Soaring Composite Index
Old August 16th 05, 04:05 PM
Papa3
Default Soaring Composite Index
If anyone is aware of a "Soaring Composite Index" which incorporates
all of the weather factors relevant to cross country soaring, please
post details below or contact me directly. So far, I have Jack
Harrison's excellent forecasts for the UK as a model, but I'm looking
for other inputs.
Similar to the Harrison number, plan is to use a 5 point rating system
(5 being best) to provide high-level guidance for folks looking at
record or badge flights. The index I am working on takes into acount
all of the following at various weights to come up with an overall
number.
- Thermal strength
- Thermal height
- Cumulus cloud ("generic" convective Cu)
- Adverse Winds (shear, drift, etc)
- Adverse cloud (vertical/horizontal OD, Ci, etc)
- Day duration
- Other adverse factors (catch all for OAS [other assorted ****])
The index number is baselined on a "competent pilot flying a Standard
Cirrus". Obviously, the index will require site-specific
modifications (on a ridge? in the mountains? etc), but I'm working
first on making sure that we agree on what "cracking good" or "tricky"
really means.
Obviously, there's no shortcut to really understanding the weather, but
for those of us who have to balance soaring with other mundane pursuits
(such as working for a living), it'll be nice to be able to get a high
level overview with a single number.
Plan for the moment is to pilot this for the Governor's Cup in
NJ/PA/NY.
Erik Mann
LS8-18 P3
Old August 16th 05, 04:09 PM
Don Johnstone
try http://www.drjack.info/
At 15:06 16 August 2005, Papa3 wrote:
If anyone is aware of a 'Soaring Composite Index' which
incorporates
soaring, please
I have Jack
but I'm looking
for other inputs.
point rating system
looking at
takes into acount
with an overall
number.
- Thermal strength
- Thermal height
- Cumulus cloud ('generic' convective Cu)
- Day duration
assorted ****])
The index number is baselined on a 'competent pilot
flying a Standard
Cirrus'. Obviously, the index will require site-specific
but I'm working
first on making sure that we agree on what 'cracking
good' or 'tricky'
really means.
the weather, but
mundane pursuits
able to get a high
Cup in
NJ/PA/NY.
Erik Mann
LS8-18 P3
Old August 16th 05, 05:23 PM
Papa3
Hi Don,
I'm an active Blipmap/Spot user. It's a great tool, but it's not a
Composite Index. It's really a graphical representation of the
underlying data. Even the Univiewer, which aggregates multiple
parameters in one view, requires one to make a a lot of correlations to
come up with the big picture .
P3
Old August 16th 05, 11:30 PM
Eric Greenwell
Papa3 wrote:
Hi Don,
Unless you fly where you have homogenous weather over a broad area for
most of the day, it's hard to imagine a single number is worth anything.
From our airport (Richland, Washington, USA), the homogenous area is
maybe a 10 mile radius circle. With the usual cloudbase, that's only 30%
of a final glide. Beyond that, picking the right direction to go
determines the quality of the flight, and not the weather around the
airport.
Also, the weather changes during the day, with marine air intrusions,
overdevelopment, rising cloudbases, changing winds, shear lines, etc.
So, even the pilot that stays close to the airport can have a day that
differs remarkably as it progresses.
And then there is the problem of different pilots in different gliders:
a beginning XC pilot flying a Ka-6 will have different criteria than an
experienced XC pilot in an ASW 27.
So, we have weather that change with time and location, and pilots that
differ greatly in what is worthwhile rigging for. My suggestion: if you
are going to stay close to home, look at the Blipspot (mini or
otherwise) for your airport; if you want to go a long distance, spend
the 5-10 minutes it takes to digest the Blipmaps. Hey, you are looking
for a five hour flight, the drive time to the airport, plus rigging and
derigging, so what's 10 minutes figuring out when and where to go?
Eric Greenwell
Washington State
USA
Old August 17th 05, 03:12 PM
Papa3
airport.
Exactly. So, what a forecaster does to add value is to take all of
these various factors into account to provide an analysis of the
weather and its potential to support cross country flight in your area.
Maybe I didn't give a clear explanation of the background and intent.
- We're fortunate to have a number of tools available to the general
soaring public that didn't exist just a few years ago. Various
forecast soundings, satellite data, etc. are all easily available over
the Web. Add to that interpretive sites such as Dr. Jack's, and one
has a fighting chance of predicting the good days... IF one takes the
time to consider all of the elements that affect XC soaring (a big IF).
- However, the average glider pilot still has a pretty hard time
interpreting even the simplest data. For instance, I can't tell you
how many times people I know have just looked at a RUC Blipmap
forecasting 500fpm lift and figured "it's a great day." They don't
know that it's a moment in time (18Z typically), whether it will be
blue or not, if there is OD potential, etc. etc. Yeah, Dr. Jack gives
you the info you need to do this, but most people can't put it all
together. And, this doesn't even begin to address the issue of
conflict across models and picking the best one (ever looked at the NAM
vs. GFS vs. NGM 24 hours out from a complex frontal passage?)
- The concept of the Soaring Composite Index (SCI as I'm calling it)
is for a human forecaster to interpret all of the available data and
come up with a score for the day. This score is subject to all of the
constraints you listed above (and more), so of course "your mileage may
vary."
