I received an email from the FAA the other day concerning the normal
revision process for the Commercial Pilot Glider Practical Test Standards. Here is your chance to influence the regulator and make your pitch for what should be added, deleted or expanded in the current flight test. Make your best pitch and good luck for your proposals. Terry Clausssen FAA Designated Pilot Examiner Estrella, Arizona FAA email: The following Practical Test Standards are now going through their revision process. If any Designated Pilot Examiners, Aviation Safety Inspectors, Flight Instructors or Pilots having any recommendations for these documents please send an email to AFS-630 COMMERCIAL PILOT PRACTICAL TEST STANDARDS GLIDER FAA-S-8081-23 |
The email address was copied incorrectly--drop the hyphen:
afs630comments at faa dot gov. Remember the fed's are here to help and waiting for your thoughtful input. Terry Claussen |
Hello Terry, and all other USA CFI-G's and Designated Pilot Examiners.
Please copy your comments and any others you receive regarding the proposed rewrite of the FAA Com-Glider PTS to the Soaring Safety Foundation. You can copy/forward them to me at and I will relay them to the SSF. The SSF, as the training and safety unit of the SSA, will compile the suggestions and send them to FAA as a comprehensive commentary to the FAA. Burt Compton, Master CFI, FAA DPE SSF Trustee Marfa, Texas Terry wrote: The email address was copied incorrectly--drop the hyphen: afs630comments at faa dot gov. Remember the fed's are here to help and waiting for your thoughtful input. Terry Claussen |
That sounds like a common sense use of the SSF or SSA website.
Power Commercial to Glider Commercial | Mitty | Soaring | 24 | March 15th 05 03:41 PM |
Glider cross-country time toward commercial SEL requrements? | Matt Michael | Soaring | 17 | November 25th 04 04:45 PM |
Bad publicity | David Starer | Soaring | 18 | March 8th 04 03:57 PM |
Did commercial glider pilots used to give instruction? | Mark James Boyd | Soaring | 7 | December 19th 03 07:51 AM |
Part 91 Commercial Glider Rides to be Outlawed? | Vaughn | Soaring | 9 | October 27th 03 09:26 PM |
