C182 tow hook arrangement?
Old October 17th 05, 08:52 PM
Default C182 tow hook arrangement?
I'm looking for a way to put a Tost release mechanism on a C182R.
We have a Tost release on the Pawnee, and it looks so much more
robust than the Schweitzer mechanism.
Wings and Wheels has the Tost arrangement for C172 and Maule, but in
Colorado, Civil Air Patrol has neither of those aircraft.
Is there an STC available (looked on google, not found)?
Do I have to go with Schweitzer (who does not even sell it anymore)?
Best regards,
LtCol Jer/ Eberhard, Colorado Wing Checkpilot (airplanes and gliders),
Assistant Glider Program Manager, Colorado Wing, CAP
LtCol Jer/ Eberhard, CO-Wing, Thompson Valley CS., Ft Collins, CO
CELL/VM: 970 231-6325, CELL Message: 9702316325'at'mmode.com
EMAIL: jer'at'frii.com WEB: WEB http://users.frii.com/jer/
C-206 N9513G, CFII Airplane&Glider, FAA-DEN Aviation Safety Counselor
CAP-CO Mission&Aircraft CheckPilot, BM218 HAM N0FZD, 233 Young Eagles!
Old November 17th 06, 03:43 AM
Bob Harrison Bob Harrison is offline
Junior Member
First recorded activity by AviationBanter: Nov 2006
S Nevada has kind of the same problem and the easiest answer is to take a Schweizer tow hook, input the individual pieces into AutoCad, have parts waterjet cut from wuality steel and then assembled in front of the FAA and recieve an onsite approval instead of a 337. Of course you could just buy the $2000.00 Tost assembly built for 206's and 172's and get it approved onsite.
PS
I am also going to produce a smaller version for folks who hand prop and want a quick release
Old November 17th 06, 03:56 PM posted to rec.aviation.soaring
Tim Mara
the TOST tow release mechanisms will now also be in the latest revision to
FAA AC 4313, (Acceptable Methods, Techniques, and Practices - Aircraft
Alterations), even without the TOST support you could use the TOST mechanism
for better safety and the TOST releases are being produced new today and
will be supported into the future...Schweizer releases are not.and the cost
for the TOST release mechanism is even less than the Schweizer hook and
release..if you're going to design and build one anyway, you'd be far better
off to use the TOST release mechanism in the system and many will do for
aircraft that TOST doesn't already offer an approved support for.......and
BTW the C-172 system from TOST is in stock here and is a very nice and well
designed set-up http://www.wingsandwheels.com/page31.htm
tim
Wings & Wheels
"Bob Harrison" wrote in
message .. .
PS
Bob Harrison
Old November 18th 06, 03:18 AM posted to rec.aviation.soaring
BT
Bob, sorry but the firist part of the thread was trimmed by the newsever
(only download the latest 300 messages).
What problem is S Nevada having with tow hooks? Are you refering to the
local CAP?
BT
message .. .
PS
Bob Harrison
Tow Hook on Cessna 180 - Update Stuart Grant Soaring 13 April 10th 20 10:48 AM
Is it Possible to Self launch (no wingman) with CG hook?? Jerz Rossignol Soaring 43 November 16th 04 07:54 AM
Tow hook for a Cesna 185? Gary Boggs Soaring 4 February 13th 04 02:09 AM
Tow Hook on Cessna 180? Stuart Grant Soaring 3 October 2nd 03 12:50 AM
CG hook & Low Tow Ray Lovinggood Soaring 2 July 25th 03 06:20 AM
