Link to B-777 upset?
Old October 3rd 05, 04:41 PM
Capt.Doug
Default Link to B-777 upset?
In the recent Airbus nose gear thread, someone posted a link to a report
about a B-777 fly-by-wire upset. I can't find it now and am asking if
someone can bring up the link to this report.
TIA,
D.
Old October 3rd 05, 05:35 PM
Chris Kennedy
No link, but there's a good description of what happened n page 46 of
the 26 Sept edition of AvWeek. Basically the problem was in the
firmware loaded into the Honeywell air data reference unit that feeds
air data and altitude information to a bunch of systems, including the
primary flight controls, autopilot, autothrottle, pilot displays and
autobrakes.
The FAA issued AD 2005-18-51 which requires that any Adiru loaded with
-06 or -07 software be reloaded with -03 within 72 hours. The -03
version has its own problems that they've been trying to fix revolving
around the ability to use data from failed sensors.
There's a fairly extensive blow-by-blow in the article, which also notes
that things would have been a lot worse had the primary flight computer
not used the data from the standby air data source to dampen the initial
pitching motion and would have gone utterly to pieces if there hadn't
been someone looking out the window and deciding that what the
instrumentation was saying (like the slip indicator swinging to full
right) made absolutely no sense.
Making one feel really warm-and-fuzzy, page 52 of the same edition
carries a report that Airbus is considering new functionality from
Honeywell that will allow software to take control of the aircraft from
the pilots in the event of a EGPWS alarm, and in later evolution,
prevent the aircraft from flying into prohibited areas. In the case of
the triple-seven the pilots were able to beat the flight control system
into submission, but here we have the provider of the same quality
software proposing to make it impossible for the flight crew to do so.
Old October 3rd 05, 09:50 PM
Casey Wilson
"Capt.Doug" wrote in message
TIA,
D.
Try this one:
http://www.atsb.gov.au/aviation/occu...ail.cfm?ID=767
The link says 767 but the report says 777.
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
correct link Shaun Instrument Flight Rules 0 October 10th 04 06:41 PM
correct website link Shaun Aerobatics 0 October 10th 04 06:41 PM
correct link Shaun Aerobatics 0 October 10th 04 06:39 PM
Blanik Weak Link for Winch Launch??? Gary Emerson Soaring 6 February 24th 04 08:08 PM
