Group Poll :Oxygen
Old October 31st 05, 06:49 PM
Jim Burns
Default Group Poll :Oxygen
Do you own/rent/borrow a portable oxygen system?
Which brand?
Likes/dislikes regarding the particular brand?
System features?
Size/capacity?
Typical altitude flown when in use?
Comments please.
Thanks!
Old October 31st 05, 07:20 PM
OtisWinslow
SkyOx. I think it's about 4 hrs with a canula. Works ok.
"Jim Burns" wrote in message
Which brand?
System features?
Size/capacity?
Comments please.
Thanks!
Old October 31st 05, 07:21 PM
Michael 182
I have a factory installed 2000 lb system in my TR-182. I use it with
cannulas equipped with a flow meter. With this set up I generally get
about 20-30 hours from an O2 fillup. I use O2 from about 11K up, 8 K
at night. Above FL180 I have to switch to a mask, as per the FARs, so
I generally don't bother going up there.
Michael
Old October 31st 05, 09:38 PM
Victor J. Osborne, Jr.
Same system, diff. plane. Same use alts and duration.
You didn't mention a oximeter but I thinks it's a must.
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
"Michael 182" wrote in message
Michael
Old November 2nd 05, 02:57 AM
Ken Reed
All oxygen systems are 2000 psi. The capacity varies.
Ken Reed
N960CM
Old November 2nd 05, 06:20 AM
Bashir Salamati
On Wed, 02 Nov 2005 02:57:34 GMT, Ken Reed wrote:
: I have a factory installed 2000 lb system in my TR-182.
:All oxygen systems are 2000 psi. The capacity varies.
:Ken Reed
:N960CM
Mine is rated for 3000, but I can only rarely get that. It is a
fiberglass wrapped bottle.
http://www.mhoxygen.com/index.phtml?...product_id=291
Old November 2nd 05, 10:28 AM
Michelle P
Typically they are 1800 to 2400 depending on temp and cylinder construction.
Michelle
Ken Reed
N960CM
Old November 3rd 05, 01:39 AM
Seth Masia
I bought a small Sky-Ox bottle about five years ago. I use it over the
Rockies. I'm usually solo and it goes about 2.5 hours at 15,500 feet, which
is more than enough to get me home.
Seth
"Ken Reed" wrote in message
ink.net...
Ken Reed
N960CM
Old November 5th 05, 06:30 AM
BTIZ
check your 5 yr inspection date..
BT
"Seth Masia" wrote in message
which is more than enough to get me home.
Seth
ink.net...
Ken Reed
N960CM
Old October 31st 05, 08:09 PM
Dave Butler
Yo, Jim,
Which brand?
I bought a SkyOx system at OSH this year. I had looked at the AeroMedix products
which are less expensive, but the guy at the SkyOx booth convinced me it was
worth the extra money. The materials in the AeroMedix unit were visibly inferior.
Happy so far, but little experience.
System features?
One outlet. Mine is a steel bottle, I think the Kevlar bottles are lighter weight.
Size/capacity?
Too small. I got hung up on the idea of not wanting to schlepp any more
equipment than necessary. Since I share my plane with partners, I can't leave
things in the plane and have to carry them in the car and load and unload them
every time I fly. I thought a small size would be good because it would be less
to carry. Actually I think the increment to carry a larger size bottle would be
minimal and would mean less refilling.
I also thought I would be using it mostly alone, so I got a single outlet
system. So far I've only used it alone, so it hasn't been an issue, but it
occurred to me that it might seem a little selfish to say to my pax "I'm going
on oxygen now, and sorry, I don't have any to offer you." So I wish I had gotten
two outlets.
Actually I've used it only once so far, on the way home from OSH at 11000 and
11500. I'm convinced I arrived home less tired than if I hadn't had it.
I picked that altitude partly because I wanted to go high enough to take
advantage of the ox and try it out. There were nice winds at that altitude, and
it helped me see better when it came time to cross a line of storms over
Virginia. Otherwise, I would typically fly at 7-8000. I've made flights at
10000+ without oxygen, but it was noticably tiring.
For reference, I'm 62, and in reasonably good shape, a regular runner and
swimmer (except for a recent break to recover from back surgery). Flying a
normally aspirated Mooney.
Comments please.
May be just my lack of experience with it, but I found I need to put the cannula
in place and get all the tubing routed correctly before takeoff. It's just too
much fussin' to put it together and fly the plane at the same time.
Good luck! Dave
Group Poll :Oxygen Jim Burns Piloting 55 November 7th 05 05:40 PM
Group poll: Favorite greases Jim Burns Owning 9 May 27th 05 03:53 AM
Group Poll: How many hours between mag overhauls? Jon Kraus Owning 22 April 26th 05 01:50 AM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Group Poll: Best 2+kids or 4 place taildragger? Jim Owning 28 December 2nd 03 01:57 AM
