Lowrance Airmap 100 databse load
Old October 27th 05, 03:28 PM
Default Lowrance Airmap 100 databse load
Folks,
I have a Lowrance Airmap 100 and a new (not current, but close)
database. I've tried to load the database, but the jeppson.exe program
says "Must be run from the floppy drive". The problem is that the
database file is too large for a 1.44MB floppy. I've never done this
before, so can anybody walk me through it?
John Stevens
Old October 27th 05, 04:22 PM
Gig 601XL Builder
Folks,
John Stevens
Sorry I can't help but there has to be a work around. I and many others have
computers that don't even have floppy drives.
Old October 27th 05, 10:17 PM
Kyler Laird
If the Lowrance airmap 100 was designed to read data from a floppy
disk, there is nothing that you can do.
I really hate proprietary crap like this.
I'd be tempted to run it under a DOS emulator and feed it something
that looks like a 2.88MB floppy.
--kyler
Old October 27th 05, 10:54 PM
pgbnh
To the OP - I think you will find that if you follow the directions in the
'Readme.txt' on the floppy that you have, and first run 'fixflop.exe' then
you will indeed be able to update the 100.
You are correct - the jeppdata.low file is 1.5m. I think 'fixflop.exe' makes
it work
Unless you have the database and it is NOT on a floppy. Which is how it is
distributed.
Folks,
John Stevens
Old October 28th 05, 02:33 PM
it work
distributed.
I in fact have it as a .zip file. I'm trying to get it on a floppy to
update my lowrance. I use it only for VFR and did not want to spend the
money to upgrade to the 1000 or 500 at this point in my training, but I
missed the last opportunity to update and the database in mine is from
2001. I guess I am cheating a little bit, but I contacted Lowrance to
see if I could buy the last database that 'fit' in the Airmap 100 and
they don't have any more.
John
Old October 29th 05, 10:56 AM
Ron Lee
John
I am also trying to update my 100 (around 1998 databse) and would like
to get the most recent database for which a floppy exists. The
upgrade program offers $100 for an Airmap 100. I do not consider that
generous. My Airmap 100 is perfectly functional although the database
is not the best now.
Ron Lee
Old November 25th 09, 08:25 PM
Joe Gores Joe Gores is offline
Junior Member
First recorded activity by AviationBanter: Nov 2009
I am also looking for a database update for my Airmap 100. Does anyone have a more recent JEPPDATA.LOW file. Mine is dated 1999. I have the ability to make a working copy of your disk for you or for me.
If your computer has a floppy drive, you can format a blank floppy disk to 1.8MB using FdFormat.exe or fdFormat 1.8 or similar programs: ftp://ftp.simtel.net/pub/simtelnet/m...il/fdfrm18.zip
You can create a virtual floppy drive with a capacity of 2.88MB using a program called "VFD Control Panel". It can be download from http://freehacking.org/toolz/geektoo...d21-080206.zip or http://chitchat.at.infoseek.co.jp/vmware/vfd.htmlelse or else search for vfd21-080206.zip. VFD Control Panel will create a file representing a virtual floppy disk to use with the virtual floppy drive.
The copy protection of the Lowrance program checks the A drive Volume Serial Number to make sure that the original floppy disk is being used and not a copy. Regardless of whether you use a virtual floppy disk formatted to 2.88MB or an actual floppy drive with a disk formatted to 1.8MB, it is necessary to change the floppy disk serial number to match the serial number of the original Lowrance floppy disk that you own. Do that from the command prompt as shown below.
Change Floppy Serial Numbers
Use DEBUG to change data on the disk. Make sure that you type the spaces between the digits as shown below.
This example shows how to set the serial number for the disk in the A: drive to any value. Notice the numbers you enter (2F 01 99 10) are mirrored from the serial number you'll get. This is just an example. You must use the serial number on your original Lowrance floppy disk.
C:\debug
-L 0 0 0 1
-E 26 29 2F 01 99 10
-W 0 0 0 1
-Q
C:\DIR A:
Volume in drive A has no label
Volume Serial Number is 1099-012F
Directory of A:\
Smooth Lowrance Airmap 1000 updates Longworth Piloting 2 August 16th 05 01:52 AM
Lowrance AirMap and Microsof Flight Simulator John Bell Piloting 0 October 26th 04 07:01 PM
Lowrance AirMap 300 plus accessories Bob Chilcoat Aviation Marketplace 1 August 19th 04 11:23 PM
GPSMAP 195/196 vs. Lowrance AIPMAP 1000 JJS Piloting 4 March 9th 04 08:14 PM
Lowrance Airmap 500 Frankenstein31 Aviation Marketplace 0 January 27th 04 08:50 AM
Copyright Đ2004-2025 AviationBanter.
