NTSB: USAF included?
Old September 11th 05, 11:33 AM
Larry Dighera
Default NTSB: USAF included?
Dear Mr. Larkin,
Thank you for your input regarding this civil/military MAC that
occurred in Warner Springs, California on April 20, 1986. Because
your original text was formatted as part of the quoted text you
included, it was difficult for me to determine which was which, but I
hope I got all your original input in the quote I include below.
Because you had personal familiarity with one of the aircraft involved
in this mishap, your comments are particularly relevant. I will
attempt to respond to your comments in-line within the body of your
comments.
[I have also included the full text of the article to which you are
following up at the tail end of this one.]
On Sat, 10 Sep 2005 07:34:56 +0100, KenLarkin
wrote in
Agreed. I'm just attempting to provide constructive suggestions for
adequate flight safety. Perhaps someone with your experience would be
more successful in suggesting more reasonable safety measures.
Using an ineffective radar for collision avoidance is neither as
obvious
nor as smart as using a sectional and a phone/radio call to FSS
to avoid hot MTRs.-
I would like to shed some light on the capabilities of the A7E radar to
help illuminate the discussion. I happen to know a great deal about A7E
Radar, as well as its inertial navigation system, computer systems,
Doppler radar, and weapons control systems since I was in charge of the
Integrated Weapons System (IWT) shop at VA27 that had the responsibility
of maintaining these systems on LT Hutcheson’s aircraft at the time of
this incident.
The forward looking radar on the A7E has several modes of operation
including terrain following, terrain avoidance, search, ground tracking
of targets, and yes, navigation. But please keep in mind that it was
1950’s technology. If the radar detects a pending near-air collision,
it is designed to provide a flashing break-X or other indicator in the
pilot’s heads-up display system and loud audible alarms in his headset,
so your question that “Would you rather have a pilot heads-down staring
at an ineffective radar display or heads-up scanning for traffic?” may
not be applicable.
I know it is tedious to interpret who said what in the original
article, but it was actually Dave Hyde (a Navy veteran if I recall
correctly) who posed that rhetorical question, not me.
With regard to the visual and aural warning of impending "near-air
collision" capabilities of the A7E's forward looking radar, is that
warning system active in all modes of this radar's operation, or just
in navigation mode?
I do not know what happened on this occasion. I do know that if the
pilot had received any warning from the system, it would have been
recorded on the flight recorder and presented to the investigating
authorities. That leads me to suspect that this situation was
instantaneous and immediate. I know that sounds like a redundancy, but
I am trying to convey that this happened so rapidly that “no one” had
any possibility to react.
It would be interesting to know if such a warning was indeed recorded
by the A7E's flight recorder. Have you any idea how one might obtain
a complete copy of the Navy's investigation report of this mishap?
The near instantaneous nature of this mishap points out the point I
was attempting to make: As currently designed, joint-use Military
Training Route airspace fails to protect pilots from mid-air
collisions. While it is true, that all pilots, military as well as
civil, are mandated by federal regulations to be familiar with all
information pertinent to their flights, it has been my experience,
that current MTR activity status is often difficult to obtain. And
given the 2 hour prior notice requirement contained in:
Order 7610.4J Special Military Operations
Chapter 11. MILITARY TRAINING ROUTES (MTR)
Section 9. VR ROUTE USE
11-9-1. SCHEDULING
a. Each VR route shall have a designated military unit responsible
for scheduling all military flights intending to use the VR route. If
the designated military unit does not have a continuous point
of contact; i.e., a unit subject to deployment or a unit not
available during normal work days (ANG unit working
Wednesday-Sunday), then an alternate scheduling agency
shall be designated. All flights on the VR route will be
scheduled through the primary or alternate scheduling agency.
b. The scheduling activity shall confirm on a daily basis (to the
extent practicable, prior to 2400 hours) with the tie-in AFSS/FSS
of the planned utilization of the route. Unless otherwise agreed,
such scheduling shall be accomplished at least 2 hours prior to
use. Scheduling agencies shall provide an hourly schedule for
each route which includes route number, aircraft type and number,
proposed entry/exit time, and altitude. Scheduling agencies should
make every effort to pass changes as soon as possible to the
tie-in AFSS/FSS when a particular route is closed or a scheduled
aircraft cancels.
EXAMPLE-
VR101 0900-1000 2/F-14
0915-1000
SFC B-50 MSL
1000-1100 None
1100-1200 4/F-14
1105-1150
20 MSL-40 MSL
VR102 0900-1000 1/T-38
0902-0944
30 MSL-40 MSL
1000-1100 1/F-14
1000-1015
SFC B-50 MSL
1100-1200 None
A pilot who has checked with the Flight Service Station prior to
departure on a flight that exceeds 2-hours, may find himself within a
hot Military Training Route that was cold before departure. And the
FAA and military's absurdity of reliance on see-and-avoid for aircraft
separation is criminal at closing rates in excess of 500 knots.
I know a great deal about aircraft, but I know nothing about being a
pilot. Unlike you folks, I don’t know anything about flight rules, or
plans, or regulations. One thing I do know, however, is that flying is
inherently dangerous and sometimes there may simply be no “right or
wrong” in a situation.
In my opinion, it is the FAA's and the military's responsibility to
assure that the dangers in flying the National Airspace System are
minimized. As evidenced by the mishaps appended to the end of this
article, it is apparent that the current regulations governing MTR
operations fail to achieve that mandate.