- In terms of the assumptions, I do address the fact that the SCI will
be a) site specific (ie. somebody who knows your operating area will
have to do the interpretation) and b) it uses a benchmark of a
"competent pilot flying a Standard Cirrus" (so a Nimbus driver or a
1-26 driver will have to adjust accordingly) and c) the conditions in
any one quadrant may be significantly better or worse.
- In a practical sense, the SCI is really for those poor working
stiffs like myself who can only afford to take a very limited number of
"emergency days off" ("calling in soar" as one of the old-timers in our
club used to say). For me, I will only drop everything for an SCI of 4
or 5 (maybe a 3 if I haven't flown for a month).
- Really the only thing the SCI does is to try to put some rigor
around the statement that "it's going to be a really good day."
Anyway, Jack Harrison is doing the same thing in the UK with what seem
to be very positive results, so I thought I'd try something in Region 2
and see how it goes...
Erik Mann
LS8-18 (P3)
Old August 17th 05, 03:36 PM
Ian Cant
that the SCI will
area will
of a
'competent pilot flying a Standard Cirrus' (so a Nimbus
driver or a
the conditions in
Erik Mann
LS8-18 (P3)
With only one number [e.g. 3 or 4 or 5] and no info
on what went into generating it, exactly HOW does the
Nimbus or 1-26 pilot adjust accordingly ? Or, if the
components are supplied, what's different from interpreting
them as we do now ?
Ian
Old August 17th 05, 07:32 PM
Eric Greenwell
Perhaps the way to approach this is find out who wants it and what kind
of weather they think rates a 5, 4, 3, etc. If there is a lot of
agreement, then the weather guru has some hope of matching the weather
forecast with a number. I suspect there will be enough variation in
rating criteria between pilots that a single number will not be
generally useful except for days that are clearly so good or so bad,
everyone agrees.
Rather than a single number, perhaps the local guru could produce a few
charts so simple they could be comprehended by anyone in a minute. These
could similar to the Blipmaps, showing a "soarabilty index" in several
colors (such as red = bad, yellow=fair, green=GO!) on the map. Producing
a number for a single location (say, 30 km on a side) at a single time
would be simpler than coming up with a single number covering a 600 x
600 km area. Unfortunately, in this example, 400 numbers would have to
be produced!
It might be this could automated, using Blipmaps as the source.
Automation would give consistency to the results, and the rules could be
quite elaborate and easily changed. The weather guru would review the
output and make a few adjustments, if needed. Over time, routine
adjustments would be incorporated in the rules. Please don't ask Dr.
Jack to do any this: he has plenty on the table already!
A map for each time (18Z, 21Z, and 24Z) could be quickly scanned. By
knowing when and where the soaring was likely to be good, the pilot
could determine if the day was good enough to have a "soaring emergency"
and drive to the airport.
Eric Greenwell
Washington State
USA
diogenes
Hopefully someone using the UK single-number system will post how it
works for them - ideally from each of a high- medium-, low-performance
glider guider.
Old August 17th 05, 10:30 PM
Papa3
Ian,
A very valid point, and absolutely agree that the rating is not issued
in isolation. The plan for my region is to basically issue a rating
ALONG WITH the full forecast. Something like the following:
SCI for Wednesday, 17 August is a 3.
Synopsis: Cold front moved through overnight, with weak high pressure
building. Moderate NW flow throughout operating range and relatively
drier air building in.
Forecast: 2-4kts with some better over the ridge and Poconos.
Moderate Cu generally at 5,000 going to 6,000. Some chance of
vertical OD and an isolated shower. Winds NW at less than 15kts in all
areas. Weak ridge possible to sustain but may be treacherous. Expect
day to start and end early. Best conditions to the North and
Northwest.
I actually have a matrix in an excel sheet that gives the parameters
as set up for "my" local area. Elements and ratings guidelines are
reasonably granular. Just as a for instance (pipe delimited here in
free text):
Parameter|Measure|Weighting|Comments
Achieved Climb|FPM|3|200 fpm max rating is 2, 200-400fpm max rating is
3,400fpm-600fpm max rating is 4
Interpretation: Thermal strength measured in FPM. Weighting is 3
(highest weighting). 200-400fpm gives a max day rating of "3"
Another parameter (cloud interference) uses Spreadout % and a weighting
of 2 (medium weighting).
It looks a lot better in a single table - honest :-)) There's really
no way to plug all of this into a table and compute a mathematical
result, as the "rules engine" is actually pretty complex. That's why
we still need a human forecaster. The only thing this really does is
to give an indicative number that should get somebody to sit up and
take notice, for example, if they see a 5 ("Hi honey - wont' be home
tomorrow for our anniversary dinner after all - looks like the big day
for the 750Km triangle... CLICK [sound of phone slamming into cradle])
Cheers,
P3
FAI, soaring and Olympic Games iPilot Soaring 125 November 9th 16 01:37 AM
Introducing NJ's Newest Soaring Club! Jim Buckridge Piloting 2 February 22nd 05 04:07 PM
Soaring Seminar - March 19th - ChicagoLand Glider Council ContestID67 Soaring 4 January 6th 05 11:28 PM
SOARING INdex? Jim Kellett Soaring 3 December 10th 04 10:07 PM
Possible future legal problems with "SOARING" Bob Thompson Soaring 3 September 26th 04 11:48 AM
