retrofitting an autopilot
Old November 25th 05, 07:13 PM posted to rec.aviation.owning
Default retrofitting an autopilot
The AMD Alarus IFR trainer that I'm thinking of buying is pretty well
equipped and reasonably priced but it doesn't come with an autopilot. Is it
possible to retrofit one with reasonable cost and reliability?
Old November 26th 05, 01:32 AM posted to rec.aviation.owning
Depends on your definition of 'reasonable cost'. That in turn depends on
what you want the autopilot to be able to do.
"anonymous" wrote in message
et...
it possible to retrofit one with reasonable cost and reliability?
Old November 26th 05, 01:44 AM posted to rec.aviation.owning
I guess I need a three-axis sync'd to a gps.
"Juan Jimenez" wrote in message
et...
Old November 26th 05, 07:10 AM posted to rec.aviation.owning
A cruise through the internet with Google makes me think/bet there is no
autopilot certified for the Alarus. Certainly not a three axis!
Most of these are trainers.
Karl
om...
et...
Is it possible to retrofit one with reasonable cost and reliability?
Old November 26th 05, 02:08 PM posted to rec.aviation.owning
Three axis? Why three?
Old November 26th 05, 02:21 PM posted to rec.aviation.owning
For a simple single-engine airplane, two axes is enough.
Even a single-axis (ailerons only) 'wing leveler' will
give you enough time to navigate without needing to hold
the yoke all the time.
The second axis will add elevator control. There
are different levels from attitude control to
ILS glidepath following.
The third axis (rudder) is usually needed for twins
and jets ('yaw damper').
Tauno Voipio
tauno voipio (at) iki fi
Old November 26th 05, 04:47 AM posted to rec.aviation.owning
Ask for a quote from an experienced S-Tec shop. $10-15k educated guess.
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
et...
Old November 27th 05, 12:30 AM posted to rec.aviation.owning
Ditto on that, I would recommend against Century...
"Victor J. Osborne, Jr." wrote in message ...
Thx, {|;-)
et...
The AMD Alarus IFR trainer that I'm thinking of buying is pretty well equipped and reasonably priced but it
doesn't come with an autopilot. Is it possible to retrofit one with reasonable cost and reliability?
Old November 28th 05, 12:42 AM posted to rec.aviation.owning
Tim Matheson down in Lafayette GA can do a STEC-30 out the door for
around $7500
Jon Kraus
'79 Mooney 201
4443H @ TYQ
Old November 29th 05, 02:11 AM posted to rec.aviation.owning
KAP140 autopilot and a KLN94 GPS question STICKMONKE Instrument Flight Rules 5 November 12th 05 04:06 AM
Rain and autopilot unstable W9MV Owning 3 May 18th 04 08:51 PM
mitchell autopilot dave Owning 1 May 5th 04 06:11 PM
Chelton AP-3C autopilot Kyler Laird Owning 0 April 2nd 04 03:08 PM
KAP140 Autopilot Details News Instrument Flight Rules 27 October 22nd 03 02:01 AM
