Oil Pressure Gauge Troubleshooting
Old October 18th 05, 04:59 AM
Kyle Boatright
Default Oil Pressure Gauge Troubleshooting
I was out flying this evening (Beautiful evening in North Georgia. We don't
get better flying weather than today...) and noticed that my oil pressure
was "stuck" at 100 PSI. I reduced throttle and RPM, no change, I increased
throttle and RPM, again no change. I tapped the face of the gauge. No
change.
Eventually, I shut down the radios and transponder and turned off the master
switch. The OP gauge fell to zero. Back on with the master and it's 100 PSI
again. By the time I returned to my home field, the pressure gauge seemed to
be acting normal again, so I presume it is going to be an intermittant
problem - the absolute worst kind to diagnose.
Anyway, the gauge and sender are both Rochester brand. Probably 6 years old
(4.5 years flying)with 350 or so tach hours on 'em.
How do I diagnose the problem when it recurrs?
Thanks in advance.
KB
Old October 18th 05, 06:02 AM
Jim Carriere
change.
This is a gauge with a remote sender mounted on the engine, right? I
ask that because what you are describing sounds like a wetline gauge
with some air in the line and cold oil.
Maybe the sender is dying. Can you see if the voltage in the
electrical line between the gauge and sender varies with oil
pressure? Then you could eliminate one part or the other.
Old October 18th 05, 12:50 PM
Kyle Boatright
"Jim Carriere" wrote in message
don't get better flying weather than today...) and noticed that my oil
pressure was "stuck" at 100 PSI. I reduced throttle and RPM, no change,
I increased throttle and RPM, again no change. I tapped the face of the
gauge. No change.
master switch. The OP gauge fell to zero. Back on with the master and
it's 100 PSI again. By the time I returned to my home field, the pressure
gauge seemed to be acting normal again, so I presume it is going to be an
intermittant problem - the absolute worst kind to diagnose.
old (4.5 years flying)with 350 or so tach hours on 'em.
This is a gauge with a remote sender mounted on the engine, right? I ask
that because what you are describing sounds like a wetline gauge with some
This is an electronic gauge with a sender mounted on the engine accessory
case.
Maybe the sender is dying. Can you see if the voltage in the electrical
line between the gauge and sender varies with oil pressure? Then you
You could, but that would mean working awfully close to a flailing prop.
I'm not up for that. ;-)
KB
Old October 18th 05, 01:36 PM
Kyle Boatright
"Kyle Boatright" wrote in message
gauge. No change.
pressure gauge seemed to be acting normal again, so I presume it is
going to be an intermittant problem - the absolute worst kind to
diagnose.
case.
Correction, this gauge is mounted on the firewall, and has a 12" or so hose
connecting it back to the oil pressure pick-up port on the engine.
KB
Old October 18th 05, 01:37 PM
Kyle Boatright
change, I increased throttle and RPM, again no change. I tapped the
face of the gauge. No change.
diagnose.
case.
hose connecting it back to the oil pressure pick-up port on the engine.
KB
Man, I can't get things straight this morning. The sender is on the
firewall, fed by the 12" hose.
Sheesh. No wonder I rarely post in the AM.
KB
Old October 18th 05, 05:48 PM
RST Engineering
Yeah, it looks like your snippit button fails at midnight also.
KB
Old October 19th 05, 03:52 AM
Cy Galley
Is the hose clear? Sounds almost like you have a check valve in the line.
Did you make up the hose by putting on ends? If you made the hose or had it
made to length, there is a possibility that a "donut" has been cut out of
the hose side wall making a flapper valve. Happens when someone doesn't use
a mandrel.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
diagnose.
years old (4.5 years flying)with 350 or so tach hours on 'em.
accessory case.
KB
KB
Old October 18th 05, 02:10 PM
Morgans
How about checking it at the back of the gauge? If you can't do that, Hmm.
Replace the sender?
Old October 18th 05, 08:22 AM
Morgans
old
That is a lot of time and hours on a sender. I would be surprised if it is
not the sender.
Most senders fail when oil gets past the pressure side, and gets into the
dry side. You really can't usually see the problem, but sometimes, you can
see oil (a small amount) oozing out around where the wires hook on.
If you put voltage onto one lead of the sender, you should see the other
terminal voltage go up and down with RPM. If not, bad sender. You can
check the gauge by inputting differing voltages, from zero to 12 (or 28) and
watch the oil pressure go up and down.
If the sender is fairly inexpensive, replace it. It is due. Your mileage
may vary.
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 10:14 PM
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 07:58 AM
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 04:46 AM
Vaccuum Pressure Gauge Al Owning 4 January 16th 04 06:26 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 01:35 AM
