Cherokee alternator bracket replacement
Old September 2nd 05, 02:47 PM
Default Cherokee alternator bracket replacement
Hey all... My Cherokee is almost done with the annual, but in the 75 hours
since it was last inspected, the alternator bracket has cracked. It's complicated by
the fact that the plane was originally a PA28-140, but now has a Lycoming O-360-A3A.
So, the parts book doesn't necessary literally apply. From the picture, it looks like
it's P/N 65199-00. My mechanic says I should get the assembly, and that it has been
superceeded by a better part. Is that the P/N 63520-00 or the P/N 63698-00?
Also, where's an appropriate place to get a replacement? Piper only, or do
other folks sell them? If the bracket has been superceeded by another due to chronic
cracking, a salvage yard isn't necessary a good place to get one.
Thanks!
-Cory
* Cory Papenfuss *
Old September 2nd 05, 04:51 PM
Jim Burns
I'll second APofLH and add http://www.westexairparts.com/, email Mark, he's
very knowledgeable.
Old September 2nd 05, 05:38 PM
: do you need the one for an airconditioned 140?
: (lots of those around - I could probably dig mine up).
No, this one doesn't have A/C. After spending the whole morning calling up a
bunch of places, I'm pretty sure the correct part is 65199-00, which has been
superceeded by 65199-005. Most places don't have any in stock (big surprise). It
doesn't seem like it matters whether it's an O-320 or O-360, though. One piper place
I called suggested getting ahold of Lycoming. The two brackets they spec for an
O-360-A3A (07A21443 and 07A19474) seem to be for Ford and Prestolite alternators,
resp.... probably won't work for the Chrysler that Piper used.
A/C in a -140? Ughh... no wonder there aren't many left. They're doggy
enough without an additional 20 lbs and hp loss.
-Cory
* Cory Papenfuss *
Old September 2nd 05, 05:46 PM
Jim Burns
Cory,
Try Mark at Westex, tell him I refered you. He also sells piper parts
manuals & CD's so he should know the correct part number. He's also got a
lot of NOS Piper parts so he may have one in stock.
Jim Burns
Old September 2nd 05, 09:09 PM
Mike Spera
20lbs. for air conditioning? Try 67lbs.
Old September 2nd 05, 09:53 PM
nrp
The vibration environment at the lower front of 4 cyl Lycomings seems
to be quite brutal. On top of that the alternator mount on our 172M
was "scientifically" measured to be resonant at 80 Hz (hand blow with a
hand held accelerometer & a scope). Eighty Hz is also the torsional
firing frequency (@2400 RPM) and there is also a second harmonic (of
course that is also 80 Hz at 2400 RPM) yaw rocking couple in the engine
due to its mechanical configuration
Maybe that,s why so many of alternator brackets become cracked. Does
the newest Piper bracket address this resonance problem?
A Piper Cherokee 140... good first plane? Cecil Chapman Owning 20 September 4th 05 03:50 PM
Cherokee Pilots Association Fly-In Just Gets Better and Better Jay Honeck Piloting 7 August 8th 05 08:18 PM
Cherokee Strut Lower Strut Seal Replacement Report Mike Spera Owning 3 July 23rd 05 08:07 PM
CHEROKEE NATIONAL FLY-IN & CONVENTION - THIS MONTH! Don Owning 0 June 3rd 04 06:03 AM
replacement rotating beacon for 64 piper cherokee Patrick Mathews Owning 2 October 1st 03 02:55 PM
