UBC's Human-Powered Helicopter blades questions (kinda technical,engineers welcome)
Old October 23rd 05, 02:26 AM
james cho
Default UBC's Human-Powered Helicopter blades questions (kinda technical,engineers welcome)
Here's a pic of their blades layout:
http://batman.mech.ubc.ca/~hph/thunderbirddesign.gif
(note the blade rotation arrows)
What I'm wondering about the blades:
- Why the odd taper? I'm guessing the taper alleviates tip losses,
but why does it begin at the ~.6 span mark? I'd expect taper across the
entire blade for the best inflow results, but then again I'm a non-expert.
- Why no twist? Does the taper alone sufficiently linearize the
inflow?
I'd be grateful for any thoughts on these questions, and I know that
probably no one in this newsgroup has an exact answer. I'm just a
student studying helicopter aerodynamics and am interested in the UBC
HPH design.
Here are some of their CFD visualizations if it helps anyone analyze:
http://batman.mech.ubc.ca/~hph/projects/cfd.html
And here's some info on another HPH design, with blades that are more
conventional (to my knowledge at least):
http://www.calpoly.edu/~wpatters/davi.jpg
Hope someone here knows more about this than I do,
jc
Old October 23rd 05, 07:47 PM
Dave Jackson
Default UBC's Human-Powered Helicopter blades questions (kinda technical, engineers welcome)
James;
Mike Georgallis was the person at UBC who was in charge of the project. His
phone number is/was 604 822-3665. He would be the best person to provide the
answers to your questions.
A few thoughts;
The UBC rotors were very large and very slow turning. My impression was that
the two disks should be smaller and identical. Normally a smaller disk will
require more power. However, the slow speed of the these blades meant that
they were not operating in a vertical flow field.
In addition, these blades would have flex in the flapping direction. The
flex recovery, as the blades pass through the downwash/downdraft of the
blades of the other rotor, should maintain a fairly consistent angle of
attack throughout the rotation.
Constant taper and ideal twist should also help.
Dave
"james cho" wrote in message
inflow?
probably no one in this newsgroup has an exact answer. I'm just a student
studying helicopter aerodynamics and am interested in the UBC HPH design.
jc
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 10:36 PM
