Wanted schematic for Narco Com120 com
Old November 4th 05, 04:36 AM
Dave
Default Wanted schematic for Narco Com120 com
Hi all
i need the schematic for a narco Com120.
Thanks
Dave
Old November 4th 05, 05:37 AM
mikem
Dave wrote:
Hi all
Thanks
Dave
Complete schematic, or just pin out for installation?
Old November 4th 05, 02:15 PM
Complete schematic.
It appears that my was wired to be on all the time and would like to
trace down the internal power circuit and wire it properly.
Dave
mikem wrote:
Dave wrote:
Hi all
Thanks
Dave
Old November 4th 05, 05:28 PM
mikem
I dont have the schematic, but I do have a pin out. It shows pins 13/14
as the 14V Power input. Pin 1 is the Power Ground. Pin 10 is the
Dimmer input.
The internal lamps will light up when ever the dimmer bus is alive,
whether the radio switch is on or off. Are you sure that the radio is
really powered with the switch off?
If so, the internal power switch may have failed. There is no wiring
at the rear connector which would cause it to be on permanently.
Narco NAV-11 Schematic wanted Aviation Marketplace 0 October 25th 05 02:32 AM
Wanted - Schematic of Century 2B bubba Owning 1 June 19th 04 06:37 PM
Things wanted cheap MRQB Owning 0 March 18th 04 12:28 AM
WANTED: Lycoming IO-320 Matt S. Aviation Marketplace 0 September 22nd 03 05:11 PM
Conspiracy Theory’s real Script: Slave CIA, FBI change the story jews wanted to tell the media Jean-Paul Roy Restoration 0 July 12th 03 12:55 PM
