Can I pose a hypotetical question
Old November 13th 05, 08:27 PM
rojolo
Default Can I pose a hypotetical question
We were discussing Engine failures in single engine aircraft with a constant
speed propeller..
Not catastrophic but more like fuel starvation types, where the prop keeps
windmilling..
The question is on getting the maximum gliding distance from the windmilling
prop..
It is assumed that a higher pitch/lower r.p.m. would give reduced drag:
hence maximum gliding distance..
The question is: Would a windmilling prop generate sufficient oil pressure
to maintain control of the propeller
and what r.p.m. would one expect from this scenario?
Old November 13th 05, 10:34 PM
john smith
speed propeller..
windmilling..
prop..
You have to know how the governor is set up for the engine you are
flying behind. Some engines are set so that when the oil pressure drops,
the prop automatically goes to high RPM. Other engines are set to
automatically go to low RPM.
Old November 14th 05, 12:29 AM
Bob Gardner
According to "Aircraft Systems for Pilots," by Dr. Dale DeMer,
constant-speed props for singles go to flat pitch (high drag) when oil
pressure is lost; constant-speed props for twins go toward the feathered
position (low drag). When flying a single, if the engine quits but the prop
is still turning, which is the usual case, pull the prop control back toward
coarse pitch to increase glide distance...you can't feather the prop, but
you can come close to it. Losing an engine in a twin means go to feather, so
in both cases the prop control comes back.
Bob Gardner
"rojolo" wrote in message
constant
speed propeller..
windmilling..
windmilling
prop..
pressure
Old November 14th 05, 03:37 AM
Bob Martin
One of the guys in our hangar has a prop on his RV-8 that apparently
goes to coarse pitch when pressure is lost... its a big ugly fat-bladed
Whirl Wind 200C, IIRC.
Old November 14th 05, 05:02 AM
George Patterson
Perhaps it came out of a twin?
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old November 30th 05, 04:00 PM posted to rec.aviation.piloting
If I was a betting man, I would say it was probably an aerobatic prop on
your friend's RV.
I believe the idea is that, there are maneuvers that result in oil
pressure drops (transitional effects of the balls in the inverted system
and some 0 G maneuvers). Much of this happens at high power settings and
flattening of the prop causes significant overspeed. As a result some
prop companies make "aerobatic" props that take more bight in a pressure
drop.
George Patterson
neighbor.
Old November 14th 05, 01:06 AM
Peter Duniho
pressure
I'm sure Bob knows the answer. I'm not sure why he didn't post it (but he
did post a bunch of other useful stuff ).
Anyway, yes...the engine RPM is likely to be high enough to provide oil
pressure to control the prop pitch.
As for what RPM to expect, I don't know. Possibly around 1000 RPM (give or
take 100 or so), less with the prop at full coarse pitch?
Pete
Old November 14th 05, 02:39 AM
cjcampbell
The problem is that single engine piston propellers go immediately to a
high rpm flat pitch when the oil pressure drops too low to operate it,
which is the worst possible case for increasing glide, but gives you
the greatest likelihood of restarting the engine. Having tried it, I
can say that at best glide the prop turns too slowly to give enough oil
pressure to control it. Even if it did and you managed to increase the
pitch, the high pitch would immediately slow the rotation of the prop
and the oil pressure would drop again. Any pitch above best glide and
the prop slows significantly and might even stop. You then have to
lower the nose quite a bit to get it turning again.
Multi-engine planes and turbine singles reverse the oil connections to
the governor. Loss of oil pressure will feather the prop. It is assumed
that you are unlikely to restart a turbine engine in the air if it
fails (nevertheless, you still practice these emergencies in aircraft
such as the King Air), and that you still have one good engine in a
twin.
All of the assumptions are a little bit questionable, of course.
Old November 14th 05, 03:28 AM
Mortimer Schnerd, RN
I've had two engine outs in singles (a Piper Lance and a C-210) and in both
cases was able to extend the glide considerably by pulling the prop all the way
back. I have no idea what rpm I was left with: I was more focused on airspeed
control at that point.
In the case of the Lance, it was a catastrophic engine failure after an oil line
vibrated loose off the oil cooler. In the C-210, it was a fuel starvation
situation. In both cases the props retarded pretty much as if you'd exercised
them during a run up. And both props were still turning at some rpm all the way
to the ground.
VE
Old November 14th 05, 06:04 AM
rojolo
Seems like you have a definitive answer having been there twice.. Thanks for
the quick reply
"Mortimer Schnerd, RN" wrote in message
pressure
both
the way
airspeed
oil line
exercised
the way
to the ground.
VE
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
