OLC score calculation?
Old August 22nd 05, 07:57 PM
ttaylor at cc.usu.edu
Default OLC score calculation?
I was just wondering how the OLC scores are calculated. I was looking
at a case today where a higher performance ship Ventus 2 versus my
Ventus B flew a shorter distance and slower yet gets a slightly higher
score.
Here is the raw data from August 20th on the USA section:
304.96 Hunter Robert US 348.66 88.73 Hemet (US) Soarfari Ventus 2
(N666RH) 2017-0013
303.35 Taylor Tim US 349.85 102.3 Morgan Ut (US) Cache Valley Soaring
Association Ventus 1 (TT) 2037-2402
Can any one explain how the scores are calculated?
Tim
Old August 22nd 05, 08:30 PM
Greg Arnold
It is explained on the OLC website. Speed doesn't matter. Also, the
5th and 6th legs don't count as much as the first 4 legs, so there is
not a consistent relationship between distance and points.
score.
(N666RH) 2017-0013
Tim
Old August 23rd 05, 12:56 AM
OLC score is based on distance only, which is multipled by your
glider's handicap or "OLC index". (Not literally. If your Ventus
index is 110, your distance score will be divided by 1.1. Something
like that.)
score.
(N666RH) 2017-0013
Tim
Old August 23rd 05, 09:34 PM
Sven Olivier
OLC allows the flight to be optimised for six legs. The first 4 legs score
100% (ie 1 point per km), leg five 75% (ie .75 points per km) and leg six
50%. The total score is then adjusted with the handicap of the glider.
At least that is how i understand it.
Sven
EY
like that.)
score.
(N666RH) 2017-0013
Tim
Old August 24th 05, 01:50 AM
David Kinsell
Leg 5 is counted at 80%, leg six at 60%. It's in the Info and Rules section.
Dave
Sven
EY
like that.)
score.
(N666RH) 2017-0013
Tim
Lycoming Horsepower Calculation? Mark Doble Home Built 1 June 20th 05 10:46 PM
Three leg GS to TAS calculation Mike Rapoport Owning 21 September 12th 04 04:37 AM
LX4000 wind calculation AttentionLEcureuil Soaring 2 June 23rd 04 04:33 AM
The "Complex" TAS calculation Arnold Pieper Soaring 2 December 14th 03 12:22 PM
propeller calculation and how to build jgarner Home Built 7 August 25th 03 03:23 AM
