On Wed, 07 Sep 2005 21:41:41 -0600, Newps wrote
in :: I have a 64 S35, first year with the IO520 and the first year as a six seater so as a four seater you have a lot of cargo space. One of the first things you notice is these things are really put together. Cessnas and Pipers are flimsy beer cans compared to a Bonanza, of course thats also why the empty weight is 230 pounds more. You probably haven't had your Bonanza long enough to answer this question, but how do you find the cost of maintenance? I have heard that Raytheon charges exorbitant prices for parts. Back in the late 90s I made a short trip from John Wayne Airport to Van Nuys to pick up a passenger. The owner of the FBO from whom I rented the aircraft for the flight asked if I might pick up a set of generator brushes for him. I intended to pick up my passenger at the Raytheon ramp on KVNY, so I agreed to bring the parts back with me. The cost for two generator brushes (for clarity, these are about the size of a half stick of blackboard chalk and made of carbon). The bill was about $200.00! I was shocked. When I worked at the electrical wholesale house in the 70s, we sold similar brushes for $0.50 each. So what has been the experience of other Bonanza owners with regard to maintenance costs? [crossposted to rec.aviation.owning] |
Alot of bonanza parts are expensive. However, accessory parts are what
the market offers since they aren't aircraft specific ie brushes. Those don't need to be bought from Beechcraft. If you buy them from Beech, they will be marked up 300%. Most of the Beechcraft parts are very well built and don't need changing very often. Once the aircraft is up to snuff, the maintenance isn't much different than other aircraft of the same type. Nothing flys like a Bonanza!!! Larry Dighera wrote: On Wed, 07 Sep 2005 21:41:41 -0600, Newps wrote in :: I have a 64 S35, first year with the IO520 and the first year as a six seater so as a four seater you have a lot of cargo space. One of the first things you notice is these things are really put together. Cessnas and Pipers are flimsy beer cans compared to a Bonanza, of course thats also why the empty weight is 230 pounds more. You probably haven't had your Bonanza long enough to answer this question, but how do you find the cost of maintenance? I have heard that Raytheon charges exorbitant prices for parts. Back in the late 90s I made a short trip from John Wayne Airport to Van Nuys to pick up a passenger. The owner of the FBO from whom I rented the aircraft for the flight asked if I might pick up a set of generator brushes for him. I intended to pick up my passenger at the Raytheon ramp on KVNY, so I agreed to bring the parts back with me. The cost for two generator brushes (for clarity, these are about the size of a half stick of blackboard chalk and made of carbon). The bill was about $200.00! I was shocked. When I worked at the electrical wholesale house in the 70s, we sold similar brushes for $0.50 each. So what has been the experience of other Bonanza owners with regard to maintenance costs? [crossposted to rec.aviation.owning] |
Aircraft parts in general are expensive; Beech parts are simply outrageous. My injected engines have one way valves that allow fuel to drain in case it was overprimed. They are Piper parts, and are $50 each. They are functionally equivalent to automotive valves that cost $10 each. But that's nothing. My friend has a Baron, and his valves are $600 each. That's the Beech way. Similar example - rod ends for trim tab actuators. Normally an AN part, about $15. On the Baron, it's $120. Most of the Beechcraft parts are very well built and don't need changing very often. Many of my friends own Bonanzas and Barons. I have not noticed them replacing parts less often than I do on my Piper, same vintage. Beech parts are no better (or worse) than any other aircraft parts. They are more expensive. Once the aircraft is up to snuff, the maintenance isn't much different than other aircraft of the same type. That's true. Mostly, the parts that wear out are engine, not airframe parts. Fortunately, the engines are Continental - not Beech/Raytheon. By the time you figure in all the other expenses - labor, engine parts, fuel, insurance, hangar, engine overhaul - the high cost of Beech parts isn't really a significant factor in owning a Beech. It's only when you buy something that needs a lot of airframe work that the Beech parts cost hits you hard. That's why you can get such a great deal on an old Bonanza, Baron, or TravelAir. Nothing flys like a Bonanza!!! Actually, lots of things fly like a Bonanza. It's an airplane. Nothing special. The real truth is, nothing lands like a Bonanza. Most airplanes in its class require some skill to land. The Bonanza really doesn't. It's easier to land than a C-172. It makes you look good. That's why so many pilots love it. Michael |
