Lycoming 0-235 L2C
Old July 7th 03, 02:52 PM
Capt. Dave
Default Lycoming 0-235 L2C
For sale, it was built for me but my needs have changed. Ron has NO email.
Engine Professionally Overhauled to New Limits, 0 Timed, Non certified, by:
"Reliable Horse Power", Ron Poelstra.
Cessna 152 engine, Dynafocal mounts. Ready to Ship!
SN: L-18454-15, 118 HP @ 2800 RPM
8.5:1 Compression, 100LL or 91 Octane Auto Fuel.
Dual Bolt Pattern Prop Flange.
..010 oversized nitrited cylinders.
"Good" hard valve seats and larger valves.
New Slick Impulse Mags, harness, plugs.
Latest Oil Pump AD's
Carb overhauled, Float and Venturi update.
New Pistons, Rings, Bearings, Rod bolts, nuts, studs, etc.
New Inter Cylinder Baffles, Rocker Drain Tubes.
Reconditioned Cam and Followers.
Very Low time Crankcase.
*Vacuum pump Remanufactured.(Can Remove to lower price)
*Lamar Light Weight Starter Remanufactured.(Can Remove to lower price)
Complete Test Run (With Records)(145 Min. Nov 23, 02) and Inhibited.
New Log Book.
Engine from a Repossessed Aircraft with no logs but has serial plate.
Only ~20 pounds heavier than a Continental 0-200.
Call Ron Poelstra (No E-Mail)
CEO of:
Reliable Horsepower, Waterloo/Guelph Regional Airport, CYKF
$16,000.00 Canadian
Res: 905-826-8389
Bus: 519-648-2398
Fax: 519-648-2399
Southern Ontario.
