What Kit takes a TCM IO-240
Old December 18th 04, 05:38 PM
Bob
Default What Kit takes a TCM IO-240
What kit takes a TCM IO-240?
We have this 240 hanging around and we can't sell it but we could stick
in something and fly it.
So what would be a good platform to hang this 240 on?
Should have a fast build kit available. Fixed gear, reasonable
landing/stall speed. 2 seater is a must, Tandem or side by side.
Not terribly expensive.
Should fit at least on semi-large guy, as in oh.....a 220 pounder and
tall.
Old December 18th 04, 05:52 PM
jls
"Bob" wrote in message
tall.
Diamond Katana uses the IO-240. I don't know of any experimental. By the
way you describe your engine it is apparently an O-240.
Put it in a 2-place experimental Cub, Vagabond, or Super Cub.
Old December 19th 04, 06:28 AM
Jim Carriere
tall.
There are a few Kitfoxes around with IO-240s. It's a lot of engine
(125hp) for an airplane that flies pretty well with a Rotax 912
(100hp). Or I suppose maybe it is "just the right" engine, depending
on personal preference- takeoff and climb performance is supposed to
be impressive.
Because the Contintental is a heavier powerplant than the Rotax
(close to 100lbs more), the wings on the Kitfox must be swept forward
slightly, otherwise the c.g. would be too far forward (or lots of
ballast would be required). I don't know what design changes went
into the IO-240 engined Katana.
Coincidentally, both airplanes (Kitfox and Katana) have several years
of history with the Rotax 912.
Old December 18th 04, 06:21 PM
Rich S.
Not a kit, but meets all of the other parameters. . .
http://www.homebuilt.org/kits/littner/cp328.html
Rich S.
Old December 18th 04, 06:23 PM
Rich S.
Oh - I should have mentioned - there's a complete airframe advertised in the
Flyer for ~$5,000.
Rich S.
Old December 18th 04, 06:55 PM
tall.
Kitfox Series 7 will take an IO-240. Cockpit room is in the eye of the
beholder.....
http://www.skystar.com/series7.htm
IO-240 is listed as suitable for the RV-9.... the prototype flew with an O-235.
Quickbuild kit goes for about $18K.
http://www.vansaircraft.com/public/rv-9int.htm
Old December 18th 04, 10:07 PM
Drew Dalgleish
tall.
There's a few murphy rebels flying with an 0-240
Old December 18th 04, 11:46 PM
Nathan Young
tall.
Super pulsar 100.
http://www.pulsaraircraft.com/
Old December 22nd 04, 02:36 AM
Rick Pellicciotti
I would have to go with the RANS Shekari or the Vans RV-9
Rick
What makes the engine unsellable?
tall.
Lancair IV-P lost near Lansing MI Darkwing Duck \(The Duck, The Myth, The Legend\) Home Built 43 June 9th 04 03:29 PM
Help change GAS prices Bob Olds Home Built 37 May 24th 04 11:46 PM
