Backward Running Engine
Old August 29th 05, 12:56 PM
mbremer216
Default Backward Running Engine
Cherokee w/Lycoming 0360-A4A
Normal flight in all respects. When shutting down, pulled throttle to idle
and mix to idle cut-off. Engine took just a little longer than normal to
run down. Just as it should have stopped, it caught and actually ran
backward for a couple of turns before stopping.
Any ideas as to why?
Thanks
Old August 29th 05, 06:05 PM
George Patterson
One of the mags may have slipped time or been set incorrectly.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old August 29th 05, 06:58 PM
Paul kgyy
I had this happen too a couple of months ago on my IO360. - just
happened once, everything's been normal since.
Old August 29th 05, 07:56 PM
mbremer216 wrote:
: Cherokee w/Lycoming 0360-A4A
: Normal flight in all respects. When shutting down, pulled throttle to idle
: and mix to idle cut-off. Engine took just a little longer than normal to
: run down. Just as it should have stopped, it caught and actually ran
: backward for a couple of turns before stopping.
: Any ideas as to why?
Completely WAG, but extra-rich idle mixture pooling in exhaust system, gets
sucked in on the final "bounce" and either preignites from hot heads and/or mags
firing at normal 25 "BTDC" (now ATDC).
Like I said, completely WAG.... getting fuel into the thing running backwards
is the tough part to explain.
-Cory
* Cory Papenfuss *
Old August 30th 05, 01:35 AM
jay somerset
On Mon, 29 Aug 2005 06:56:01 -0500, "mbremer216"
Quite common with engines that have timing well in advance of TDC.
Usually caused by plugs that are fouled with carbon, which stays hot
and causes detonation under compression. Called "dieseling."
You can lessen the chances of it happening by revving the engine up
just before you cut the fuel mixture. Running backwards isn't good
for the engine -- and it can play hell with vacuum pumps, as the vanes
are designed to turn in one direction only. Same problem in cars and
outboard engines with water pumps.
Thanks
Gyrocopter Speed Mark Rotorcraft 36 August 16th 05 11:28 PM
ROP masking of engine problems Roger Long Piloting 1 September 25th 04 07:13 PM
YAMAHA FZ 750 FZ750 RUNNING GENESIS ENGINE FOR SALE Karsten Home Built 0 September 3rd 04 07:34 PM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 03:27 PM
