block airlift of British troops to Basra | Michael Petukhov | Military Aviation | 202 | October 24th 03 07:48 PM |