I believe that it may be possible that the A7E (which is a “light
attack” aircraft and not a fighter, of course) and the glider could
have both acted entirely appropriately within the conditions they were
presented, and yet still collided.
That is because you are ignoring the Federal Aviation Regulation
governing right-of-way: Gliders have the right-of-way over powered
aircraft.
I don’t know the actual conditions, and from what I read, you really
don’t either.
All I know about this MAC is what the NTSB reported and the accounts
published by the pilots involved.
Some things can be over analyzed.
In this case it seems that one federal body erroneously exonerated
another at the expense of the truth and public safety.
I DO know the nature, character, and training of LT Hutcheson, however,
Other than Lt. Hutchenson's apparent assumption that he had MTR
airspace clear of conflicting air traffic, and the NTSB's support of
that notion, I have no problem with his actions. It is the failure of
the FAA and military to provide a safe and workable MTR system within
the NAS that I find dangerously unacceptable if not criminal.
and I know the thoroughness with which the Navy deals with aviation
accidents. Both are outstanding. I also know that there were no
instrumentation alerts recorded either before or after the collision.
That is a bit of welcome information. To what would you attribute the
A7's radar's failure to issue such a warning? Could it have been
because of the particular mode of operation it may have been in at the
time of the MAC, or an inadequacy of the warning system's operation?
Thank you for your time and courtesy, and I apologize for entering into
a conversation beyond my depth.
K. J. Larkin
KenLarkins
Thank you for your contribution to this issue, Mr. Larkin. There is
no need for you to apologize; you have provided information that may
be useful in understanding one of the MTR system's operational
shortcomings.
======= Original Article to which Mr Larkin is responding ==========
Newsgroups: rec.aviation.piloting
Subject: NTSB: USAF included?
Message-ID:
Date: Mon, 21 Jul 2003 20:00:27 GMT
For others following this message thread, here are the stories written
by the pilots involved:
March 1988
The Naval Aviation Safety Review (pp 11-13)
US Navy
Approach looks at low-level flying
The Hop Was Perfect ... Except for the Midair
By Lt. K. C. Hutcheson
What a great day to go flying! It was a beautiful Sunday afternoon in
southern California. My trusty Corsair and I were returning home from
a good cross-country weekend. Fighertown base ops was accommodating
as usual. Being an infamous cross-country pilot, I began checking
every preflight planning block.
I planned to fly a local low-level training route that would take me
on a scenic tour of southern California, then fly back home. This had
all the makings of a great hop -- great weather, great airplane, great
countryside and flight time. The preflight, man-up and takeoff
confirmed my expectations, and the Flight Service Station even
answered my call when I checked in on the first point of the route, a
rare occurrence at best. It was, in fact, a beautiful day, hardly a
cloud in the sky. I was thoroughly enjoying myself as I approached my
next to last check point. The point was a mountain peak with ranger
tower on it, and as I arrived, I made a left turn to the last leg of
the route. As I was rolling out I saw him -- a glider just on the
other side of the ridge. He was pointed straight toward me as I was
rounding the peak.
A few seconds after spotting me, he must have realized that my turn
put us on a collision course and that I couldn't see him in his small
cross-section sailplane. He dropped his nose and right wing to show
me some plan form and to try to get away.
My entire body was filled with terror when I saw nothing but glider in
my windscreen as I pulled back on the stick while screaming into my
mask. It was only a moment before we collided, but I found it was
plenty of time to ponder my autobiography from birth to my sudden new
interest in purchasing some rural real estate. I thought I was in the
archives for a second there, and my dreamy Sunday afternoon had
violently become a nightmare.
The next few moments were filled shouting every expletive known to
mankind until I realized that I had actually survived a head-on midair
and my combat proven Corsair was still flying. I knew that I hit the
left wing of the glider but wasn't exactly sure where he contacted my
aircraft. My new vibrations felt and sounded like airframe
vibrations, and I thought that perhaps I had pulled up enough to only
get a glancing blow to the bottom of the corsair. My mind was filled
with visions of the glider pilot and what happened to his frail
aircraft. I looked over my shoulder for him but saw nothing. I
thought the impact certainly must have ripped his wing off at the root
and he was spiraling down into the mountainside. We're talking some
high anxiety here!
I figured there was nothing I could do for him now anyway, so I
started climbing toward Miramar only 30 - 40 miles away. I finally
began to settle down and told Approach what happened. I reviewed the
structural damage part of the NATOPS Pocked Checklist to make sure I
wasn't forgetting anything as I proceeded overhead for my dirty-up and
controllability checks. A visual check by an airborne Tomcat
confirmed that my control surfaces weren't damaged and the Corsair was
controllable in the landing configuration. I hadn't experienced any
engine instrument fluctuations, but when I added some power to stop my
deceleration, the engine sounded like a box of rocks, shaken
vigorously. Good deal, I made a precautionary approach to a field
arrestment.
Upon shutdown, the engine made all sorts of clickety-clackety noises,
and when I climbed out of the cockpit, I could see where the glider
had hit. There was a jagged hole about the size of a football in the
intake with fiberglass wing fiber packed in it. You could also see
white scraped paint streaks swirling down the intake and visible FOD
to the first stage blades. The tailpipe still had bits of fiberglass
from the glider wing in it. A runner from base ops came out to tell
me that the FAA called, and although losing 3 feet of his wing, the
glider pilot had landed safely.
Once again the big sky - little airplane theory had been disproven.
