Part 91 instruction and TBO
Old August 18th 05, 09:57 PM
Doug
Default Part 91 instruction and TBO
I am quite sure that one can offer an aircraft for hire with an
instructor under part 91 with an engine that has gone beyond TBO.
However, someone I know called the FSDO in California and asked, and I
was astounded when he was told that they told him if he was going to do
instruction for hire the airplane engine had to be rebuilt if beyond
TBO! I maintain that is erroneous information. I am not sure how to
"proove" this. Certainly he needs 100 hour inspections, but so long as
the mechanic will sign off the 100 hour, and annual, he is good to go.
Any help here?
Old August 19th 05, 05:19 AM
My understanding of the "official" FAA interpretation is as follows:
Renting an airplane, as opposed to chartering one, does not constitute a
commercial, "for hire" use. Hiring of a flight instructor is a separate
transaction not tied to the rental of the airplane. Therefore, regulations
specifically governing commercial operations do not apply to airplanes that
are rented out for instruction or for general use by pilots, regardless of
whether dual instruction is given. Of course, if the pilot renting the
airplane is going to use it for commercial purposes then the plane must meet
commercial use maintenance and operational regulations.
Because this interpretation is contrary to widely held belief it is not
surprising that a local FSDO would provide a different reading.
-Elliott Drucker
Old August 19th 05, 03:14 PM
Matt Barrow
news:r5dNe.22116$Rp5.7682@trnddc03...
regulations
that
meet
http://www.avweb.com/news/columns/187037-1.html
The Savvy Aviator #4: Debunking TBO
Engine TBO (time between overhauls) seems to be one of the most
misunderstood concepts in aviation maintenance. There are lots of
TBO-related old wives tales that are widely believed by owners and mechanic
alike, and they can cost owners a great deal of money. Mike Busch endeavors
to clear up these misconceptions, and explain what TBO really means.
By Mike Busch
(MYTH) "While it's true that manufacturer's TBO isn't compulsory for
non-commercial (Part 91) operators, commercial (Part 121/135) operators are
required to overhaul an engine when it reaches TBO."
Not so. Both Lycoming and TCM publish engine TBOs in the form of
non-mandatory service bulletins. Some Part 121/135 operators have Operations
Specifications that require them to comply with all manufacturer's service
bulletins (even non-mandatory ones), while others have Op Specs that require
compliance only with mandatory service bulletins. Those in the latter group
are no more obligated to comply with published TBO than are Part 91
operators. Those in the former group might theoretically be required to
overhaul at published TBO, but most such operators request TBO extensions
from their FSDO and these are routinely granted, often for as much as 50%
over the engine manufacturer's published TBO. So, in actual practice,
published TBO is hardly ever compulsory for any operators -- commercial or
non-commercial.
Old August 19th 05, 04:38 PM
Mike Rapoport
I agree and have also previously read Mike Busch's article but question
really is whether renting an airplane and providing a flight instructor is a
commercial operation, one without Op Specs., where, presumably, the most
conservative interpretation would be applied. Do flight schools generally
have to overhaul at TBO?
MU-2
"Matt Barrow" wrote in message
regulations
that
of
meet
mechanic
endeavors
By Mike Busch
are
Operations
require
group
non-commercial.
Old August 19th 05, 06:45 PM
Matt Barrow
My guess would be: Not unless they are carriers (passengers), not merely
commercial operators per se. Note he says even air carriers have gotten
waivers up to half again the TBO time. I recall that one of Deakin's
articles stated that in the great long ago, the airlines were running the
radial engines to DOUBLE their normal TBO time (though we can be certain
that the rules have changed even now in the turbine era).
The interesting part of the article, though, is his point that you can be
wayyyyy below TBO and not be AIRWORTHY. Also, that the most likely time for
engine failure is right _after_ TBO, not _ just before_.
As for flight schools:
Sec. 141.39 Aircraft.
An applicant for a pilot school certificate or provisional pilot
school certificate must show that each aircraft used by that school for
flight training and solo flights meets the following requirements:
(a) Each aircraft must be registered as a civil aircraft in the
United States;
(b) Each aircraft must be certificated with a standard airworthiness
certificate or a primary airworthiness certificate, unless the
Administrator determines that due to the nature of the approved course,
an aircraft not having a standard airworthiness certificate or primary
airworthiness certificate may be used;
(c) Each aircraft must be maintained and inspected in accordance
with the requirements under subpart E of part 91 of this chapter that
apply to aircraft operated for hire;
141.91 (???) pertains to Satellite Operations: what the hell are those?)
a
MU-2
a
separate
regulations
that
of
meet
mechanic
endeavors
By Mike Busch
are
Operations
service
require
group
extensions
50%
or
non-commercial.
Old August 20th 05, 05:27 AM
Robert M. Gary
None that I know of. Flight Schools often go beyond TBO. I know FBOs
that can put 2000 hrs on a 172 in 3 years. That engine looks brand new
when you open it up.
-Robert
Old August 20th 05, 07:10 AM
Chuck
I can tell you from first hand experience that the FSDO in San Antonio
does not read the rules the same way.
I was "leasing-back" my Cherokee to a local school for instruction.
They had three or four planes there that were past TBO. And they had
a fleet of Thomahawks, one in particular was more than 50% past TBO.
This particular school owner was in deep **** with the local FSDO for
putting off, pencil-whipping. or other such **** on maintenance.
Because of it, the local FSDO was all over him and the maintenance
records. I was working closely at the time with the A&P there keeping
my plane up and flying. I know for a FACT that the Inspector knew the
hours on that Thomahawk as well as three other planes that were past
TBO. But nothing was said in that respect.
Now, in deference to that owner -- that Thomahawk was the best running
of the five he had. It climbed even better than the one with the STC
horsepower upgrade. All inspections were good, no metal in the oil,
and just no indication that it needed rebuild. True, it had a LOT of
hours on it -- but it ran great.
Oh, and it was being used for both instruction (under both parts 61
and 141) and also used for rental occasionally. FSDO didn't say a
thing...
Chuck
PA28-180
On 18 Aug 2005 13:57:02 -0700, "Doug"
Any help here?