![]() Larry Dighera wrote: On Wed, 07 Sep 2005 21:41:41 -0600, Newps wrote in :: I have a 64 S35, first year with the IO520 and the first year as a six seater so as a four seater you have a lot of cargo space. One of the first things you notice is these things are really put together. Cessnas and Pipers are flimsy beer cans compared to a Bonanza, of course thats also why the empty weight is 230 pounds more. You probably haven't had your Bonanza long enough to answer this question, but how do you find the cost of maintenance? I have heard that Raytheon charges exorbitant prices for parts. I've heard that too, we'll see. My IA has the same model Bo I do so I am lucky there. No paying for learning about Bonanza's. Back in the late 90s I made a short trip from John Wayne Airport to Van Nuys to pick up a passenger. The owner of the FBO from whom I rented the aircraft for the flight asked if I might pick up a set of generator brushes for him. I intended to pick up my passenger at the Raytheon ramp on KVNY, so I agreed to bring the parts back with me. The cost for two generator brushes (for clarity, these are about the size of a half stick of blackboard chalk and made of carbon). The bill was about $200.00! I was shocked. When I worked at the electrical wholesale house in the 70s, we sold similar brushes for $0.50 each. My mechanic says I have an alternator that costs a lot to overhaul if you do it the right(FAA) way. We will be taking it to the automotive shop down the street when the time comes. Right now I have one dimmer switch that is belly up. Mechanic says $350 from Beech but he will check his other sources and get a cheaper one. Cessna was the same, very expensive for a dimmer but we found a different source. |
On Thu, 08 Sep 2005 20:27:29 -0600, Newps wrote
in :: My mechanic says I have an alternator that costs a lot to overhaul if you do it the right(FAA) way. We will be taking it to the automotive shop down the street when the time comes. Have you any idea with the differences in overhaul procedures are? Right now I have one dimmer switch that is belly up. Mechanic says $350 from Beech but he will check his other sources and get a cheaper one. A dimmer is nothing more than a wire-wound rheostat right? If it hasn't been charred beyond serviceability, and the fault is a result of an open winding, it might be an easy matter to procure the proper gage Nichrome wire, and rewind it. Materials: $1.00 Cessna was the same, very expensive for a dimmer but we found a different source. Well, you can't blame the manufacturers for trying to make a profit, but attempted price gouging because they officially have a monopoly on an approved part that is comparable to those priced at 1/10th won't endear them to their customers. |
hasn't been charred beyond serviceability, and the fault is a result of an open winding, it might be an easy matter to procure the proper gage Nichrome wire, and rewind it. Materials: $1.00 Have you ever taken one apart and tried to rewind it? |
On Fri, 09 Sep 2005 18:17:55 GMT, john smith wrote in
:: A dimmer is nothing more than a wire-wound rheostat right? If it hasn't been charred beyond serviceability, and the fault is a result of an open winding, it might be an easy matter to procure the proper gage Nichrome wire, and rewind it. Materials: $1.00 Have you ever taken one apart and tried to rewind it? I have not taken a Cessna nor Bonanza dimmer apart, but I have rewound rheostats and coils. But then I'm an IBEW trained, card-caryin' Journeyman Wireman 'A', and electronics technician. Such a task may not be for everyone, just as some find soldering difficult. |
![]() Larry Dighera wrote: Right now I have one dimmer switch that is belly up. Mechanic says $350 from Beech but he will check his other sources and get a cheaper one. A dimmer is nothing more than a wire-wound rheostat right? If it hasn't been charred beyond serviceability, and the fault is a result of an open winding, it might be an easy matter to procure the proper gage Nichrome wire, and rewind it. Materials: $1.00 I went flying today and saw that my mechanic had fixed the rheostat, don't yet know what he did. I have Nulites and now the panel looks really cool. |
On Fri, 09 Sep 2005 14:10:12 -0600, Newps wrote
in :: I went flying today and saw that my mechanic had fixed the rheostat, don't yet know what he did. I have Nulites and now the panel looks really cool. Great. I'll bet it was an easy fix; it's a very simple system: http://www.nulite.net/electrical.htm |
Larry Dighera wrote: On Fri, 09 Sep 2005 14:10:12 -0600, Newps wrote in :: I went flying today and saw that my mechanic had fixed the rheostat, don't yet know what he did. I have Nulites and now the panel looks really cool. Great. I'll bet it was an easy fix; it's a very simple system: http://www.nulite.net/electrical.htm Another high priced product. Google "electroluminescent rope" |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Mountain flying knowledge required? | Peter R. | Piloting | 76 | May 1st 05 06:52 PM |
Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 01:54 AM |
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 08:48 PM |
Ten Years of Flying | Jay Honeck | Piloting | 20 | February 19th 05 02:05 PM |
