"hinge stock"?
Old October 5th 05, 12:17 AM
Michael Horowitz
Default "hinge stock"?
reading thru EAA's "Aircraft Welding" I see mention of 'hinge stock',
a tube which probably takes a bushing and is part of the
elevator/stab. assy.
I didn't see a mention in Spruce; is it just tougher steel than 4130
or is it tubing with a pre-drilled bushing? - Mike
Old October 5th 05, 04:16 AM
Dear Mike,
Look under 'Bushing Stock.'
'Hinge Stock' is another name for plain, old-fashioned SAE 1020 mild
steel tubing, usually having a sixteenth-inch wall. You may install
bushings in the finished hinge if you wish but other means of
distributing the wear are to provide additional hinge points or to use
a hinge-pin (bolt; whatever) of larger diameter. If kept greased and
cleaned periodically, with the pins replaced when prudent, even
operating off a dirt strip it will be twenty years or more before you
can detect any wear in the barrel of the hinge itself.
-R.S.Hoover
Hinge pins for Pegasus AD tooromeo Soaring 0 May 17th 05 02:56 PM
Aluminum hinge VideoFlyer Home Built 2 May 11th 04 08:39 PM
Wood questions - Public Lumber Company, determining species at the lumberyard Corrie Home Built 17 September 17th 03 06:51 PM
