position and hold at an angle
Old October 10th 05, 11:39 PM
Jose
Default position and hold at an angle
A few months ago there was a discussion here about positioning on the
runway at an angle to better see traffic from the rear while awaiting
takeoff clearance, and I opined in the face of dissent by Steven
McNicoll that it was a good idea.
I had a chance to fly a 172 while I was out west and was unable to see
any better that way from a Skyhawk, which was the OP's aircraft. I
still think it makes sense to angle a Cherokee, but a 172 might as well
be straight on.
So, I guess I was wrong. (dang - that's twice now!)
Jose
Money: what you need when you run out of brains.
Old October 11th 05, 12:37 AM
john smith
be straight on.
You can do what taildragger pilots are taught (at least the older ones)
and do a 360 to scan the pattern prior to takeoff.
Old October 11th 05, 01:31 AM
.Blueskies.
"john smith" wrote in message ...
be straight on.
I don't do a 360, but I do turn toward the approach end and look and then turn on to the runway...
Old October 11th 05, 01:36 AM
BTIZ
Position and hold is normally used at tower controlled airports..
At uncontrolled airports.. I do not plan on taxing onto the active unless I
can take off right away.
And from behind the hold line I can see most of the base and all of the
final whilst sitting with my nose 90 degrees to the take off direction.
BT
be straight on.
Old October 11th 05, 02:08 AM
Sylvain
that's what I was thinking too... however, there are uncontrolled
airports *without* taxiways (you taxi on the runway), so I reckoned
that was what they were talking about,
--Sylvain
Old October 11th 05, 01:37 AM
Jose
The point was to be able to have a continuous watch behind you while
waiting for takeoff, while at the same time being ready for an immediate
takeoff (the fraction of a second it takes to turn 30 degrees while on
the roll is insignificant).
Doing donuts on the numbers while awaiting takeoff clearance gives a new
meaning to "position and hold... whoa there... yee haw!... comone little
dawgiee..."
Jose
Old October 11th 05, 02:50 AM
john smith
dawgiee..."
I can add a little power, roll forward a couple feet and hit a brake and
spin a 360 pretty quickly! Think of it as a controlled ground loop.
Old October 11th 05, 08:57 PM
Steven P. McNicoll
be straight on.
Where are older taildragger pilots taught to do a 360 to scan the pattern
prior to takeoff when instructed to position and hold? Why is this taught?
Old October 11th 05, 11:44 PM
zatatime
On Tue, 11 Oct 2005 19:57:41 GMT, "Steven P. McNicoll"
No where that I know of. At a towered airport you need trust in the
tower.
At uncontrolled airports a 360 (actually 270) is used if you have a
visual obstruction of some sort, or don't have a good look at what's
going on in the pattern for any other reason.
z
Old October 11th 05, 11:39 PM
Steven P. McNicoll
"zatatime" wrote in message
The previous poster, John Smith, apparently knows of some place where it's
done.
"position & hold" going away Paul kgyy Piloting 86 August 29th 05 02:43 PM
Position and Hold at uncontrolled field dave Piloting 42 February 26th 04 01:25 AM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 08:46 PM