Anyone who has flown airplanes for any significant length of time has
had a close call with another aircraft, or *will* have one. I have
around 1,200 jet hours, and this was the third time I have seen a
small civilian aircraft without enough time to avoid it. Fortunately,
the other times I wasn't that close, and it just surprised me.
The amount of VFR traffic in the United States in becoming enormous,
especially in the southern California area. Two gliders or two light
aircraft flying at VFR altitudes are not too bad, but throw in a
military jet on a training route at 400 plus knots, and you have a
serious problem. Jets at that speed are incapable of "seeing and
avoiding" small cross-section targets, especially if they have no
crossing angles. Civilian pilots must become educated on the danger
to *them* of military training routes and where they are and hot to
find out if they are active or not.
This incident has reinforced another point to me that I have already
learned and generally live by, and that is preflight planning. On
many occasions I have found myself walking to an aircraft realizing
that there were a couple of more things I could have to better
prepare. Fortunately, for me, that wasn't the case on this flight. I
had made all the appropriate calls to schedule the route and read all
the route restrictions. Even as prepared as I was to go on a simple
hop on a beautiful day, near disaster struck. All that preflight
planning had absolutely no effect on the collision itself, but imagine
if I had be violating a published restriction due to ignorance and an
unprofessional approach to preflight planning. That would have made
standing in front of the big green table and answering very painful
and not too career-enhancing questions. Even something unrelated to
an actual mishap will come out in an investigation, and the finger
will be pointed at you if your performance has been less than
acceptable.
Every time you man up, you should be convinced that you have "checked
all the blocks" in your preflight planning. If your hop should turn
into a nightmare through no fault of your own, you will avoid a lot of
heat. Most importantly, it's the best to stack the safety odds in
your favor
Lt. Hutcheson flies A-7Es with VA27
And for the glider pilot's viewpoint, we offer his story.
Perspective:
An Unfortunate Way to Start the Season
By Chip Garner
It was the first good soaring day that I had found last Spring. I
took off at Hemet-Ryan airport at about 1 p.m. and headed southeast.
The lift was good; I was able to work 5 to 6 knot thermals to about
9,000 feet MSL over the mountains. The terrain is at about 5,000 to
7,000 feet in this area and drops off spectacularly to the east to the
Anza-Borego Desert and the Salten Sea at 235 feet below sea level. My
radio quit after about 45 minutes of flying for some unknown reason.
The lift was weakening as I went south and I had no crew so I turned
back.
I headed north toward the Idyllwild area and was staying within easy
reach of Warner Springs Airport but couldn't find anything good. I
mosied along north and was looking for lift near Warner Springs in the
vicinity of, and about level with, the lookout tower five miles east
of the airport. I was flying into a canyon when I saw a military jet
come over the ridge headed on a long radius arching turn that would
obviously intersect with me. I initiated a right turn and started
nosing down, but the jet was coming on very fast. I did not want to
bank too far because I was very aware that banking would increase my
collision cross section from the jet, so I compromised and banked
somewhat. I kept hoping that the jet would straighten out and miss me
by several hundred feet or more, but this opportunity was disappearing
with astonishing speed. I thought I was going to go through the large
circular object under his wing, which I thought was an engine and
later leaned was a drop-tank. At about this time the jet pilot
apparently saw me and pulled up. I continued to push down and started
to bring the left wing down (I had banked right to turn away) so it
would clear the jet. It looked like we would just clear, and I
thought I would probably have to report the near=miss.
About one to two seconds after the jet pulled up, there was a loud
bang and the glider shook, but did not yaw, as he went by. My radio
came back to life, and there was dust flying around in my cockpit. I
thought the loud bang had been from his wake at such close quarters,
but I immediately looked out and saw damage to my left wing. I then
looked down and felt some discomfort at the thought of bailing out (I
was at about 800 feet over steeply rising terrain) and initiated a
left turn toward Warner Springs Airport and toward more ground
clearance. The ship turned nicely, which was very pleasing and led me
to think that the damage must be minor. I was relieved not to see any
crashed jet aircraft in the valley.
Of course, I hit a great thermal a mile or so on the way toward Warner
Springs Airport. I started climbing and announced my predicament on
the radio, which caused a lot of commotion. I started thinking about
soaring the 40 miles back to Hemet as I got higher (I was within final
glide for 15-meter LS-4) and began wondering how to estimate my L/D.
I got some good advice on the radio. Curt Hawkins in sailplane side
number CJ and others pointed out politely that flying back to Hemet in
a damaged glider when Warner Springs was in easy reach was a dumb
idea, and offered to come get me. Jack Gravance in HL Suggested that
I check my dive brakes, gear, slow flight and control travel while I
had altitude. Bob Backer in 3S came in below me in the thermal and
reported that I had lost about a meter of my left wing and that there
was a piece hanging down.
I climbed a while and then flew a mile or two further out into the
valley and tried slow flight, faster flight, gear, diver brakes and
turns in both directions. I then dumped my altitude and entered a
left-hand pattern for the west-facing runway at Warner Springs.
Flying the pattern I noticed a large loss of L/D. I got scared as my
options narrowed on approach *I hadn't had time to get scared
earlier), but landing was easy and normal.
Postflight Analysis
I estimate that I had the jet in sight for five to 10 seconds and that
he saw me and pulled up about one to two seconds out. He was in an
A-7 traveling at 360 knots, terrain following on a low-level route,
and I was coming more or less head-on at about 60 to 65 knots. I
probably saw him first because I was headed directly toward the jet
when I first saw it and was headed nearly toward it the whole time,
presenting a very small visual cross section. If the Navy A-7 pilot
hadn't been flying heads-up, I don't think I would be writing this
story.
