About thrust force
Old August 21st 05, 12:58 AM
Grandss
Default About thrust force
I have one question concerning thrust force.
What's happend if i increase thrust at a very hight value (theorics).
I know that lift will increase too and drag decrease.
But for the plane, what it do really.
Just UP or begin to turn to rise ?
Thanks
Grandss
Old August 21st 05, 01:13 AM
Bob Noel
drag increases with airspeed, doesn't it?
depends on the propulsion system.
Bob Noel
no one likes an educated mule
Old August 21st 05, 01:21 AM
Grandss
yes, increase sorry
Ok but for a classic plane (type little cessna) what's the reaction of
the plane ?
Old August 21st 05, 01:55 AM
Bob Noel
the plane ?
For the single engine fixed-pitch prop, increasing the RPM will increase
the airspeed, thus increasing the lift (and the plane will climb, assuming
no change in trim). Also, there will be a left-turn tendency (think about
the difference in thrust of each blade due to angle-of-attack variances
as it spins).
Bob Noel
Old August 21st 05, 02:43 AM
john smith
as it spins).
Depends upon which way the prop is turning!
Old August 21st 05, 04:06 AM
Larry Dighera
On Sun, 21 Aug 2005 01:58:16 +0200, Grandss grandss@nospam wrote in
Generally an increase in power/thrust results in an increase in rate
of climb if the wing's angle of attack isn't changed. Increasing
thrust and reducing AOA should result in an increase in airspeed.
If the increased thrust results in an increase in airspeed, parasitic
drag will increase.
Thanks
Grandss
I realize you're in Luxembourg, and your native language is probably
French, but here's a link to web site written in English that will
answer all your questions: http://aerodyn.org/contents.html
Perhaps you can translate from English to French he
http://www.babblefish.com/babblefish/language_webt.htm
Old August 21st 05, 06:42 PM
Darrell S
Thanks
Grandss
Depends. Thrust is a term generally only used for jet or rocket powered
craft. On a jet or rocket powered plane the speed has to increase to
increase wing lift. On most prop airplanes an increase in power will
produce greater airflow and increase lift somewhat even before speed
increases.
However, if you have enough thrust and enter a vertical climb you can
support the aircraft weight by power alone, without regard to wing lift.
Darrell R. Schmidt
B-58 Hustler History: http://members.cox.net/dschmidt1/
Old August 21st 05, 10:19 PM
Grandss
Thanks
Grandss
Thanks for all precision
Air Force Working to Combat Stressors Otis Willie Military Aviation 0 September 18th 04 03:54 AM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Highest-Ranking Black Air Force General Credits Success to Hard Work Otis Willie Military Aviation 0 February 10th 04 11:06 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
