How did he make this joint?
Old September 10th 05, 03:05 AM
Michael Horowitz
Default How did he make this joint?
At http://members.cox.net/mhorowit/interesting weld with comment.jpg
is a pic of two tubes welded at 90 degrees.
Any idea how he got any strength to the joint? I don't think either
tube had any metal removed for fitting. - Mike
Old September 10th 05, 05:08 AM
"Michael Horowitz" wrote in message
The correct link:
The image is at the bottom of this page: http://members.cox.net/mhorowit/
(spaces should NEVER be used in the path)
Old September 10th 05, 01:30 PM
Michael Horowitz
Thanks - worked at this end - MIke
So what did you think about the weld?
The correct link:
Old September 16th 05, 04:15 PM
John T
Can't really see where this joint is in the whole setup. Not much
perspective on it.
John
Old September 16th 05, 07:14 PM
perspective on it.
Uh huh. I don't see any welds that actually join the
horizontal tube to the vertical.
The center section of the horizontal tube appears to be belled
at each end so as to slip over separate pieces of tubing and
then welded near the shoulder of the bell instead of out at
the lip as one would with normal socket-weld fittings.
It kinda looks like the back side of the center section is
cut away to create a saddle shape that could be, but has
not yet been, welded to the vertical tube.
FF
Showstoppers (long, but interesting questions raised) Anonymous Spamless Military Aviation 0 April 21st 04 06:09 AM