Private aircraft are allowed to fly in military low-level training
routes but are discouraged from doing so. The rule is as always, see
and avoid. The Navy pilots I spoke to usually fly at either 360 or
450 knots, and the routes are between 200 and 1,500 feet AGL and
usually extend to NM on either side of the centerline mark (as little
gray lines) on the Sectionals. Judging from my experience, if you are
lucky and happen to be looking in the right place at the right time,
you might see, but do not have time to avoid. In retrospect, the best
thing I could have done when I saw the A-7 would have been to
immediately bank away to show him as much wing area as possible, and
to hope he saw me in time. (An even better thing would have been to
avoid the low-level route.) The difference in maneuverability between
an A-7 and an LS-4A is awesome. Turning away would have required
relinquishing the illusion of control I had over the situation and
would probably have caused me to loose [sic] sight of the jet under my
belly, which is why I did not.
Aftermath
The aftermath of this incident was in some way more traumatic than the
collision itself. (Although I have subsequently taken an occasional
extremely fast, hard look at a speck on my canopy.) When I landed, I
got a call from the Navy spokesman, who informed me that the jet I had
collided with was a shingle-engine a07 and that the pilot had landed
safely at Miramar. He had had trouble of his own swallowing my tip
down his engine (I think it nearly choked on the aileron hinges) and
could not come back for a look; he was certain he had killed me. The
sheriff and the fire department showed up and wanted reports, and I
also got a call from the FAA, who also wanted a report . A TV station
from San Diego showed up (also wanting reports), and some friends from
Hemet appeared and rescued me and my 14 meter LS-4a. About a meter of
wing was gone, and the aileron was gone for another 1/2 meter and was
split at the trailing edge.
The following week I cooperated with four separate investigations by
the NTSB, the FAA and both a legal and safety investigation by the
Navy. I also had to explain things to my partner, Stan Foat, and
spent a lot of time on the phone trying to find an LS-4 wing.
Alen Bikle rebuilt our wing tip, and we ordered a new aileron from
Germany and were flying again in June. We collected some
reimbursement (half of what my partner and I asked for) from the Navy,
contending that gliders have the right of way even in low-level
routes. The navy people were very straightforward, and I enjoyed
dealing with them -- I did not encounter the bureaucratic ineptitude
that I expected.
I no longer ignore the little gray lines on my Sectionals.
Reprinted from Soaring and Motorgliding.
It's obvious the Navy felt culpable, and settled the matter. The
NTSB's failure to recognize the violation of regulations is
pathetically telling about their lack of objectivity.
The military pilot's statement, "...this was the third time I have
seen a small civilian aircraft without enough time to avoid it." is
first hand evidence that high-speed, low-level military operations as
currently regulated are unsafe, and should be curtailed.
On Tue, 15 Jul 2003 22:08:42 GMT, Larry Dighera
wrote in Message-Id: :
On Sat, 12 Jul 2003 00:27:02 GMT, Dave Hyde wrote in
Message-Id: :
Larry Dighera wrote:
I can readily understand the physics involved in such a "reduction" in
pilot ability so spot the frontal area of an inconspicuous (lights
out) fighter airplane traveling at ~500 knots.
In the example we are discussing, which airplane was flying with
no lights? Which one was flying at 500 knots? While an A-7 might push
500 on some legs of a low level it's not likely he was that fast
masking in the mountains. The glider pilot reported (how he knew
is not stated) that the A-7 was at 360 KIAS. Fast, but not that fast.
350 KIAS is about **44%** faster than the FAA/CAA felt was a safe
speed below 10,000' for mere (civil) mortals (FAR Sec. 91.117).
http://www.fas.org/man/dod-101/sys/ac/a-7.htm
The A-7's Max level speed at sea level is 600 knots.
Back in the timeframe of this accident it's unlikely that you'd find
an A-7 on a low-level (intentionally) without lights, as well, day or
night.
I was thinking that the Navy's prudent sense of AIR SAFETY might
prompt them to enhance the conspicuity of the A-7 while it's operating
44% faster than non-military aircraft below 10,000' amongst slow civil
aircraft.
http://www1.faa.gov/ATPubs/AIM/Chap4...03.html#4-3-23
§ 4-3-23. USE OF AIRCRAFT LIGHTS
c. The FAA has a voluntary pilot safety program, Operation Lights
On, to enhance the see-and-avoid concept. Pilots are encouraged to
turn on their landing lights during takeoff; i.e., either after
takeoff clearance has been received or when beginning takeoff
roll. Pilots are further encouraged to turn on their landing
lights when operating below 10,000 feet, day or night, especially
when operating within 10 miles of any airport, or in conditions of
reduced visibility and in areas where flocks of birds may be
expected, i.e., coastal areas, lake areas, around refuse dumps,
etc. Although turning on aircraft lights does enhance the
see-and-avoid concept, pilots should not become complacent about
keeping a sharp lookout for other aircraft. Not all aircraft are
equipped with lights, and some pilots may not have their lights
turned on. Aircraft manufacturer's recommendations for operation
of landing lights and electrical systems should be observed.
Is the A-7 even capable of displaying a landing light at that speed?
Aren't they tucked in the gear wells out of sight?
I hear that the Romulan cloaking device was inop too.
Untrue.
