Using WINMiter
Old September 10th 05, 11:11 PM
Michael Horowitz
Default Using WINMiter
Do you use the template to trace the pattern on the tube, or do you
glue the template to the tube and keep it there while cutting? - Mike
Old September 11th 05, 02:46 PM
Ken Moffett
Michael Horowitz wrote in
Which ever works for you. I just wrap it around the tube, tape it in place,
and grind to the line on the paper.
Old September 17th 05, 12:33 AM
Ernest Christley
Wrap the paper tight, lining up the marks and tape across the joint.
Twist the paper around to clock it right. Slap on another piece of
tape, with about 1/8" laying on the tube. Cheap scotch tape wants to
come apart rahter than off, and you just need a little to hold it in place.
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
Old September 21st 05, 08:16 PM
I cut out the template and tape it to the tube, then use a Sharpie
marker to trace the pattern. Then take off the template and grind
away.
Dave
www.davewilson.cc
Old October 6th 05, 06:09 PM
Richard Lamb
I know this is a late response, but (for what it's worth) my trick is
to wrap the pattern around the tube (in the correct place?) and
spray a little white krylon on the exposed tube.
Then grind off the painted area.
Richard
Old October 7th 05, 02:44 AM
Ernest Christley
Richard
Richard, that will work just fine, but it requires that you carefully
cut out the template. Rough cut and tape to the tube, then just cut to
the line.
Old October 11th 05, 11:16 PM
Richard Lamb
Problem is ----
The paper catches on fire!
OOOps!
Richard (call the fire dept) Lamb
