Decompression zombie aircraft-a simple solution
Old August 15th 05, 04:45 PM
Bret Ludwig
Default Decompression zombie aircraft-a simple solution
There should be a interlink which brings engine power to flight idle
any time cabin pressure is lost above FL180. The aircraft wil descend
under autopilot. There is statistically very little terrain above
18,000 feet and what there is is unpopulated.
Of course there should be an override, but it should take positive
crew action and should need to be repeated at intervals.(The emergency
buoy on a sub, is a good example. If not manually held down with a
timer button each hour it releases and sends the rescue signal.) How
long is a passenger aircraft without cabin pressure gooing to be
operated abov FL 180 anyway?
Old August 15th 05, 05:03 PM
No Such User
In article . com,
With all the fancy nav equipment you could do better. Just tell the
computer to descend to, say, 10000 "unless you're over the Andes,
Himalayas, etc."
Old August 15th 05, 05:13 PM
Ben Hallert
I recently read a review of a new business plane that had a similar
feature. I think it was the new Gulfstream, the reviewer noted that
the pilot manually partially depressed the cabin. Once the cabin alt
was above some figure like 9,000 or so, the plane automatically
initiated an autopilot descent to a 'safe' oxygen altitude.
A large scale accident like this may be responsible for an FAA mandate
that such systems be retrofitted onto existing commercial fleets. If
you know a public traded company that makes such equipment, now might
be a good time to invest.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