When an aircraft is on a collision course with your aircraft, it
presents its smallest silhouette (frontal area) to your view. At ~500
knots it is virtually physically impossible to visually spot it IN
TIME to maneuver out of its way. For this reason, I believe the
military should bear _exclusive_ responsibility for
see-and-avoid/seperation while operating under exemption from Federal
Aviation Regulation, at high-speed below 10,000' within the NAS, on or
off MTRs, except in time of actual combat.
It's simple logic. The military should be solely responsible for the
safety hazard their high-speed operations below 10,000' create.
Placing responsibility for separation on the civil aircraft operating
in compliance with Federal Aviation Regulations is absurdly contrary
to the laws of physics, and woefully unjust.
Even better, would have been for the fighter pilot to give way to the
aircraft that had the right-of-way by virtue of the regulations both
pilots were duty bound to follow.
You should read the supplemental info.
Your mail had not yet arrived at my box when I checked on Monday.
*BOTH* pilots were _trying_ to give way.
That's my point. It's physically impossible to see-and-avoid at
high-speed.
Trying and failing cannot be construed as _complying_ with
see-and-avoid regulations.
You'll see that *neither* pilot was reported for failure
to see and avoid, but that the glider pilot was written up for his
decision(s) to loiter in the published, active, and reported active
MTR.
I don't see where the glider pilot was "written up for his decision(s)
to loiter in the published, active and reported active MTR":
http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=1
The National Transportation Safety Board determines the probable
cause(s) of this accident as follows:
PREFLIGHT PLANNING/PREPARATION..IMPROPER.
IN-FLIGHT PLANNING/DECISION..IMPROPER.
CHECKLIST..POOR.
The truth is, the military pilot's actions weren't merely improper,
they were contrary to _regulations_, but the NTSB failed to mention
that.
Apparently you don't agree that MTR airspace is Joint Use. Civil
aircraft are not prohibited by regulations from flying within Military
Training Routes. It's Russian Roulette, but not prohibited.
AIM 3-5-2
2. (f) Nonparticipating aircraft are not prohibited from flying
within an MTR
The glider pilot did not violate any Federal Aviation Regulation
solely by operating within the active MTR, and the NTSB report didn't
find that he did.
(and I think I'm duty-bound by the charter of the newsgroup to
report that an A-7E is not a "fighter" :-)
I appreciate your insistence on accuracy.
http://www.fas.org/man/dod-101/sys/ac/attack.htm
Attack aircraft, delivering air-to-ground munitions, are deployed
in force application and air control roles.
One wonders why the A-7 radar
wasn't used to spot the glider in advance of the impact?
How effective do you think the APQ-126 is at spotting
small fiberglass airplanes in ground clutter?
Hint: It's an air-to-ground radar.
I have no experience with on board military radar.
Would you rather have a pilot heads-down staring at an
I would prefer that the military aircraft operating on MTRs employed
some technology to augment the pilot's ability to prevent colliding
with civil aircraft. Perhaps something like TCAS would less of an
anachronism for this purpose than the "Mark-1 Eyeball."
A study employing highly trained military pilots determined that
17-seconds out of every 20-seconds was required to scan for
conflicting traffic. That leaves only 3-seconds remaining out of
every 20-seconds for head-down instrument scan.
http://www.aopa.org/asf/publications/sa15.pdf
"An experimental scan training course conducted with military
pilots found the average time needed to conduct the operations
essential to flying the airplane was 20 seconds – 17 seconds for
the outside scan, and three seconds for the panel scan. Without
the benefit of intensive military training, most pilots will need
more time than this. But as demonstrated by the military pilots,
considerably more time should be spent on the external scan than
the panel scan."
An aircraft traveling at 250 knots will travel ~1.4 NM in 20
seconds. If 20 seconds are required to visually detect conflicting
traffic, and one adds to that
* the additional time necessary to recognize the
(intentionally very inconspicuous) military attack traffic
as being on a conflicting course
* the time to make appropriate deconfliction control inputs
* the time it takes the aircraft to respond to those inputs
and maneuver out of harm's way
it becomes readily apparent that the PIC is tasked with the
impossibility of visually locating the conflicting aircraft
when it is much greater than 1.4 NM distant, or face disaster.
Of course, the pilot of a military aircraft operating on a MTR at ~500
knots will only have half the time given in that example. Further,
the above calculations do not take into consideration the speed of the
other aircraft, which may significantly increase _closing-speed_. The
physics involved realistically preclude visual separation of
high-speed military operations from reliably occurring, but currently
the FAA erroneously permits it, indeed mandates it by official
regulation.
Currently, a civil PIC is required to visually observe the tiny speck
offered by the minimal frontal profile of the military aircraft
operating on the MTR (traveling well in excess of 250 knots, and not
burning a landing light) at substantially (2 to 4 times) more than 1.4
NM distant to successfully avoid it.
I submit that the likelihood of a non-military trained pilot
accomplishing visual separation from military aircraft operating on
MTRs is effectively nil. Therefore, it would seem that the FAA is
failing to meet its responsibility to provide safe skies by permitting
high-speed low-level operation of military aircraft while relying on
physical calculations which indicate that see-and-avoid is physically
inadequate for separation of these aircraft in excess of 250 knots.
Perhaps it's time for a change:
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgFAR.nsf/0/c85fcc2b24fc2ead86256962005b584c!OpenDocument&High light=special%20use#_Section1
The use of radar aboard the A-7 for collision avoidance seems obvious.
I don't think you know very much about the A-7 radar.
Using an ineffective radar for collision avoidance is neither as obvious
to avoid hot MTRs.
