Flying on the Cheap - Again
Old January 22nd 05, 03:30 AM
Default Flying on the Cheap - Again
To All:
A fellow homebuilder spotted a female air-hose quick-connect fitting on
a fuel I'd just finished sloshing (riveted aluminum tank) and told me
he hadn't bothered to pressure-test his tank since it was gravity feed
and he figured just filling it up was enough of a test. He went on to
say that it hadn't leaked so I guess he was right.
I didn't bother to tell him the fitting wasn't there for the purpose of
pressure-testing.
Heat the end of your 2-ply fuel line in oil, you can push it onto a
female air-hose quick-connect fitting. Safety wire or even a
hose-clamp for the rich *******s, you got yourself a fuel-line fitting.
Why? Because it costs less than half a buck and works perfectly well.
Gettem from Harbor Freight. Three females and one male, plus a
quick-connect coupler. Wait for the sale, you can pick up the kit for
$1.79 (otherwise, it's about $3).
No big deal? Maybe not, if you got lots of money to waste.
Personally, I prefer aluminum tubing for fuel, vent & vacuum lines.
Old habits, etc. But if you have to squeeze ever nickle until the
buffalo farts, hose is makes pretty good sense. When properly
installed & supported, frequently inspected and periodically replaced,
hose can be made to serve for the plumbing in a minimum-cost,
VW-powered puddle jumper. Assuming you've got a drawer full of
fittings.
Back around Thanksgiving I reached in the drawer and came up empty and
the local auto-parts place wanted something like three bucks for ONE
1/4"-NPT to hose fitting, I needed four of them and they only had the
one in stock. I could turn them up on the lathe faster than they could
order them but on the way home I stopped by the Harbor Freight store in
Escondido and they had a whole bin of air-hose fittings on sale.
Bought a bunch. Worked fine.
They're cast brass rather than extruded. And only come in straights,
male or female. But a gravity-feed system doesn't see any pressure to
speak of and space isn't at a premium in this particular airframe so
straight works okay.
Yeah, it's outside the box. No, it isn't unsafe; not when properly
installed. And the proof is no farther away than testing it for
yourself.
-R.S.Hoover
Marske Flying Wing discussion Group mat Redsell Home Built 0 September 19th 04 02:58 PM
How many non flying pilots John Home Built 19 September 17th 04 05:16 AM
Goodyear Brake Pucks - Cheap! Ron Wanttaja Home Built 7 July 16th 04 07:45 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
Flying Wing Design workshop in july 04 mat Redsell Home Built 1 May 5th 04 02:53 PM
