Cessna nose oleo seals
Old October 7th 05, 09:49 PM
Default Cessna nose oleo seals
In the Cessna 172's nosewheel strut are several O-rings, but the
one that seals against the chrome piston sometimes twists in its groove
and a spiral failure (tear) occurs. All the outer-cavity oil escapes,
then the nitrogen leaves and the strut goes flat. The failure appears
to happen rather suddenly.
These are MS28775-329 rings. The rubber is an ancient type,
probably around for 40 years or more, and while there are much better
O-rings on the market now we can't use them since Cessna does not
approve them and no one, as far as I know, has done an STC on a better
ring. Some folks recommend Granville Strut seal, which I have tried and
haven't noticed any better life. The stuff is supposed to swell and
soften the seal.
The failure I see seems to be due to the ring sticking to the shaft
and getting rolled over. An anti-friction additive might be a better
bet. Does anyone who has worked on these things know if there are any
approved additives like that?
Dan
Old October 7th 05, 11:01 PM
nrp
I have not experienced or heard of that problem, however in ordinary
industrial hydraulics, I've found that smearing STP on a piston rod
will cut the cyclic operating seal friction in half for several minutes
- even if it is only smeared on the low pressure side of things.
Another possible factor is the surface finish on the O-ring groove and
the groove faces. Too smooth and this might happen.
I'm sure it is not approved, but maybe just assembling the strut with
STP as a prelubricant might help. The "ancient" type rubber is
probably neoprene - which is widely used in industrial applications
today. I doubt the O-ring compound is at fault here.
Old October 8th 05, 01:20 AM
If there is a newer technonogy o-ring that would fix the problem, i
would use it. I've never seen an o-ring policeman.
But is the problem with the oring or the shaft making the o-ring twist?
Quite a few people clean and lube their strut tubes on a regular basis.
It helps the seal keep sealing.
Old October 8th 05, 05:07 AM
RST Engineering
"Why, I have no idea who put that o-ring in there. It must have been done
before I bought the airplane. (TM)"
ring.
Old October 8th 05, 09:58 PM
Scott Skylane
Dan,
While I have heard rumors of people succesfully mixing a little STP, or
even dry graphite powder, in with the hydraulic fluid, I can not say
from personal experience that these will work just fine and last a long
time...
However, Cessna does sell a "cold weather" seal that replaces the O-ring
in question, as well as the two S1628 backup rings on either side of
it. It is a much sturdier piece, has a sort of squared-off cross
section, and appears to have some teflon-like properties. I *think* the
part # is "A2748", but I'd be sure to double check that before ordering.
Aircraft Spruce lists the part for $17.50
Happy Flying!
Scott Skylane
N92054
slow roll in a super decathlon Nobody Aerobatics 4 August 24th 05 02:36 AM
Wow - heard on the air... (long) Nathan Young Piloting 68 July 25th 05 06:51 PM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 05:22 AM