I don't think you have much experience in attempting to obtain MTR
information from FSS:
http://www.aopa.org/whatsnew/newsite...00-4-066x.html
AOPA's Vice President for Air Traffic Melissa Bailey noted that it
is difficult for pilots to obtain information about activity on
MTRs. "We've been pushing FAA and the military for years to make
real-time information on military flight activities available to
civilian pilots."
I'd be most interested in the information contained in those articles.
They're on their way.
Many thanks for your kindness in sending that information. When I
have read it, I'll provide my comments.
Why do you make it sound like it was solely
Mr. Garner's responsibility to avoid the military jet?
Because I don't think ROW was the issue here.
I would be most appreciative of your divulging your thought process
that lead you to that conclusion. It seems erroneous to me.
Neither pilot failed to see the other.
That has nothing to do with right-of-way.
Neither pilot was faulted for failure to see and avoid.
NTSB's omission was in error.
The NTSB _has_ addressed "the inherent limitations of the see and avoid
concept of separation of aircraft operating under visual flight rules"
[...on MTRs], but their conclusions are/were not to your statisfaction,
I suspect.
That has nothing to do with right-of-way either. The aircraft were of
differing Categories. The USAF and FAA regulations concur,
(civil) gliders have right-of-way over powered (military) aircraft in
peacetime.
One pilot used the system as it was intended and followed
procedures intended to prevent midairs
The military pilot failed to comply with:
FAR Sec. 91.113 (d)(2) Right-of-way rules
"A glider has the right-of-way over an airship, airplane, or
rotorcraft"
FAR Sec. 91.13(a) Careless or reckless operation"
"No person may operate an aircraft in a careless or reckless
manner so as to endanger the life or property of another."
FAR Sec. 91.111 Operating near other aircraft.
"(a) No person may operate an aircraft so close to another
aircraft as to create a collision hazard."
And, though authorized:
FAR Sec. 91.117 Aircraft speed.
"(a) Unless otherwise authorized by the Administrator, no person
may operate an aircraft below 10,000 feet MSL at an indicated
airspeed of more than 250 knots (288 m.p.h.)."
(I am aware that military pilots are required to follow AFI11-202. As
I am familiar with FARs, I quote them. AFI11-202 parallels FARs in
these areas.)*
- the other pilot did not.
While the glider pilot may not have ATTEMPTED to ascertain the current
status of all the MTRs within 100-miles of his route, _regulations_
would NOT have prevented him from operating within the MTR structure.
I do not see right-of-way as a blanket absolution
and/or reason for chucking what I (and the NTSB, as reported)
see as the major causal factors in this mishap.
Obviously there are more contributory factors to this mishap than the
military pilot's failure to comply with FAR Sec. 91.113 (d)(2)
Right-of-way rules. But it would seem to be fundamental. And the
NTSB's failure to note it implies that it is either superseded in this
case by other regulations, an error of omission by NTSB, or deliberate
NTSB bias.
The bottom line is, that the FAA has failed to provide air safety by
granting military MTR operation as it is currently regulated, IMNSHO.
* http://www.e-publishing.af.mil/searc...I11-202&page=2
22 AFI11-202V3 6 JUNE 2003
5.5. Right-of-Way Rules . Usually, right-of-way is given to the
aircraft least able to maneuver, which normally permits that
aircraft to maintain course and speed. However, visibility
permitting, each pilot must take whatever action is necessary to
avoid collision, regardless of who has the right-of-way. When
another aircraft has the right-of-way, the yielding aircraft must
not pass over, under, abeam, or ahead of the other aircraft until
well clear.
5.5.1. Distress . Aircraft in distress have the right-of-way over
all other air traffic.
5.5.2. Converging. When converging at approximately the same
altitude (except head-on or approximately so), the aircraft to the
other’s right has the right-of-way. Aircraft of different
categories have the right-of-way in the following order of
priority:
5.5.2.1. Balloons.
5.5.2.2. Gliders.
5.5.2.3. Aircraft towing or refueling other aircraft.
5.5.2.4. Airships.
5.5.2.5. Rotary or fixed-wing aircraft.
5.5.3. Approaching Head-On . If aircraft are approaching each
other head-on or approximately so, each shall alter course to the
right.
5.5.4. Overtaking Aircraft . An overtaken aircraft has the
right-of-way. The overtaking aircraft must alter course to the
right.
Irrational beliefs ultimately lead to irrational acts.
-- Larry Dighera,
=========== Civil/Military MACs Within the CONUS ============
On 28 Jan 2004 19:21:29 GMT, Laurence Doering wrote in
Message-Id: :
The worst military vs civil midair in the US was probably the
one between a Navy F-4 and a Hughes Airwest DC-9 near Duarte, CA
on 6 June 1971. Both aircraft were destroyed, with 49 fatalities
aboard the DC-9. One of the F-4 crewmembers survived.
According to the NTSB accident database there have been more.
