the punch test on fabric... are the results a go/no-go decision, or
can an A&P make a determination as to how long the covering will last based on the test? - Mike |
I argue that the punch test is go-nogo, but there are those who argue that a
lab test may be required for marginal fabric. My answer is that "marginal" is like being a little pregnant. IT passes or it doesn't. It says NOTHING about how long the fabric will last. That is a function of environment -- hangared or outside, humid or dry, hot or cold... Jim "Michael Horowitz" wrote in message ... the punch test on fabric... are the results a go/no-go decision, or can an A&P make a determination as to how long the covering will last based on the test? - Mike |
Jim - I'm looking at a fabric a/c with 25 year old fabric. A recovery
will run into 5 figures. Assume we don't know the entire history of this coating; no log entries stating "under cover from X to Y" so I have to guess at how long we have remaining on the fabric. Any suggestions on how that can be done? - Mike "RST Engineering" wrote: I argue that the punch test is go-nogo, but there are those who argue that a lab test may be required for marginal fabric. My answer is that "marginal" is like being a little pregnant. IT passes or it doesn't. It says NOTHING about how long the fabric will last. That is a function of environment -- hangared or outside, humid or dry, hot or cold... Jim "Michael Horowitz" wrote in message .. . the punch test on fabric... are the results a go/no-go decision, or can an A&P make a determination as to how long the covering will last based on the test? - Mike |
No way in hell other than extrapolating 100% strength to where the fabric
punches right now and drawing a straight line through 25 years to the ultimate fabric strength limit. What kind of fabric is it? Jim |
Dacron/Ceconite - Mike
"RST Engineering" wrote: No way in hell other than extrapolating 100% strength to where the fabric punches right now and drawing a straight line through 25 years to the ultimate fabric strength limit. What kind of fabric is it? Jim |
The punch-test gives an approximation of the tensile strength of the fabric. It has nothing to do with how long the fabric will last. New Grade 'A' cotton ('standard' weight; about 6oz per square yard) must have a minimum tensile strength of 80 pounds, equal for both warp & weft. When applied to a wing or control surface, once the strength degrades by 30% the fabric should be replaced. (The test is normally done to the upper surface; that which has the most exposure to sunlight.) For comparison, new 2.7oz/yd polyester (ie, Dacron) has a tensile strength of about 85 pounds, 3.7 oz about 130, although those numbers may vary slightly from one manufacturer to another. When warp & weft are not equal you must use the lower strength for your calculations. Other than fiberglas, all fabrics used for aircraft covering are subject to degradation. And even WITH fibergals (ie, 'Razorback') the airframe UNDER the fabric requires periodic maintenance, making claims of 'Lifetime' coverings a bit iffy :-) The fact a 20 year old covering measures high-green on a strength test is no guarantee the thing won't fall apart next week. There could be corrosion, dry-rot or rampant rusting going on under that slick, always-hangared fabric skin. -R.S.Hoover |
Bob...cut me some slack...
wrote in message oups.com... The punch-test gives an approximation of the tensile strength of the fabric. It has nothing to do with how long the fabric will last. That is the absolute truth. The condom is only so strong from manufacture; how many times can you use it before it breaks catastrophically? The fact a 20 year old covering measures high-green on a strength test is no guarantee the thing won't fall apart next week. There could be corrosion, dry-rot or rampant rusting going on under that slick, always-hangared fabric skin. Which was not the question. The question was the fabric itself. The remainder of the airframe is quite another matter. Jim |
RST Engineering wrote: Bob...cut me some slack... ---------------------------------------- Okay. But I wasn't aware you needed any. My msg was in response to Mike's. The fact it appeared after yours is an artifact of my ISP, which has taken as long as 24 hours to upload a message to a Usenet newsgroup. My closing para was to make sure Mike understood that the condition of the covering is not the only criteria for re-covering. -R.S.Hoover |
RST Engineering wrote: Bob...cut me some slack... ---------------------------------------- Okay. But I wasn't aware you needed any. Moi? {;-) My msg was in response to Mike's. The fact it appeared after yours is an artifact of my ISP, which has taken as long as 24 hours to upload a message to a Usenet newsgroup. Got it. My closing para was to make sure Mike understood that the condition of the covering is not the only criteria for re-covering. Absolutely true. -R.S.Hoover Jim |
No!
| Thread Tools | |
| Display Modes | |
| Post Test Web to Usenet | Guest | Naval Aviation | 0 | April 22nd 05 04:43 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Air Force conducts live test of MOAB | Otis Willie | Military Aviation | 0 | November 21st 03 11:45 PM |
| FAA Knowledge Test Results | Richard Moore | Instrument Flight Rules | 4 | October 12th 03 08:10 AM |
| FAA Knowledge Test Results | Richard Moore | Simulators | 3 | October 12th 03 05:48 AM |
