Transponder problem...
Old November 14th 05, 01:15 AM
Dave
Default Transponder problem...
Had a strange one today..
While squawking IDENT , our "ident" stuck "on"
ATC confirmed we were continuously "identing"
Cycling the transponder to off then on again cleared the
ident fault.
Pressing the button again locks the ident light on again
until the power is cycled..
Any thoughts?
Switch appears mechanically OK, (clicks when pressed, clicks
when released)..
It is a King KT78 "KT76TSO"
Dave
Old November 14th 05, 02:12 AM
Jim Macklin
Take it to an avionics shop, it isn't airworthy until you
fix it.
James H. Macklin
ATP,CFI,A&P
some support
"Dave" wrote in message
| ident fault.
| Any thoughts?
clicks
| when released)..
| Dave
Old November 14th 05, 02:58 AM
Larry Dighera
On Sun, 13 Nov 2005 20:12:43 -0600, "Jim Macklin"
wrote in
4qSdf.1063$QW2.860@dukeread08::
James H. Macklin
ATP,CFI,A&P
Welcome back to rec.aviation.piloting.
Has it been almost five years?
Old November 14th 05, 03:39 AM
Jim Macklin
Since 9/11 when I lost the cable Internet. Glad you
remember me. Just renewed my CFI for another cycle, good
until Jan 2008. I plan to win the lottery before Christmas
and buy myself a Legacy Cub. Maybe I'll put half a Garmin
1000 in it
some support
"Larry Dighera" wrote in message
| wrote in
| James H. Macklin
| ATP,CFI,A&P
Old November 14th 05, 10:21 PM
Dave
Already gone!
Dave
fix it.
James H. Macklin
ATP,CFI,A&P
Old November 17th 05, 12:31 AM posted to rec.aviation.piloting
On it's way back, should have it tomorrow....
Including taxes, .219 AMU's.. (CDN $"s)
Suprisingly, they could not reproduce the fault on the bench, so they
replaced the IC, some caps etc, all the parts in the timing circuit,
($35 in parts).. They did a full alignment, centered it to fac specs,
and are sending it home..
I am dissappointed the fault cleared on the bench, that still leaves
some doubt, but they heated it, froze it several times, then did what
they could.
How long should this timer cycle for? (How long should the "ident"
signal tx on one push of the switch?)
Dave
On Mon, 14 Nov 2005 18:21:05 -0400, Dave
Already gone!
Dave
fix it.
James H. Macklin
ATP,CFI,A&P
Old November 17th 05, 01:10 AM posted to rec.aviation.piloting
20-30 seconds
they could.
Dave
Already gone!
Dave
fix it.
James H. Macklin
ATP,CFI,A&P
Old November 17th 05, 01:23 AM posted to rec.aviation.piloting
Hmmm... that seems like a long time... tech said mine is suposed to
be set for 15 secs, and I thought that was very long time.
Can anyone direct me to a resource that explains how the "ident" sys
works? - what happens when the button is pushed, to how it appears
on the controllers radar..
I understant WHAT happens in basic fashon, I need some more details.
I have a background in electronics, so I understand the technology,
but never any training on avionics..
Thanks !
Dave
On Thu, 17 Nov 2005 01:10:44 GMT, "Michael Ware"
20-30 seconds
they could.
Dave
Already gone!
Dave
fix it.
James H. Macklin
ATP,CFI,A&P
Old November 17th 05, 01:17 PM posted to rec.aviation.piloting
"Ident" times...
Garmin GTX 330 = 18 seconds
Microair T2000 = 20 seconds
As per their manuals...
Thanks !
Dave
20-30 seconds
they could.
Dave
Already gone!
Dave
fix it.
James H. Macklin
ATP,CFI,A&P
Old November 17th 05, 01:49 PM posted to rec.aviation.piloting
When you push the transponder ident button, for the next 15-20 seconds
any reply the transponder receives has an additional pulse (called in
transponder terms the "Special Position Identification Pulse") added
to the end of the reply. Pressing the IDENT button does nothing if
you aren't being radar interrogated.
How this is displayed to the controller depends on what radar they
are using. Either the little splat on the screen that corresponds
to your aircraft changes appearance (the slash doubles) or the word
IDENT appears in your data block (knowing the hacked nature of
ATC radars there are probably more options).
Transmittion Noise - High Power Settings Paul Smedshammer Owning 6 August 20th 05 06:17 PM
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
A Cheap and Dirty Transponder Tool John P Owning 3 June 15th 04 05:30 AM
Another Cirrus BRS deployment: Dan Luke Piloting 111 April 19th 04 04:34 AM
