Maule has no performance?
Old October 7th 05, 05:09 PM
Robert M. Gary
Default Maule has no performance?
After spending a frustrated hour out at the CAP plane trying to finish
my questionnaire I finally called the aircraft manager asking where the
performance section to the POH went. Amazingly the Maule has none,
nothing nada. Not even expected cruise speed or fuel burn info. This
isn't some J-3 classic aircraft, this plane is a youngster but the FAA
apparently didn't ask them for any performance information. I guess
that makes the written CAP exam easier.
-Robert
Old October 7th 05, 06:25 PM
Michael
This
Check out your POH. Note that it has sections that are FAA approved,
and sections that are not. Performance is not. If it's not FAA
approved, it's not FAA required. I hear Maule does it that way to keep
lawsuits down.
Michael
Old October 7th 05, 06:43 PM
Maule Driver
That's what Ray Maule told me when I was down flying with him. If it's
not required, it's not there. Limit liability where you can seems to be
the motto.
Never missed it either.
Michael wrote:
This
lawsuits down.
Michael
Old October 7th 05, 07:08 PM
Robert M. Gary
I guess as a Maule driver you haven't missed it but as a CAP pilot who
seems the Maule as one of a number of planes on the ramp, it would be
good to know how speed/fuel burn to expect when you hop in.
-Robert
Old October 7th 05, 09:56 PM
Maule Driver
I guess it would.
FWIW, In my 180HP fixed pitch MX7180a I flight plan 10gph (conservative,
I can do anything with that assumption). I get 9 GPH with 1 hour or
greater leg and 1 TO and 1 Landing. I can get 8.1 by aggressive
leaning, flying over 7000feet on a 4 hour+ leg. All assume 2500rpm.
I guess with the CAP setup, a chief pilot will have to put together a
performance sheet for use by the group. Of course the liability for the
figures would lie with .....
-Robert
Old October 8th 05, 12:57 AM
Michelle P
For a 235 Hp Maule (M-7-235B 80 gallons on board) you can figure 12
Gal/Tach hour or 15 Gal/flight hour. This gives me 7 tach hours or 5
flight hours till dry tanks. I have run the aircraft for 6 hours strait
without stopping with a favorable tail wind. I lean to about 12.6 to
13.0 depending on the CHTs.
Michelle
Maule Driver wrote:
I guess it would.
(conservative, I can do anything with that assumption). I get 9 GPH
with 1 hour or greater leg and 1 TO and 1 Landing. I can get 8.1 by
aggressive leaning, flying over 7000feet on a 4 hour+ leg. All assume
2500rpm.
the figures would lie with .....
-Robert
Old October 8th 05, 01:34 AM
George Patterson
You can find a limited amount of performance data at the Maule Air web site.
http://www.mauleairinc.com/Our_Planes
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old October 8th 05, 11:24 AM
Brad Salai
"Michelle P" wrote in message
ink.net...
.. I have run the aircraft for 6 hours strait
I'm glad I didn't say that. And in THIS group, boy are you going to get it.
You better brace yourself!
Brad
Old October 8th 05, 03:38 PM
Mike Weller
On Sat, 08 Oct 2005 10:24:14 GMT, "Brad Salai"
link.net...
Brad
I've lost the attributes, but I think Michelle is not a boy.
To answer the original question, a Maule flys like a Aeronica on
steriods. It has no real mean traits, it just is what it looks like.
Of course, if you run out of gas, that's not the airplane's fault.
Mike Weller
Old October 8th 05, 06:35 PM
Michelle P
Brad,
I have done it because it can. I plan for 15 Gal/hour and it flies about
12.5 gal/hour according to the Shadin Fuel Flow. I still had 10 gallons
left upon landing. about 45 minutes. I like to have an hour in the tank
when I land. I have pushed it to 45 minutes if necessary.
Michelle ( girl)
link.net...
Brad
Performance World Class design proposal iPilot Soaring 85 September 9th 04 09:11 PM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
Assistance on performance *** Happy conclusion *** Marc Arsenault Soaring 0 August 16th 03 08:56 PM
Maule Turbine kevin Owning 16 August 4th 03 10:49 PM