Their online database is searchable back to 1962. I didn't
feel like searching for every type of military aircraft I could
think of, but since 1962 there have been the following midair
collisions between civil aircraft and military F-4s, F-14s, and
F-16s in the United States:
06 Jun 1971
The above midair between a Navy F-4 and a DC-9.
http://www.ntsb.gov/ntsb/brief.asp?ev_id=59912&key=0
PROBABLE CAUSE(S): PILOT IN COMMAND of DC-9 - FAILED TO SEE AND
AVOID OTHER AIRCRAFT. REMARKS- BOTH CREWS HAD ONLY MRGL CPBLTY TO
SEE AND AVOID.OTR C/F -ATC SYS LTD,PRECLUDED EFF IFR/VFR SEPN.
http://www.ntsb.gov/ntsb/brief.asp?ev_id=59913&key=0
PROBABLE CAUSE(S): USMC PILOT IN COMMAND of F-4B - FAILED TO SEE
AND AVOID OTHER AIRCRAFT. REMARKS- OTR C/F-CREW OF USMC458 FAILED
TO REQ RARAD SVC,TINOP.OTR C/F INCL VERY HIGH CLOSURE RATE BTN
ACFT
16 May 1975:
A USAF RF-4C collided with a Schweitzer 2-32 near Colorado Springs,
CO. Both aircraft landed safely
April 20, 1986, in Warner Springs, CA between a USN A7E and Rolladen-Schneider
LS-4 Glider. NTSB Identification: LAX86MA186A.
http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=2
probable cause(s) of this accident as follows:
PREFLIGHT PLANNING/PREPARATION..IMPROPER..PILOT IN COMMAND
IN-FLIGHT PLANNING/DECISION..IMPROPER..PILOT IN COMMAND
CHECKLIST..POOR..PILOT IN COMMAND [glider pilot found to be at
fault by NTSB despite Navy paying for damages to glider.]
The NTSB found A7E pilot not to be at fault despite the regulatory
requirement to see-and-avoid!
09 Jan 1983
An ANG F-4C collided with a Beech Baron in the Atlantic
Coastal ADIZ about 30 miles from Cherry Point, NC. All
7 aboard the Baron were lost at sea, and the F-4 landed
safely. The F-4 was attempting to intercept and identify
the Baron, which was flying direct from Nassau in the Bahamas
to Norfolk, VA even though the pilot had filed a flight plan
from Nassau to clear customs in Fort Pierce, FL and then on
to Norfolk.
http://www.ntsb.gov/ntsb/brief.asp?e...14X41935&key=1
SECONDS BEFORE THE COLLISION, THE BE-D55 TURNED LEFT AS REQUESTED
BY FAA ATC THUS TURNING IT INTO THE PATH OF THE OVERTAKING
INTERCEPTOR WHICH ALSO HAD TURNED LEFT TO BREAK OFF THE INTERCEPT.
THE SAFETY BOARD DID NOT DETERMINE THE PROBABLE CAUSE OF THIS
ACCIDENT, BUT OFFERED STATEMENTS OF CAUSE.
http://www.ntsb.gov/ntsb/brief.asp?e...14X41935&key=2
20 Jun 1985
An ANG RF-4C collided with a Beech 18 at Birmingham, AL after the
tower controller cleared the Beech 18 onto the runway,
then forgot about it and cleared the F-4 to land.
http://www.ntsb.gov/ntsb/brief.asp?e...14X36733&key=1
Injuries: 1 Fatal, 2 Minor. THE LOCAL CONTROLLER FORGOT ABX 74.
SHE BECAME PREOCCUPIED WITH OTHER TRAFFIC
IDENTIFICATION OF AIRCRAFT VISUALLY..NOT PERFORMED..ATC
PERSONNEL(LCL/GND/CLNC)
DIVERTED ATTENTION..ATC PERSONNEL(LCL/GND/CLNC)
VISUAL SEPARATION..NOT MAINTAINED..ATC PERSONNEL(LCL/GND/CLNC)
MENTAL PERFORMANCE OVERLOAD..ATC PERSONNEL(LCL/GND/CLNC)
ATC CLEARANCE..IMPROPER..ATC PERSONNEL(LCL/GND/CLNC)
SUPERVISION..INADEQUATE..ATC PERSONNEL(SUPERVISOR)
http://www.ntsb.gov/ntsb/brief.asp?e...14X36733&key=2
28 Jun 1990
A Navy F-14 took evasive action to avoid a Bellanca Viking near
Ojai, CA. The Viking suffered structural damage to the rear
wing spar when it flew into wake turbulence from the F-14 (OK,
not quite a collision, but close.)
http://www.ntsb.gov/ntsb/brief.asp?e...12X23447&key=1
Injuries: 1 Minor, 3 Uninjured
WHEN THE TWO AIRPLANES WERE BETWEEN 100-300 FT OF EACH OTHER, THE
NAVY PILOT OBSERVED THE TARGET AND ABRUPTLY PULLED UP. THE F-14
WAS BEING RADAR CONTROLLED BY A TRAINEE CONTROLLER
STRUCTURAL DAMAGE SUSTAINED BY THE BELLANCA, N39843, AS A RESULT
OF ENCOUNTERING WAKE TURBULENCE DURING A NEAR-COLLISION WITH A
NAVY F-14A [It would seem the NTSB shirked its responsibility to
find a cause in this accident.]
http://www.ntsb.gov/ntsb/brief.asp?e...12X23447&key=2
16 Nov 2000
A USAF F-16 collided with a Cessna 172 near Bradenton, FL
http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=2
Injuries: 1 Fatal, 1 Uninjured
the failure of the F-16 flight lead pilot and F-16 accident pilot
to maintain an adequate visual lookout while maneuvering. Factors
contributing to the accident we the F-16 flight lead pilot’s
decision to discontinue radar traffic advisory service, the F-16
flight lead pilot’s failure to identify a position error in his
aircraft’s navigational system, the F-16 pilots subsequent
inadvertent entry into class C airspace without establishing and
maintaining required communications with air traffic control
(ATC); and ATC’s lack of awareness that there was more than one
F-16 aircraft in the formation flight, which reduced the ATC
controllers ability to detect and resolve the conflict that
resulted in the collision.
