Prang Rate?
Old January 13th 05, 08:18 PM
Colin W Kingsbury
Default Prang Rate?
With the winter doldrums well set in, this spamcan pilot has gotten to
thinking again about trying something different in aviation- specifically
the homebuilt/LSA area. Something not too expensive to operate, on floats
(or a boat-hull) sounds like a lot of fun and might get me up in the air
more often.
I've been following some forums for planes I've been interested in, like the
Challenger, Searey, and Zenith series, and something that's been a bit
disconcerting is that it seems like every time I turn around I'm reading
about somebody trashing their bird in one way or another. It seems like I
hear about this a lot more often than with certified planes, but I studied
enough statistics to know that's not valid methodology.
My question to those of you in the know, is how do you feel about the safety
of designs like I mentioned above, that have been around a while and built
in large numbers, built the way the factory says, maintained to a proper
standard, and flown by a pilot who understands his toy is an airplane and
not a snowmobile or jet ski?
Best,
-cwk.
Old January 14th 05, 04:36 AM
Peter Dohm
Since you are a spamcan pilot, the problem probably does not apply to you.
However, I just received an e-mail from EAA, explaining the present meaning
of the term "repositionable gear" in the LSA rule. (Due to some really
unfair
competition from a well known retailer earlier today, I can not quite decide
whether this is the most stupid thing that I have heard or read today.) So,
sit
down and hang on... "Repositionable gear" apparently means that the craft
may be converted between land and sea operation while on the ground or on
the water, but not while in the air!
Supposedly, the hypothesis is that inadvertant gear-up landings on land and
inadvertant gear-down landings on water will be prevented if all flights
must
begin and end on the same medium. To the extent that deliberate landings
with the gear in the "wrong" position are questionable, this would seem to
prevent any LSA craft from being amphibious.
Let's all wish the EAA the greatest success in counteracting this lunacy!
"Colin W Kingsbury" wrote in message
ink.net...
more often.
safety
Best,
-cwk.
Old January 14th 05, 09:21 AM
unfair
sit
That's certainly the way the rule was written. However, I was told that the FAA
announced at Oshkosh that the gear rule was being interpreted to allow amphibs
to retract and lower the gear for each type of landing. Apparently that wasn't
the case....
Old January 14th 05, 02:34 PM
Colin W Kingsbury
"Peter Dohm" wrote in message
Well, sort of. I am rated for ASEL/S-IR, but if I am exercising sport pilot
privileges, i.e., flying with a driver's license medical, it's my
understanding that I could only fly true LSA-legal planes. Hopefully not an
issue I'll be confronting for a couple decades but it's always nice to have
the option. Enforcement of course is another question...
FWIW, I sympathize with the original logic ("no retractable gear
airplanes"), but this specific application is a bridge too far. How many
gear-down water landings are there in a year? You're effecting a huge
reduction in utility for a pretty marginal reduction in accidents. Sounds
like an issue someone got a bug up their ass about and wrote into the regs.
-cwk.
Old January 14th 05, 04:12 PM
On Fri, 14 Jan 2005 13:34:33 GMT, "Colin W Kingsbury"
Especially when you consider that retractable gear is allowed on LSA gliders.
However, the severity of a gear-up accident on land is usually a lot less than
that of a gear-down landing in the water. There was one of those (in a
homebuilt, yet) just last September.
"When the pilot expected to hear the hissing of the water on the hull at the
step, the pilot, instead, saw two columns of water on both sides of the cockpit
shooting straight up. The airplane then violently nosed down into the water and
came to rest inverted and submerged in the lake."
They should have written the rules to allow retracts on amphibs as long as the
aircraft's max speed stays within the bounds.
Old January 14th 05, 04:22 PM
For that matter, they should have included a rule to prevent people on the
ground from retracting the runway! :-)
http://www.avweb.com/news/features/188978-1.html
Old January 14th 05, 08:59 PM
B2431
Date: 1/14/2005 09:22 Central Standard Time
Message-id:
Retractible runways are classified. You shouldn't have published the link. Now
the Ruskis will want to start making them. We must not allow a retractible
runway gap.
Dan, U.S. Air Force, retired
Old January 14th 05, 11:25 PM
Colin W Kingsbury
If you land a fixed-gear airplane on a retractable runway, do you need a
complex endorsement?
"B2431" wrote in message
Message-id:
as
Now
runway gap.
Old January 15th 05, 08:12 AM
On Fri, 14 Jan 2005 22:25:49 GMT, "Colin W Kingsbury"
the ground from retracting the runway! :-)
I just know if a runway retracted under ME, I'd develop a complex real
fast.... :-)
Ron "Let's look at the blueprints. Let's look at the blueprints. Let's
look...." Wanttaja
JET99 is growing at an amazing rate! Join for CASH & Air Miles PBoyd77443 Home Built 1 July 18th 04 05:10 PM
Boeing 757 turn rate? Garyurbach Aerobatics 6 June 14th 04 05:43 PM
Rate of climb Dillon Pyron Home Built 3 May 8th 04 02:08 PM
Air Flow Rate for Rotax Calvin R. Walker Home Built 0 November 14th 03 04:17 AM
