Why so many rivets?
Old December 29th 04, 02:26 AM
Brian Sponcil
Default Why so many rivets?
I'm currently considering embarking on an RV project and after checking out
a few in our local EAA chapter I ran across a seemingly curious fact. I
recall the builders telling me that their RV kits have around 10,000 rivets.
Compared to a Piper Comanche at 3,714 and a Warrior at 1,785 that's a heck
of a lot of rivets.
So the question is, why so many???
-Brian
N33431
Old December 29th 04, 04:39 AM
On Tue, 28 Dec 2004 20:26:00 -0600, "Brian Sponcil"
of a lot of rivets.
Don't know for sure, but here are my guesses:
1. It's possible the RV uses smaller rivets. Smaller rivets are easier for
amateur installers, while a manufacturer with trained riveters might use larger
rivets to cut down the man-hours needed for construction.
2. Most of the RV series are aerobatic, while the Pipers are not. More rivets
needed due to higher load factors
3. The designers add a bit of extra margin due to mistakes the amateur might
make.
4. The "N" number of rivets listed for Pipers may not include rivets used by
any companies that subcontract parts, while the builder does all the RV rivets.
5. RVs seem to use rivets *everywhere*...perhaps the Pipers use more bolts,
molded sections, etc.
6. Eighth-inch rivets are supposed to be installed about 32 to a foot, and most
RV builders think this --- --- is six inches. :-)
Old December 29th 04, 05:32 AM
Ric
"Ron Wanttaja" wrote in message
out
rivets.
of a lot of rivets.
for
larger
rivets
might
make.
by
rivets.
bolts,
and most
I'm not sure where I read it, but I remember something about by using more
rivets the strength of the structure will not be compromised by the
occasional badly driven rivet.
Ric
Old December 29th 04, 06:05 AM
On Wed, 29 Dec 2004 04:39:06 GMT, Ron Wanttaja wrote:
6. Eighth-inch rivets are supposed to be installed about 32 to a foot...
For those who are wondering, this isn't a "real" specification....
Old December 29th 04, 01:36 PM
Matt Whiting
of a lot of rivets.
make.
I agree with Ron's guesses (not sure about #6 though), and will add a
7th possibility. It may be that the larger companies use more machine
formed sections (stamped, hydroformed, etc.) that can be larger and thus
have fewer seams to be riveted.
Matt
Old December 29th 04, 02:42 PM
checking out
fact. I
10,000 rivets.
a heck
of a lot of rivets.
easier for
might use larger
More rivets
amateur might
make.
rivets used by
the RV rivets.
more bolts,
foot, and most
inches. :-)
machine
thus
Matt
Whatever: The RV is sure a LOT more airplane than anything Piper
built !!!!
Bob Olds RV-4
Charleston,Arkansas
Old December 29th 04, 04:00 PM
Orval Fairbairn
of a lot of rivets.
-Brian
N33431
One of the things I have noticed on Comanches is that their rivet
spacing for #3 rivets is about twice that spelled out in the manuals.
The result is that a lot of Comanches show signs of distress along those
rivet lines with too much space between rivets.
I have not checked Warriors that closely but would expect to see the
same thing there, too.
Old December 29th 04, 04:29 PM
Michael Pilla
"Matt Whiting" wrote in message
out
rivets.
of a lot of rivets.
SNIP
Matt
Regardless of the number of rivets, the actual riveting process is not all
that time consuming. Yes, you do have to clean 10,000 holes (at least
double, for the mating parts) and debur them, and even countersink/dimple a
lot of those holes, but you develop a rhythm that goes by rather quickly. I
found that the actual setting of rivets, once the prep is finished, is so
quick that it is almost anti-climactic.
So, if the original poster was concerned about the sheer number of rivets;
i.e., the level of effort, then I recommend that he not be concerned about
that. The systems work will consume the most time as well as looking at the
plans, figuring out the steps, etc. The learning part is the most fun, for
me.
Michael Pilla
Old December 29th 04, 06:31 PM
MJC
.... or it that's a "problem" for you, do what I did.
RV7-A Quickbuild kit. Poof; lot's less rivets :-)
MJC
"Brian Sponcil" wrote in message
out
rivets.
of a lot of rivets.
-Brian
N33431
"C-175 SoCal Beware" Original Poster Replies Bill Berle Home Built 3 July 8th 04 07:01 AM
Poppers Revisted and the Return of the Teenie Two Veeduber Home Built 0 March 29th 04 09:57 AM
Patching Baffling, 3/32 C-Sunk Rivets, 1100 Aluminum? jls Home Built 3 February 3rd 04 12:15 AM
Bonded aluminum aircraft structures asennad Home Built 9 December 31st 03 02:58 PM
Dimpling and riveting pressures Max Krippler Home Built 5 November 11th 03 08:03 PM