January 18, 2005
http://www.ntsb.gov/ntsb/brief.asp?e...26X00109&key=1
NTSB Identification: CHI05FA055A
Nonscheduled 14 CFR Armed Forces
Accident occurred Tuesday, January 18, 2005 in Hollister, OK
Aircraft: Cessna T-37B, registration: 68008003
Injuries: 1 Fatal, 1 Minor, 1 Uninjured.
This is preliminary information, subject to change, and may
contain errors. Any errors in this report will be corrected when
the final report has been completed.
On January 18, 2005, approximately 1128 central standard time, an
Air Tractor AT-502B single-engine agricultural airplane, N8526M, and a
Cessna T-37B, a twin-turbojet military trainer, tail number 66008003,
operating under the call sign Cider 21, were destroyed following a
midair collision during cruise flight near Hollister, Oklahoma. The
AT-502B was registered to a private individual and operated by a
commercial pilot. The T-37B was registered to and operated by the
United States Air Force (USAF). The commercial pilot in the AT-502B
was fatally injured. The USAF flight instructor pilot was not injured
and the USAF student pilot sustained minor injuries. Visual
meteorological conditions prevailed and a flight plan was not filed
for the AT-502B, who was operating under 14 Code of Federal
Regulations Part 91 for the ferry flight. An instrument rules flight
plan was filed for the T-37B, who was operating under Air Force
Instructions (AFI) 11-202, Volume III. The cross-country flight for
the AT-502B flight originated from the Olney Municipal Airport, near
Olney, Texas, approximately 1100, and was destined for Huron, South
Dakota, with an intermediate fuel stop. The local flight for the T-37B
originated from the Sheppard Air Force Base (SPS), near Wichita Falls,
Texas, approximately 1022.
According to company personnel from an Air Tractor dealership in
Arkansas, the pilot was hired to ferry the recently purchased AT-502B
to the new owner in Huron, South Dakota, with an intermediate
refueling stop in Hutchinson, Kansas. Company personnel at the Air
Tractor factory located in Olney, Texas, reported that the AT-502B was
equipped with basic visual flight rules (VFR) instruments and was not
equipped with any radios or a transponder. Company personnel added
that the pilot had a hand held aircraft radio transmitter, a hand held
Garmin 295 GPS unit, and various maps prior to departure.
During an interview with the NTSB investigator-in-charge (IIC),
the USAF flight instructor and student pilot reported that they were
on a routine mission training flight (C2803). After a non-eventful
departure from SPS, they performed two normal overhead approaches to
SPS before being cleared into the Military Operations Area (MOA). Once
in the MOA, the training flight completed one loop, a barrel roll, two
power on stalls, one spin recovery, two spin prevents, traffic pattern
stalls, and slow flight. After completing the series of high altitude
maneuvers, the training flight received radar vectors to the RANCH
intersection and then to the Frederick Municipal Airport (FDR), near
Frederick, Oklahoma, which is commonly referred to by the USAF as
"Hacker." As the flight descended to an altitude of 6,000 feet, the
instructor noted the bottom of the overcast cloud ceiling to be
between 6,000 and 6,500 feet mean sea level (msl).
After arriving at Hacker, the training flight performed a straight
in no flap landing, and requested left closed traffic. After
completing a normal overhead approach and a single-engine landing, the
flight proceeded to depart Hacker's airspace to the east and climbed
to 5,500 feet msl.
During this time, the USAF student pilot performed the en route
portion of his checklist and contacted USAF Radar Approach Control
(Rapcon) to notify them they were en route back to Sheppard Air Force
Base and requested the "home plate" arrival. Rapcon advised the flight
that they had radar contact, and to descend to 5,000 feet msl on a
heading of 100 degrees.
After leveling off at 5,000 feet msl at an indicated airspeed of
200 knots, the flight instructor took control of the T-37B. The
instructor stated that he briefly scanned at the student pilot's
altimeter on the left side of the instrument panel (a standard
practice for T-37 flight instructors). As he was turning his head back
to the right, he noticed a "high visibility yellow airplane" out of
the right corner of his eye. The student pilot stated that as the
flight instructor took control of the aircraft, he scanned outside the
airplane to the left, and started to look back to the right when he
saw the yellow Air Tractor heading towards the right side of the
T-37B. Subsequently, the instructor and student pilot recalled feeling
a spinning sensation, and rolling inverted. Both the instructor and
student pilot initiated emergency egress procedures and ejected from
the aircraft.
The T-37B and AT-502B impacted farm fields about 3.5 miles east of
Hollister, Oklahoma. Both aircraft were partially consumed by a post
impact fire.
A witness located north of the accident site reported in a written
statement that he observed an aircraft descending rapidly in a nose
down attitude and on fire prior to losing sight of it behind a tree
line. Subsequently, the witness observed a second aircraft spinning in
a nose down attitude, and it was missing a wing. The witness added
that a plume of smoke was originating from the airplane but he didn't
see any flames. As the airplane continued to descend, he noticed two
parachutes on each side of the airplane and he decided to proceed to
the area to see if he could assist the pilots
[ rec.aviation.military, rec.aviation.soaring added ]
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 11:33 AM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Mil Acft heard on HF freqs, Monday 20 Sep 2004 AllanStern Military Aviation 0 September 21st 04 09:28 PM
A-4 / A-7 Question Tank Fixer Military Aviation 135 October 25th 03 04:59 AM
